[GRASS-SVN] r36802 - grass-addons/raster/r.soils.texture
svn_grass at osgeo.org
Sun Apr 19 23:06:32 EDT 2009
Author: hamish
Date: 2009-04-19 23:06:32 -0400 (Sun, 19 Apr 2009)
New Revision: 36802
grass-addons/raster/r.soils.texture/main.c
use G_define_standard_option(), EXIT_SUCCESS, remove unused variable
Modified: grass-addons/raster/r.soils.texture/main.c
--- grass-addons/raster/r.soils.texture/main.c 2009-04-20 02:52:03 UTC (rev 36801)
+++ grass-addons/raster/r.soils.texture/main.c 2009-04-20 03:06:32 UTC (rev 36802)
@@ -24,9 +24,7 @@
#include "local_include.h"
- * global function declaration
+/* global function declaration */
extern CELL f_c(CELL);
extern FCELL f_f(FCELL);
extern DCELL f_d(DCELL);
@@ -90,7 +88,6 @@
struct GModule *module; /* GRASS module for parsing arguments */
struct Option *inputSand, *inputClay, *inputTextureScheme, *output; /* options */
- struct Flag *flag1; /* flags */
struct TextureTriangleCoord *punt_lista;
@@ -103,40 +100,27 @@
module->description = _("Define soil texture from sand and clay grid."); //D
/* Define the different options for SAND file */
- inputSand = G_define_option();
- inputSand->key = "SAND";
- inputSand->type = TYPE_STRING;
- inputSand->required = YES;
- inputSand->gisprompt = "old,cell,raster";
- inputSand->description = _("Name of an input SAND layer");
+ inputSand = G_define_standard_option(G_OPT_R_INPUT);
+ inputSand->key = "sand";
+ inputSand->description = _("Name of input SAND map");
/* Define the different options for CLAY file */
- inputClay = G_define_option();
- inputClay->key = "CLAY";
- inputClay->type = TYPE_STRING;
- inputClay->required = YES;
- inputClay->gisprompt = "old,cell,raster";
- inputClay->description = _("Name of an input CLAY layer");
+ inputClay = G_define_standard_option(G_OPT_R_INPUT);
+ inputClay->key = "clay";
+ inputClay->description = _("Name of input CLAY map");
/*Define the texture file scheme: USDA, FAO, International or other scheme */
- inputTextureScheme = G_define_option();
+ inputTextureScheme = G_define_standard_option(G_OPT_F_INPUT);
inputTextureScheme->key = "scheme";
- inputTextureScheme->type = TYPE_STRING;
- inputTextureScheme->required = YES;
- inputTextureScheme->gisprompt = "old_file,file,input";
- inputTextureScheme->answer = "";
- inputTextureScheme->description = "Text file with texture scheme ";
+ inputTextureScheme->description = _("Text file with texture scheme");
- output = G_define_option();
- output->key = "output";
- output->type = TYPE_STRING;
- output->required = YES;
- output->description = _("Output texture file");
+ output = G_define_standard_option(G_OPT_R_OUTPUT);
/* options and flags pareser */
if (G_parser(argc, argv))
- exit(-1);
+ exit(EXIT_FAILURE);
/* stores options and flags to variables */
SandName = inputSand->answer;
ClayName = inputClay->answer;
@@ -262,8 +246,8 @@
reclassTexture(SchemeName, result);
- G_message("Soil texture file generated with name:<%s>", result);
- return 0;
+ G_done_msg(_("Soil texture file generated with name: <%s>"), result);
+ exit(EXIT_SUCCESS);
