[GRASS-SVN] r36726 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Tue Apr 14 04:11:51 EDT 2009
Author: mmetz
Date: 2009-04-14 04:11:50 -0400 (Tue, 14 Apr 2009)
New Revision: 36726
grass/trunk/vector/v.out.ogr/main.c
grass/trunk/vector/v.out.ogr/v.out.ogr.html
reversed -c flag, manual updated
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2009-04-14 00:10:50 UTC (rev 36725)
+++ grass/trunk/vector/v.out.ogr/main.c 2009-04-14 08:11:50 UTC (rev 36726)
@@ -148,8 +148,8 @@
cat_flag = G_define_flag();
cat_flag->key = 'c';
- cat_flag->description = _("Export features with category (labeled) only. "
- "Otherwise all features are exported");
+ cat_flag->description = _("Also export features without category (not labeled). "
+ "Otherwise only features with category are exported");
esristyle = G_define_flag();
esristyle->key = 'e';
@@ -198,9 +198,9 @@
if (cat_flag->answer)
+ donocat = 1;
+ else
donocat = 0;
- else
- donocat = 1;
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -209,8 +209,9 @@
Vect_set_open_level(2);
Vect_open_old(&In, in_opt->answer, "");
- if (Vect_get_num_islands(&In) > 0 && !cat_flag->answer)
- G_warning(_("The map contains islands. To preserve them in the output map, use the -c flag"));
+ if ((GV_AREA & otype) && Vect_get_num_islands(&In) > 0 && cat_flag->answer)
+ G_warning(_("The map contains islands. With the -c flag, "
+ "islands will appear as filled areas, not holes in the output map."));
/* fetch PROJ info */
G_get_default_window(&cellhd);
@@ -642,7 +643,7 @@
if (noatt > 0)
G_warning(_("%d features without attributes were written"), noatt);
if (nocatskip > 0)
- G_warning(_("%d features found without category were skipped"),
+ G_message(_("%d features found without category were skipped"),
nocatskip);
/* Enable this? May be confusing that for area type are not reported
Modified: grass/trunk/vector/v.out.ogr/v.out.ogr.html
--- grass/trunk/vector/v.out.ogr/v.out.ogr.html 2009-04-14 00:10:50 UTC (rev 36725)
+++ grass/trunk/vector/v.out.ogr/v.out.ogr.html 2009-04-14 08:11:50 UTC (rev 36726)
@@ -23,10 +23,10 @@
<h2>NOTES</h2>
-To export areas with holes into, e.g., a Shapefile, while keeping the
-holes as holes, the flag <em>-c</em> has to be used.
+By default, islands will appear as holes inside surrounding areas.
+To export areas with holes into, e.g., a Shapefile, and make the
+holes appear as filled areas, the flag <em>-c</em> has to be used.
<h2>EXAMPLES</h2>
<h3>Export to Shapefile</h3>
@@ -37,8 +37,8 @@
v.out.ogr input=multi type=line dsn=/tmp olayer=testogr
</pre></div>
-Export areas from GRASS vector map to Shapefile format, preserving islands
- (generates /tmp/testogr.shp and related files):
+Export areas from GRASS vector map to Shapefile format, converting
+islands (holes) to filled areas (generates /tmp/testogr.shp and related files):
<div class="code"><pre>
v.out.ogr -c input=multi type=area dsn=/tmp olayer=testogr
</pre></div>
