[GRASS-SVN] r36801 - grass-addons/raster/r.soils.texture
svn_grass at osgeo.org
Sun Apr 19 22:52:03 EDT 2009
Author: hamish
Date: 2009-04-19 22:52:03 -0400 (Sun, 19 Apr 2009)
New Revision: 36801
grass-addons/raster/r.soils.texture/description.html
grass-addons/raster/r.soils.texture/local_include.h
grass-addons/raster/r.soils.texture/main.c
run grass_indent.sh on code
Modified: grass-addons/raster/r.soils.texture/description.html
--- grass-addons/raster/r.soils.texture/description.html 2009-04-20 02:45:48 UTC (rev 36800)
+++ grass-addons/raster/r.soils.texture/description.html 2009-04-20 02:52:03 UTC (rev 36801)
@@ -29,8 +29,10 @@
<p>Sanesi G., 2000 - Elementi di pedologia - Edagricole, Bologna</p>
<p>Texture AutoLookup (TAL) ver 4.2, 2002 </p>
<p>Van Rossum G. - 2005 - Manuale di riferimento di python - Ed. Italiana, Fred L. Drake, Jr., editor</p>
-<p>WATTON J. D., 1997 - Comparing C, Fortran, Lisp, java, python, perl, scheme (guile), and tcl using a</p>
-<p>floating point numerical test - point inside polygon. Applied mathematics and computer technology center alcoa technical center. Distribution documents.</p>
+<p>WATTON J. D., 1997 - Comparing C, Fortran, Lisp, java, python, perl,
+scheme (guile), and tcl using a floating point numerical test - point inside
+polygon. Applied mathematics and computer technology center alcoa technical
+center. Distribution documents.</p>
<p>
<br><br>
</p>
Modified: grass-addons/raster/r.soils.texture/local_include.h
--- grass-addons/raster/r.soils.texture/local_include.h 2009-04-20 02:45:48 UTC (rev 36800)
+++ grass-addons/raster/r.soils.texture/local_include.h 2009-04-20 02:52:03 UTC (rev 36801)
@@ -1,3 +1,4 @@
* MODULE: r.soils.texture
@@ -16,23 +17,26 @@
#define MAX_POINT 15
#define MAX_LABEL 50
-/*///////List element prototipe///////////////////////////////*/
-struct TextureTriangleCoord {
- int numVertex; // polygons vertex of texture triangle
- float xSand[MAX_POINT], yClay[MAX_POINT]; // coordinate vector polygons in triangle
- int codeTexture; // code for identify textural type
- struct TextureTriangleCoord *PointToNext; //pointer to next element
-struct label_struct {
- int id;
- char etichetta[1024];
+/*///////List element prototipe/////////////////////////////// */
+struct TextureTriangleCoord
+ int numVertex; // polygons vertex of texture triangle
+ float xSand[MAX_POINT], yClay[MAX_POINT]; // coordinate vector polygons in triangle
+ int codeTexture; // code for identify textural type
+ struct TextureTriangleCoord *PointToNext; //pointer to next element
+struct label_struct
+ int id;
+ char etichetta[1024];
* function prototype
-struct TextureTriangleCoord *ReadTriangle(int *, char *); //read texture file criteria (es. USDA.DAT)
-int ReadList(struct TextureTriangleCoord *, int *, float, float); //read all list of texture criteria
-int DefineTexture (int numVert, float *xSand, float *yClay, float SandVal, float ClayVal, int codeTxt); /*define texture for each point*/
-void reclassTexture(char *SchemeName, char *result); //reclass texture file with label
+struct TextureTriangleCoord *ReadTriangle(int *, char *); //read texture file criteria (es. USDA.DAT)
+int ReadList(struct TextureTriangleCoord *, int *, float, float); //read all list of texture criteria
+int DefineTexture(int numVert, float *xSand, float *yClay, float SandVal, float ClayVal, int codeTxt); /*define texture for each point */
+void reclassTexture(char *SchemeName, char *result); //reclass texture file with label
Modified: grass-addons/raster/r.soils.texture/main.c
--- grass-addons/raster/r.soils.texture/main.c 2009-04-20 02:45:48 UTC (rev 36800)
+++ grass-addons/raster/r.soils.texture/main.c 2009-04-20 02:52:03 UTC (rev 36801)
@@ -1,3 +1,4 @@
@@ -21,8 +22,8 @@
#include <grass/gis.h>
#include <grass/glocale.h>
#include "local_include.h"
* global function declaration
@@ -30,35 +31,42 @@
extern FCELL f_f(FCELL);
extern DCELL f_d(DCELL);
-CELL c_calc(CELL c_sand, CELL c_clay, struct TextureTriangleCoord *punt_lista, int *numPoly)
+CELL c_calc(CELL c_sand, CELL c_clay, struct TextureTriangleCoord *punt_lista,
+ int *numPoly)
CELL out;
int polygons;
- polygons=*numPoly;
- out=ReadList(punt_lista, &polygons, c_sand, c_clay);
+ polygons = *numPoly;
+ out = ReadList(punt_lista, &polygons, c_sand, c_clay);
return out;
-FCELL f_calc(FCELL f_sand, FCELL f_clay, struct TextureTriangleCoord *punt_lista, int *numPoly )
+FCELL f_calc(FCELL f_sand, FCELL f_clay,
+ struct TextureTriangleCoord * punt_lista, int *numPoly)
FCELL out;
int polygons;
- out=ReadList(punt_lista, &polygons, f_sand, f_clay);
+ out = ReadList(punt_lista, &polygons, f_sand, f_clay);
return out;
-DCELL d_calc(DCELL d_sand, DCELL d_clay, struct TextureTriangleCoord *punt_lista, int *numPoly )
+DCELL d_calc(DCELL d_sand, DCELL d_clay,
DCELL out;
int polygons;
- out=ReadList(punt_lista, &polygons, d_sand, d_clay);
+ out = ReadList(punt_lista, &polygons, d_sand, d_clay);
return out;
* main function
* it copies raster inputSand raster file, calling the appropriate function for each
@@ -66,59 +74,59 @@
int main(int argc, char *argv[])
- struct Cell_head cellhd; /* it stores region information, and header information of rasters */
- char *SandName, *ClayName, *SchemeName; /* inputSand raster name */
- char *result; /* output raster name */
- char *mapsetSand, *mapsetClay; /* mapset name */
- void *inrastSand, *inrastClay; /* input buffer */
- unsigned char *outrast; /* output buffer */
+ struct Cell_head cellhd; /* it stores region information, and header information of rasters */
+ char *SandName, *ClayName, *SchemeName; /* inputSand raster name */
+ char *result; /* output raster name */
+ char *mapsetSand, *mapsetClay; /* mapset name */
+ void *inrastSand, *inrastClay; /* input buffer */
+ unsigned char *outrast; /* output buffer */
int nrows, ncols;
int row, col;
- int infdSand, infdClay, outfd; /* file descriptor */
+ int infdSand, infdClay, outfd; /* file descriptor */
int verbose;
int polygons;
- RASTER_MAP_TYPE data_type_Sand, data_type_Clay, data_type; /* type of the map (CELL/DCELL/...) */
+ RASTER_MAP_TYPE data_type_Sand, data_type_Clay, data_type; /* type of the map (CELL/DCELL/...) */
- struct GModule *module; /* GRASS module for parsing arguments */
+ struct GModule *module; /* GRASS module for parsing arguments */
struct Option *inputSand, *inputClay, *inputTextureScheme, *output; /* options */
- struct Flag *flag1; /* flags */
+ struct Flag *flag1; /* flags */
struct TextureTriangleCoord *punt_lista;
/* initialize GIS environment */
G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
/* initialize module */
module = G_define_module();
- module->description = _("Define soil texture from sand and clay grid."); //D
+ module->description = _("Define soil texture from sand and clay grid."); //D
- /* Define the different options for SAND file*/
+ /* Define the different options for SAND file */
inputSand = G_define_option();
inputSand->key = "SAND";
inputSand->type = TYPE_STRING;
inputSand->required = YES;
- inputSand->gisprompt = "old,cell,raster";
+ inputSand->gisprompt = "old,cell,raster";
inputSand->description = _("Name of an input SAND layer");
- /* Define the different options for CLAY file*/
+ /* Define the different options for CLAY file */
inputClay = G_define_option();
inputClay->key = "CLAY";
inputClay->type = TYPE_STRING;
inputClay->required = YES;
- inputClay->gisprompt = "old,cell,raster";
+ inputClay->gisprompt = "old,cell,raster";
inputClay->description = _("Name of an input CLAY layer");
- /*Define the texture file scheme: USDA, FAO, International or other scheme*/
+ /*Define the texture file scheme: USDA, FAO, International or other scheme */
inputTextureScheme = G_define_option();
inputTextureScheme->key = "scheme";
inputTextureScheme->type = TYPE_STRING;
inputTextureScheme->required = YES;
inputTextureScheme->gisprompt = "old_file,file,input";
- inputTextureScheme->answer ="";
+ inputTextureScheme->answer = "";
inputTextureScheme->description = "Text file with texture scheme ";
output = G_define_option();
output->key = "output";
output->type = TYPE_STRING;
@@ -132,8 +140,9 @@
/* stores options and flags to variables */
SandName = inputSand->answer;
ClayName = inputClay->answer;
- SchemeName= inputTextureScheme->answer;
+ SchemeName = inputTextureScheme->answer;
result = output->answer;
/*************************************control sand file*****************************/
/* returns NULL if the map was not found in any mapset,
* mapset name otherwise */
@@ -143,7 +152,7 @@
if (G_legal_filename(result) < 0)
G_fatal_error(_("[%s] is an illegal name"), result);
/* determine the input map type (CELL/FCELL/DCELL) */
data_type_Sand = G_raster_map_type(SandName, mapsetSand);
@@ -155,18 +164,19 @@
/* controlling, if we can open inputSand raster */
if (G_get_cellhd(SandName, mapsetSand, &cellhd) < 0)
G_fatal_error(_("Cannot read file header of [%s]"), SandName);
/*********************************control clay file **********************************/
mapsetClay = G_find_cell2(ClayName, "");
if (mapsetClay == NULL)
G_fatal_error(_("cell file [%s] not found"), ClayName);
data_type_Clay = G_raster_map_type(ClayName, mapsetClay);
@@ -182,55 +192,56 @@
/* Allocate input buffer */
inrastSand = G_allocate_raster_buf(data_type_Sand);
- inrastClay= G_allocate_raster_buf(data_type_Clay);
+ inrastClay = G_allocate_raster_buf(data_type_Clay);
/* Allocate output buffer, use input Sand map data_type */
nrows = G_window_rows();
ncols = G_window_cols();
outrast = G_allocate_raster_buf(data_type_Sand);
- data_type=data_type_Sand;
+ data_type = data_type_Sand;
/* controlling, if we can write the raster */
if ((outfd = G_open_raster_new(result, data_type)) < 0)
G_fatal_error(_("Could not open <%s>"), result);
- punt_lista=ReadTriangle(&polygons,SchemeName);//read texture criteria file (es USDA.DAT) and buil a list
+ punt_lista = ReadTriangle(&polygons, SchemeName); //read texture criteria file (es USDA.DAT) and buil a list
CELL c_sand, c_clay, c;
FCELL f_sand, f_clay, f;
DCELL d_sand, d_clay, d;
/* for each row */
for (row = 0; row < nrows; row++) {
- if (verbose)
+ if (verbose)
G_percent(row, nrows, 2);
/* read input Sand map */
- if (G_get_raster_row(infdSand, inrastSand, row, data_type_Sand) < 0)
- G_fatal_error(_("Could not read from <%s>"), SandName);
- if (G_get_raster_row(infdClay, inrastClay, row, data_type_Sand) < 0)
- G_fatal_error(_("Could not read from <%s>"), ClayName);
+ if (G_get_raster_row(infdSand, inrastSand, row, data_type_Sand) < 0)
+ G_fatal_error(_("Could not read from <%s>"), SandName);
+ if (G_get_raster_row(infdClay, inrastClay, row, data_type_Sand) < 0)
+ G_fatal_error(_("Could not read from <%s>"), ClayName);
/* process the data */
- for (col = 0; col < ncols; col++) {
+ for (col = 0; col < ncols; col++) {
/* use different function for each data type */
- switch (data_type) {
- case CELL_TYPE:
- c_sand = ((CELL *) inrastSand)[col];
- c_clay = ((CELL *) inrastClay)[col];
- c = c_calc(c_sand, c_clay, punt_lista, &polygons); /* calculate */
- ((CELL *) outrast)[col] = c;
- break;
- case FCELL_TYPE:
- f_sand = ((FCELL *) inrastSand)[col];
- f_clay = ((FCELL *) inrastClay)[col];
- f = f_calc(f_sand, f_clay, punt_lista, &polygons); /* calculate */
- ((FCELL *) outrast)[col] = f;
- break;
- case DCELL_TYPE:
- d_sand = ((DCELL *) inrastSand)[col];
- d_clay = ((DCELL *) inrastClay)[col];
- d = d_calc(d_sand, d_clay, punt_lista, &polygons); /* calculate */
- ((DCELL *) outrast)[col] = d;
- break;
+ switch (data_type) {
+ case CELL_TYPE:
+ c_sand = ((CELL *) inrastSand)[col];
+ c_clay = ((CELL *) inrastClay)[col];
+ c = c_calc(c_sand, c_clay, punt_lista, &polygons); /* calculate */
+ ((CELL *) outrast)[col] = c;
+ break;
+ case FCELL_TYPE:
+ f_sand = ((FCELL *) inrastSand)[col];
+ f_clay = ((FCELL *) inrastClay)[col];
+ f = f_calc(f_sand, f_clay, punt_lista, &polygons); /* calculate */
+ ((FCELL *) outrast)[col] = f;
+ break;
+ case DCELL_TYPE:
+ d_sand = ((DCELL *) inrastSand)[col];
+ d_clay = ((DCELL *) inrastClay)[col];
+ d = d_calc(d_sand, d_clay, punt_lista, &polygons); /* calculate */
+ ((DCELL *) outrast)[col] = d;
+ break;
@@ -238,7 +249,7 @@
if (G_put_raster_row(outfd, outrast, data_type) < 0)
G_fatal_error(_("Cannot write to <%s>"), result);
/* memory cleanup */
G_free(inrastSand);
G_free(inrastClay);
@@ -249,9 +260,9 @@
G_close_cell(infdClay);
G_close_cell(outfd);
- reclassTexture(SchemeName,result);
- G_message("Soil texture file generated with name:<%s>",result);
+ reclassTexture(SchemeName, result);
+ G_message("Soil texture file generated with name:<%s>", result);
return 0;
@@ -259,149 +270,152 @@
-struct TextureTriangleCoord *ReadTriangle(int *numPoly, char *SchemeName )
+struct TextureTriangleCoord *ReadTriangle(int *numPoly, char *SchemeName)
- /*//////////// Declare Read Poly texture structure ////////////////////////////*/
- struct TextureTriangleCoord Triangle, *pTxt, *paus;
- pTxt=&Triangle; //pointer to struct
- int i,j,polygons;
- FILE* fp_dat;
+ /*//////////// Declare Read Poly texture structure //////////////////////////// */
+ struct TextureTriangleCoord Triangle, *pTxt, *paus;
- fp_dat=fopen(SchemeName,"r");
- if (fp_dat==NULL){
- printf("Could not read from <%s>", SchemeName);
+ pTxt = &Triangle; //pointer to struct
+ int i, j, polygons;
+ FILE *fp_dat;
+ fp_dat = fopen(SchemeName, "r");
+ if (fp_dat == NULL) {
+ printf("Could not read from <%s>", SchemeName);
+ fscanf(fp_dat, "%d", numPoly);
+ if (polygons == 0) {
+ pTxt = NULL; /*break if no polygons */
+ else {
+ pTxt = (struct TextureTriangleCoord *)malloc(sizeof(struct TextureTriangleCoord)); /*first struct PolygonCoord */
+ fscanf(fp_dat, "%d", &pTxt->codeTexture);
+ fscanf(fp_dat, "%d", &pTxt->numVertex);
+ for (j = 0; j < (pTxt->numVertex); j++) { //fill sand array with coord. polygons array
+ fscanf(fp_dat, "%f", &pTxt->xSand[j]);
- fscanf(fp_dat,"%d",numPoly);
- if (polygons==0) {
- pTxt=NULL; /*break if no polygons*/
+ for (j = 0; j < (pTxt->numVertex); j++) { //fill clay array with coord. polygons array
+ fscanf(fp_dat, "%f", &pTxt->yClay[j]);
- else
- pTxt=(struct TextureTriangleCoord *)malloc(sizeof(struct TextureTriangleCoord)); /*first struct PolygonCoord*/
- fscanf(fp_dat,"%d",&pTxt->codeTexture);
- fscanf(fp_dat,"%d",&pTxt->numVertex);
- for(j=0;j<(pTxt->numVertex);j++) { //fill sand array with coord. polygons array
- fscanf(fp_dat,"%f",&pTxt->xSand[j]);
- for(j=0;j<(pTxt->numVertex);j++) { //fill clay array with coord. polygons array
- fscanf(fp_dat,"%f",&pTxt->yClay[j]);
- paus=pTxt;
- for(i=2;i<=polygons;i++)
- paus->PointToNext=(struct TextureTriangleCoord *)malloc(sizeof(struct TextureTriangleCoord));
- paus=paus->PointToNext;
- fscanf(fp_dat,"%d",&paus->codeTexture);
- fscanf(fp_dat,"%d",&paus->numVertex);
- for(j=0;j<(paus->numVertex);j++) { //fill sand array with coord. polygons array
- fscanf(fp_dat,"%f",&paus->xSand[j]);
- for(j=0;j<(paus->numVertex);j++) { //fill clay array with coord. polygons array
- fscanf(fp_dat,"%f",&paus->yClay[j]);
- paus->PointToNext=NULL;
+ paus = pTxt;
+ for (i = 2; i <= polygons; i++) {
+ paus->PointToNext =
+ (struct TextureTriangleCoord *)
+ malloc(sizeof(struct TextureTriangleCoord));
+ paus = paus->PointToNext;
+ fscanf(fp_dat, "%d", &paus->codeTexture);
+ fscanf(fp_dat, "%d", &paus->numVertex);
+ for (j = 0; j < (paus->numVertex); j++) { //fill sand array with coord. polygons array
+ fscanf(fp_dat, "%f", &paus->xSand[j]);
+ for (j = 0; j < (paus->numVertex); j++) { //fill clay array with coord. polygons array
+ fscanf(fp_dat, "%f", &paus->yClay[j]);
- fclose (fp_dat);
- return (pTxt);
+ paus->PointToNext = NULL;
+ fclose(fp_dat);
+ return (pTxt);
-int ReadList(struct TextureTriangleCoord *pTxt, int *numPoly,float SandVal, float ClayVal )
+int ReadList(struct TextureTriangleCoord *pTxt, int *numPoly, float SandVal,
+ float ClayVal)
- int polygons,textureOUT;
- textureOUT=0;
- while(pTxt!=NULL && textureOUT==0) {
- textureOUT=DefineTexture (pTxt->numVertex, pTxt->xSand, pTxt->yClay, SandVal, ClayVal, pTxt->codeTexture);
- pTxt=pTxt->PointToNext;
+ int polygons, textureOUT;
- return textureOUT;
+ textureOUT = 0;
+ while (pTxt != NULL && textureOUT == 0) {
+ textureOUT =
+ DefineTexture(pTxt->numVertex, pTxt->xSand, pTxt->yClay, SandVal,
+ ClayVal, pTxt->codeTexture);
+ pTxt = pTxt->PointToNext;
+ return textureOUT;
+ float ClayVal, int codeTxt)
- int i, j, textureVER=0;
+ int i, j, textureVER = 0;
- for (i = 0, j = numVert-1; i < numVert; j = i++) {
- if ((((yClay[i] <= ClayVal) && (ClayVal < yClay[j])) || ((yClay[j] <= ClayVal) && (ClayVal < yClay[i]))) &&
- (SandVal < (xSand[j] - xSand[i]) * (ClayVal - yClay[i]) / (yClay[j] - yClay[i]) + xSand[i]))
- textureVER = !textureVER;
+ for (i = 0, j = numVert - 1; i < numVert; j = i++) {
+ if ((((yClay[i] <= ClayVal) && (ClayVal < yClay[j])) ||
+ ((yClay[j] <= ClayVal) && (ClayVal < yClay[i]))) &&
+ (SandVal <
+ (xSand[j] - xSand[i]) * (ClayVal - yClay[i]) / (yClay[j] -
+ yClay[i]) +
+ xSand[i]))
+ textureVER = !textureVER;
- if (textureVER == 1)
- textureVER=codeTxt;
- else {
- textureVER=0;
- return textureVER;
+ if (textureVER == 1) {
+ textureVER = codeTxt;
+ else {
+ textureVER = 0;
+ return textureVER;
-void reclassTexture(char *SchemeName, char *result) /*reclass texture file with label in scheme file*/
+{ /*reclass texture file with label in scheme file */
- int control,i;
- char c,command[1024];
+ int control, i;
+ char c, command[1024];
- struct label_struct label, *plabel;
- struct Categories pcats;
- FILE* fp_dat;
+ struct label_struct label, *plabel;
+ struct Categories pcats;
- plabel=&label;
+ FILE *fp_dat;
- if (G_read_cats (result, G_mapset(), &pcats) < 0) /*read raster category file*/
- G_fatal_error (("%s: %s in %s - can't read category file"),G_program_name(), result, G_mapset());
- if (fp_dat==NULL)
- G_fatal_error(_("Could not open <%s>"), SchemeName);
- fscanf(fp_dat,"%d",&control);
+ plabel = &label;
- while(c!='#')
- fscanf(fp_dat,"%c",&c);
+ if (G_read_cats(result, G_mapset(), &pcats) < 0) /*read raster category file */
+ G_fatal_error(("%s: %s in %s - can't read category file"),
+ G_program_name(), result, G_mapset());
- sprintf(command,"NULL");
- G_set_cat(0, command,&pcats); /*set a category label. The label is copied into the cats structure for category n.*/
+ G_fatal_error(_("Could not open <%s>"), SchemeName);
+ fscanf(fp_dat, "%d", &control);
- for(i=1;i<=control;i++)
- fscanf(fp_dat,"%s",&plabel->etichetta);
- sprintf(command,"%s",plabel->etichetta);
- G_set_cat(i, command,&pcats);
+ while (c != '#') {
+ fscanf(fp_dat, "%c", &c);
- G_write_cats(result,&pcats);
+ sprintf(command, "NULL");
+ G_set_cat(0, command, &pcats); /*set a category label. The label is copied into the cats structure for category n. */
- fclose (fp_dat);
- /*return (0);*/
+ for (i = 1; i <= control; i++) {
+ fscanf(fp_dat, "%s", &plabel->etichetta);
+ sprintf(command, "%s", plabel->etichetta);
+ G_set_cat(i, command, &pcats);
+ G_write_cats(result, &pcats);
+ fclose(fp_dat);
+ /*return (0); */
