[GRASS-SVN] r36727 - grass/branches/develbranch_6/lib/vector/Vlib
svn_grass at osgeo.org
Tue Apr 14 07:40:35 EDT 2009
Author: mmetz
Date: 2009-04-14 07:40:35 -0400 (Tue, 14 Apr 2009)
New Revision: 36727
grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c
cosmetics, centroid attachment synchronised to trunk
Modified: grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c
--- grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c 2009-04-14 08:11:50 UTC (rev 36726)
+++ grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c 2009-04-14 11:40:35 UTC (rev 36727)
@@ -332,7 +332,6 @@
static int first = 1;
static struct ilist *List;
P_AREA *Area;
- P_NODE *Node;
P_LINE *Line;
struct Plus_head *plus;
@@ -378,7 +377,6 @@
centr = List->value[i];
Line = plus->Line[centr];
- Node = plus->Node[Line->N1];
/* only attach unregistered and duplicate centroids because
* 1) all properly attached centroids are properly attached, really! Don't touch.
@@ -390,7 +388,7 @@
orig_area = Line->left;
- sel_area = Vect_find_area(Map, Node->x, Node->y);
+ sel_area = Vect_find_area(Map, Line->E, Line->N);
G_debug(3, " centroid %d is in area %d", centr, sel_area);
if (sel_area > 0) {
Area = plus->Area[sel_area];
@@ -398,17 +396,20 @@
G_debug(3, " first centroid -> attach to area");
Area->centroid = centr;
Line->left = sel_area;
+ if (sel_area != orig_area && plus->do_uplist)
+ dig_line_add_updated(plus, centr);
else if (Area->centroid != centr) { /* duplicate centroid */
/* Note: it cannot happen that Area->centroid == centr, because the centroid
* was not registered or a duplicate */
G_debug(3, " duplicate centroid -> do not attach to area");
Line->left = -sel_area;
+ if (-sel_area != orig_area && plus->do_uplist)
- if (sel_area != orig_area && plus->do_uplist)
- dig_line_add_updated(plus, centr);
return 0;
@@ -436,6 +437,7 @@
P_AREA *Area;
BOUND_BOX box;
struct ilist *List;
+ time_t start, end;
G_debug(3, "Vect_build_nat() build = %d", build);
@@ -509,6 +511,9 @@
/* register lines, create nodes */
Vect_rewind(Map);
+ time(&start);
G_message(_("Registering primitives..."));
i = 1;
npoints = 0;
@@ -566,6 +571,9 @@
G_message(_("%d vertices registered"), npoints);
plus->built = GV_BUILD_BASE;
+ time(&end);
+ G_message("primitives: %f", difftime(end, start));
if (build < GV_BUILD_AREAS)
@@ -575,6 +583,7 @@
/* Build areas */
/* Go through all bundaries and try to build area for both sides */
G_message(_("Building areas..."));
+ time(&start);
for (i = 1; i <= plus->n_lines; i++) {
G_percent(i, plus->n_lines, 1);
@@ -600,6 +609,9 @@
G_message(_("%d areas built"), plus->n_areas);
G_message(_("%d isles built"), plus->n_isles);
plus->built = GV_BUILD_AREAS;
+ time(&end);
+ G_message("areas: %f", difftime(end, start));
if (build < GV_BUILD_ATTACH_ISLES)
@@ -608,11 +620,14 @@
/* Attach isles to areas */
if (plus->built < GV_BUILD_ATTACH_ISLES) {
G_message(_("Attaching islands..."));
+ time(&start);
for (i = 1; i <= plus->n_isles; i++) {
G_percent(i, plus->n_isles, 1);
Vect_attach_isle(Map, i);
plus->built = GV_BUILD_ATTACH_ISLES;
+ time(&end);
+ G_message("isles: %f", difftime(end, start));
if (build < GV_BUILD_CENTROIDS)
@@ -623,6 +638,7 @@
int nlines;
G_message(_("Attaching centroids..."));
+ time(&start);
nlines = Vect_get_num_lines(Map);
for (line = 1; line <= nlines; line++) {
@@ -654,9 +670,12 @@
plus->built = GV_BUILD_CENTROIDS;
+ time(&end);
+ G_message("centroids: %f", difftime(end, start));
/* Add areas to category index */
+ time(&start);
for (area = 1; area <= plus->n_areas; area++) {
int c;
@@ -675,6 +694,8 @@
if (plus->Area[area]->centroid == 0 || Cats->n_cats == 0) /* no centroid or no cats */
dig_cidx_add_cat(plus, 0, 0, area, GV_AREA);
+ time(&end);
+ G_message("areas to cidx: %f", difftime(end, start));
return 1;
