[GRASS-SVN] r36803 - grass/trunk/vector/v.in.dxf
Sun Apr 19 23:08:01 EDT 2009
Author: hcho
Date: 2009-04-19 23:08:01 -0400 (Sun, 19 Apr 2009)
New Revision: 36803
   grass/trunk/vector/v.in.dxf/add_lwpolyline.c
   grass/trunk/vector/v.in.dxf/make_arc.c
Support for LWPOLYLINE elevations
Modified: grass/trunk/vector/v.in.dxf/add_lwpolyline.c
--- grass/trunk/vector/v.in.dxf/add_lwpolyline.c	2009-04-20 03:06:32 UTC (rev 36802)
+++ grass/trunk/vector/v.in.dxf/add_lwpolyline.c	2009-04-20 03:08:01 UTC (rev 36803)
@@ -11,6 +11,7 @@
     int polyline_flag = 0;	/* indicates the type of polyline */
     int xflag = 0;		/* indicates if a x value has been found */
     int yflag = 0;		/* indicates if a y value has been found */
+    double elevation = 0.0;	/* elevation */
     int arr_size = 0;
     /* variables to create arcs */
@@ -20,7 +21,6 @@
     handle[0] = 0;
     strcpy(layer, UNIDENTIFIED_LAYER);
-    zpnts[0] = 0.0;
     /* read in lines and process information until a 0 is read in */
     while ((code = dxf_get_code(dxf)) != 0) {
 	if (code == -2)
@@ -56,6 +56,9 @@
 	    ypnts[arr_size] = atof(dxf_buf);
 	    yflag = 1;
 	    break;
+	case 38:
+	    elevation = atof(dxf_buf);
+	    break;
 	case 42:		/* bulge */
 	    bulge = atof(dxf_buf);
 	    break;
@@ -83,6 +86,13 @@
+	int i;
+	for (i = 0; i < arr_size; i++)
+	    zpnts[i] = elevation;
     if (polyline_flag & 1) {
 	if (xpnts[0] != xpnts[arr_size - 1] ||
 	    ypnts[0] != ypnts[arr_size - 1]) {
@@ -102,13 +112,6 @@
-	int i;
-	for (i = 0; i < arr_size; i++)
-	    zpnts[i] = 0.0;
     write_vect(Map, layer, "LWPOLYLINE", handle, "", arr_size, GV_LINE);
     return;
Modified: grass/trunk/vector/v.in.dxf/make_arc.c
--- grass/trunk/vector/v.in.dxf/make_arc.c	2009-04-20 03:06:32 UTC (rev 36802)
+++ grass/trunk/vector/v.in.dxf/make_arc.c	2009-04-20 03:08:01 UTC (rev 36803)
@@ -32,7 +32,7 @@
 	    ypnts[arr_size] = radius * sin(alpha) + centery;
 	    zpnts[arr_size] = zcoor;
 	    theta -= RSTEP;
-	    if (arr_size == arr_max) {
+	    if (arr_size >= arr_max - 1) {
 		arr_max += ARR_INCR;
 		xpnts = (double *)G_realloc(xpnts, arr_max * sizeof(double));
 		ypnts = (double *)G_realloc(ypnts, arr_max * sizeof(double));
@@ -49,7 +49,7 @@
 	    theta += RSTEP;
@@ -63,7 +63,7 @@
     xpnts[arr_size] = radius * cos(alpha) + centerx;
