[GRASS-SVN] r36733 - grass-addons/raster/r.terracost
Wed Apr 15 07:35:07 EDT 2009
Author: neteler
Date: 2009-04-15 07:35:07 -0400 (Wed, 15 Apr 2009)
New Revision: 36733
   grass-addons/raster/r.terracost/main.cc
use G_define_standard_option() where possible; use guisection for better GUI tabs organization
Modified: grass-addons/raster/r.terracost/main.cc
--- grass-addons/raster/r.terracost/main.cc	2009-04-15 01:07:02 UTC (rev 36732)
+++ grass-addons/raster/r.terracost/main.cc	2009-04-15 11:35:07 UTC (rev 36733)
@@ -87,30 +87,20 @@
   /* input elevation grid  */
   struct Option *input_cost;
-  input_cost = G_define_option() ;
-  input_cost->key        = "input";
-  input_cost->type       = TYPE_STRING;
-  input_cost->required   = YES;
-  input_cost->gisprompt  = "old,cell,raster" ;
-  input_cost->description= _("Input cost grid");
+  input_cost = G_define_standard_option(G_OPT_R_INPUT);
+  input_cost->description= _("Name of raster map containing grid cell cost information");
   /* source point raster */
   struct Option *source_grid;
-  source_grid = G_define_option() ;
+  source_grid = G_define_standard_option(G_OPT_R_INPUT);
   source_grid->key        = "start_raster";
-  source_grid->type       = TYPE_STRING;
-  source_grid->required   = YES;
-  source_grid->gisprompt  = "Raster of source points" ;
-  source_grid->description= _("Input raster of source points");
+  source_grid->description= _("Name of starting raster points map");
+  source_grid->guisection = _("Start");
   /* output direction  grid */
   struct Option *output_cost;
-  output_cost = G_define_option() ;
-  output_cost->key        = "output";
-  output_cost->type       = TYPE_STRING;
-  output_cost->required   = YES;
-  output_cost->gisprompt  = "new,cell,raster" ;
-  output_cost->description= _("Output distance grid");
+  output_cost = G_define_standard_option(G_OPT_R_OUTPUT);
+  output_cost->description= _("Output distance grid raster map");
   /* Number of tiles */
   struct Option *numtiles;
@@ -162,6 +152,7 @@
   help_f->description  = _("Help");
   /* verbose flag */
+  /* please, remove before GRASS 7 released */
   struct Flag *quiet;
   quiet = G_define_flag() ;
   quiet->key         = 'q' ;
@@ -177,42 +168,47 @@
   ascii = G_define_flag() ;
   ascii->key         = 's' ;
   ascii->description = _("Dbg: Save output to ASCII file \"DIST_GRID\"");
+  ascii->guisection = _("Debug");
   struct Flag *debug_f;
   debug_f = G_define_flag();
   debug_f->key         = 'd' ;
   debug_f->description  = _("Dbg: Print (a lot of) debug info (developer use)");
+  debug_f->guisection = _("Debug");
   /* Run step0 only flag */
   struct Flag *step0;
   step0 = G_define_flag();
   step0->key         = '0' ;
   step0->description  = _("Dbg: Step 0 only (default: run all)");
+  step0->guisection = _("Debug");
   /* Run step 1 only flag*/
   struct Flag *step1;
   step1 = G_define_flag() ;
   step1->key         = '1' ;
   step1->description = _("Dbg: Step 1 only (default: run all)");
+  step1->guisection = _("Debug");
   /* Run step 2 and 3 only flags */
   struct Flag *step2;
   step2 = G_define_flag();
   step2->key         = '2' ;
   step2->description  = _("Dbg: Step 2 only (default: run all)");
+  step2->guisection = _("Debug");
   struct Flag *step3;
   step3 = G_define_flag();
   step3->key         = '3' ;
   step3->description  = _("Dbg: Step 3 only (default: run all)");
+  step3->guisection = _("Debug");
   struct Flag *step4;
   step4 = G_define_flag();
   step4->key         = '4' ;
   step4->description  = _("Dbg: Step 4 only (default: run all)");
+  step4->guisection = _("Debug");
   /* Stem name for stream outputs; used in conjunction with step0 flag */
   struct Option *s0out;
   s0out = G_define_option() ;
@@ -221,6 +217,7 @@
   s0out->required   = NO;
   s0out->description= _("Dbg: Stream name stem for step 0 output");
   s0out->answer     = G_store(S0OUT_ANS);
+  s0out->guisection = _("Debug");
   struct Option *s0bnd;
   s0bnd = G_define_option() ;
@@ -229,6 +226,7 @@
   s0bnd->required   = NO;
   s0bnd->description= _("Dbg: Stream name for boundary data structure");
   s0bnd->answer     = G_store(S0BND_ANS);
+  s0bnd->guisection = _("Debug");
   /* Name for config file output */
   struct Option *s1out;
@@ -238,6 +236,7 @@
   s1out->required   = NO;
   s1out->description= _("Dbg: Output file for step 1");
   s1out->answer     = G_store(S1OUT_ANS);
+  s1out->guisection = _("Debug");
   struct Option *s2bout;
@@ -247,6 +246,7 @@
   s2bout->required   = NO;
   s2bout->description= _("Dbg: Output file for source to boundary stream");
   s2bout->answer     = G_store(S2BOUT_ANS);
+  s2bout->guisection = _("Debug");
   struct Option *config;
@@ -256,6 +256,7 @@
   config->required   = NO;
   config->description= _("Dbg: Name for config file");
   config->answer     = G_store(CONFIG_ANS);
+  config->guisection = _("Debug");
   struct Option *phaseBnd;
@@ -265,8 +266,8 @@
   phaseBnd->required   = NO;
   phaseBnd->description= _("Dbg: Name for phase2Bnd file");
   phaseBnd->answer     = G_store(PHASE2BND_ANS);
+  phaseBnd->guisection = _("Debug");
   /* stats file */
   struct Option *stats_opt;
   stats_opt = G_define_option() ;
@@ -275,6 +276,7 @@
   stats_opt->required   = NO;
   stats_opt->description= _("Dbg: Stats file");
   stats_opt->answer     = G_store(STATS_ANS);
+  stats_opt->guisection = _("Debug");
   struct Option *tilesAreSorted;
   tilesAreSorted =  G_define_option();
@@ -283,8 +285,8 @@
   tilesAreSorted->required   = NO;
   tilesAreSorted->description  = _("Dbg: Tiles are sorted (used in grid version) (y/n)");
   tilesAreSorted->answer = G_store("no");
+  tilesAreSorted->guisection = _("Debug");
   if (G_parser(argc, argv)) {
     exit (EXIT_FAILURE);
