[GRASS-SVN] r36732 - grass-addons/raster/r.terracost
svn_grass at osgeo.org
Tue Apr 14 21:07:02 EDT 2009
Author: ltoma
Date: 2009-04-14 21:07:02 -0400 (Tue, 14 Apr 2009)
New Revision: 36732
grass-addons/raster/r.terracost/main.cc
as suggested by Markus: changed parameter names to match the standard input=, output=; made default numtiles=1. labeled the Debug parameters as DBG. Fixed the error where VTMPDIR did not exist and was not created.
Modified: grass-addons/raster/r.terracost/main.cc
--- grass-addons/raster/r.terracost/main.cc 2009-04-14 19:26:25 UTC (rev 36731)
+++ grass-addons/raster/r.terracost/main.cc 2009-04-15 01:07:02 UTC (rev 36732)
@@ -88,9 +88,9 @@
/* input elevation grid */
struct Option *input_cost;
input_cost = G_define_option() ;
- input_cost->key = "cost";
+ input_cost->key = "input";
input_cost->type = TYPE_STRING;
- //input_cost->required = YES;
+ input_cost->required = YES;
input_cost->gisprompt = "old,cell,raster" ;
input_cost->description= _("Input cost grid");
@@ -99,19 +99,28 @@
source_grid = G_define_option() ;
source_grid->key = "start_raster";
source_grid->type = TYPE_STRING;
- //source_grid->required = YES;
+ source_grid->required = YES;
source_grid->gisprompt = "Raster of source points" ;
source_grid->description= _("Input raster of source points");
/* output direction grid */
struct Option *output_cost;
output_cost = G_define_option() ;
- output_cost->key = "distance";
+ output_cost->key = "output";
output_cost->type = TYPE_STRING;
- //output_cost->required = YES;
+ output_cost->required = YES;
output_cost->gisprompt = "new,cell,raster" ;
output_cost->description= _("Output distance grid");
+ /* Number of tiles */
+ struct Option *numtiles;
+ numtiles = G_define_option() ;
+ numtiles->key = "numtiles";
+ numtiles->type = TYPE_INTEGER;
+ numtiles->required = NO;
+ numtiles->description= _("Number of tiles (default: 1)");
+ numtiles->answer = G_store("1");
/* main memory */
struct Option *mem;
mem = G_define_option() ;
@@ -158,58 +167,51 @@
quiet->key = 'q' ;
quiet->description = _("Quiet") ;
+ struct Flag *info_f;
+ info_f = G_define_flag();
+ info_f->key = 'i' ;
+ info_f->description = _("Info (print suggested numtiles information and exit)");
/* save ascii grid flag */
struct Flag *ascii;
ascii = G_define_flag() ;
ascii->key = 's' ;
- ascii->description = _("Save output to ASCII file \"DIST_GRID\"");
+ ascii->description = _("Dbg: Save output to ASCII file \"DIST_GRID\"");
struct Flag *debug_f;
debug_f = G_define_flag();
debug_f->key = 'd' ;
- debug_f->description = _("Debug (for developer use)");
+ debug_f->description = _("Dbg: Print (a lot of) debug info (developer use)");
- struct Flag *info_f;
- info_f = G_define_flag();
- info_f->key = 'i' ;
- info_f->description = _("Info (prints useful information and exits)");
/* Run step0 only flag */
struct Flag *step0;
step0 = G_define_flag();
step0->key = '0' ;
- step0->description = _("Step 0 only (-h for info)");
+ step0->description = _("Dbg: Step 0 only (default: run all)");
/* Run step 1 only flag*/
struct Flag *step1;
step1 = G_define_flag() ;
step1->key = '1' ;
- step1->description = _("Step 1 only (-h for info)");
+ step1->description = _("Dbg: Step 1 only (default: run all)");
/* Run step 2 and 3 only flags */
struct Flag *step2;
step2 = G_define_flag();
step2->key = '2' ;
- step2->description = _("Step 2 only (-h for info)");
+ step2->description = _("Dbg: Step 2 only (default: run all)");
struct Flag *step3;
step3 = G_define_flag();
step3->key = '3' ;
- step3->description = _("Step 3 only (-h for info)");
+ step3->description = _("Dbg: Step 3 only (default: run all)");
struct Flag *step4;
step4 = G_define_flag();
step4->key = '4' ;
- step4->description = _("Step 4 only (-h for info)");
+ step4->description = _("Dbg: Step 4 only (default: run all)");
- /* Number of tiles; used in conjunction with step0 flag */
- struct Option *numtiles;
- numtiles = G_define_option() ;
- numtiles->key = "numtiles";
- numtiles->type = TYPE_INTEGER;
- numtiles->required = NO;
- numtiles->description= _("Number of tiles (-h for info)");
- numtiles->answer = G_store("-1");
/* Stem name for stream outputs; used in conjunction with step0 flag */
struct Option *s0out;
@@ -217,7 +219,7 @@
s0out->key = S0OUT;
s0out->type = TYPE_STRING;
s0out->required = NO;
- s0out->description= _("Stream name stem for step 0 output");
+ s0out->description= _("Dbg: Stream name stem for step 0 output");
s0out->answer = G_store(S0OUT_ANS);
struct Option *s0bnd;
@@ -225,7 +227,7 @@
s0bnd->key = S0BND;
s0bnd->type = TYPE_STRING;
s0bnd->required = NO;
- s0bnd->description= _("Stream name for boundary data structure");
+ s0bnd->description= _("Dbg: Stream name for boundary data structure");
s0bnd->answer = G_store(S0BND_ANS);
/* Name for config file output */
@@ -234,7 +236,7 @@
s1out->key = S1OUT;
s1out->type = TYPE_STRING;
s1out->required = NO;
- s1out->description= _("Output file for step 1");
+ s1out->description= _("Dbg: Output file for step 1");
s1out->answer = G_store(S1OUT_ANS);
@@ -243,7 +245,7 @@
s2bout->key = S2BOUT;
s2bout->type = TYPE_STRING;
s2bout->required = NO;
- s2bout->description= _("Output file for source to boundary stream");
+ s2bout->description= _("Dbg: Output file for source to boundary stream");
s2bout->answer = G_store(S2BOUT_ANS);
@@ -252,7 +254,7 @@
config->key = CONFIG;
config->type = TYPE_STRING;
config->required = NO;
- config->description= _("Name for config file");
+ config->description= _("Dbg: Name for config file");
config->answer = G_store(CONFIG_ANS);
@@ -261,7 +263,7 @@
phaseBnd->key = PHASE2BND;
phaseBnd->type = TYPE_STRING;
phaseBnd->required = NO;
- phaseBnd->description= _("Name for phase2Bnd file");
+ phaseBnd->description= _("Dbg: Name for phase2Bnd file");
phaseBnd->answer = G_store(PHASE2BND_ANS);
@@ -271,7 +273,7 @@
stats_opt->key = "stats";
stats_opt->type = TYPE_STRING;
stats_opt->required = NO;
- stats_opt->description= _("Stats file");
+ stats_opt->description= _("Dbg: Stats file");
stats_opt->answer = G_store(STATS_ANS);
struct Option *tilesAreSorted;
@@ -279,7 +281,7 @@
tilesAreSorted->key = "tilesAreSorted" ;
tilesAreSorted->type = TYPE_STRING;
tilesAreSorted->required = NO;
- tilesAreSorted->description = _("Tiles are sorted (used in grid version) (y/n)");
+ tilesAreSorted->description = _("Dbg: Tiles are sorted (used in grid version) (y/n)");
tilesAreSorted->answer = G_store("no");
@@ -544,18 +546,16 @@
fprintf(stdout, "terracost intermediate files in %s\n", getenv(VTMPDIR));
- if(opt->runMode != RUN_ALL) {
- struct stat sb;
- if(stat(opt->vtmpdir, &sb) < 0) {
- perror(opt->vtmpdir);
- // try to make VTMPDIR
- fprintf(stderr, "trying to create %s\n", opt->vtmpdir);
- if(mkdir(opt->vtmpdir, 0777)) {
- if(errno != EEXIST) {
- // this might not be a fatal error (maybe we dont use it), so go on -RW
- //exit(1);
+ /* DOES VTMPDIR exist? If not, create it */
+ struct stat sb;
+ if(stat(opt->vtmpdir, &sb) < 0) {
+ perror(opt->vtmpdir);
+ fprintf(stderr, "trying to create %s\n", opt->vtmpdir);
+ if(mkdir(opt->vtmpdir, 0777)) {
+ if(errno != EEXIST) {
+ // this might not be a fatal error (maybe we dont use it)?
+ exit(1);
@@ -593,9 +593,8 @@
- // PICK A GOOD NUMBER OF TILES HERE
+ // CHECK NUMBER OF TILES
if(opt->numtiles < 1) {
- fprintf(stderr, "ERROR: numtiles not set; default value=-1\n");
fprintf(stderr, "ERROR: numtiles must be >= 1\n");
exit(1);
@@ -1061,7 +1060,7 @@
assert(phase2Bnd);
}//end reconstruct
- //this should be known t this point (either form step3 or
+ //this should be known at this point (either form step3 or
//reconstructed)
assert(phase2Bnd);
