[GRASS-SVN] r38623 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Thu Aug 6 03:47:28 EDT 2009
Author: mmetz
Date: 2009-08-06 03:47:27 -0400 (Thu, 06 Aug 2009)
New Revision: 38623
grass/trunk/lib/vector/diglib/spindex_rw.c
fixed loading index, some cleanup
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c 2009-08-05 16:33:07 UTC (rev 38622)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c 2009-08-06 07:47:27 UTC (rev 38623)
@@ -609,7 +609,7 @@
s[top].branch_id = i = 0;
s[top].sn = t->root;
- /* some sort of inorder traversal */
+ /* some sort of postorder traversal */
/* root node is written out last */
while (top >= 0) {
@@ -618,15 +618,13 @@
if (s[top].sn->level > 0) { /* this is an internal node in the tree */
for (i = s[top].branch_id; i < t->nodecard; i++) {
s[top].pos[i] = 0;
- if (n->branch[i].child > 0) {
+ if (n->branch[i].child != NULL) {
s[top++].branch_id = i + 1;
s[top].sn = n->branch[i].child;
s[top].branch_id = 0;
writeout = 0;
break;
- else if (n->branch[i].child < 0)
- G_fatal_error("corrupt spatial index");
if (writeout) {
/* nothing else found, ready to write out */
@@ -682,7 +680,6 @@
int i, j, writeout;
struct spidxstack
- struct Node *node[MAXCARD]; /* pointer to already loaded child node */
off_t childpos[MAXCARD];
off_t pos; /* file position of child node */
struct Node sn; /* stack node */
@@ -702,11 +699,18 @@
for (j = 0; j < MAXCARD; j++) {
dig__fread_port_D(s[top].sn.branch[j].rect.boundary, NUMSIDES, fp);
dig__fread_port_O(&(s[top].childpos[j]), 1, fp, off_t_size);
+ if (s[top].sn.level == 0 && s[top].childpos[j]) { /* leaf node */
+ s[top].sn.branch[j].child =
+ (struct Node *)s[top].childpos[j];
+ else {
+ s[top].sn.branch[j].child = NULL;
while (top >= 0) {
@@ -714,7 +718,6 @@
writeout = 1;
if (s[top].sn.level > 0) { /* this is an internal node in the tree */
- s[top].sn.branch[i].child = NULL;
if (s[top].childpos[i] > 0) {
s[top].pos = last->childpos[i];
@@ -762,7 +765,7 @@
top--;
/* update child of parent node */
if (top >= 0) {
- s[top].node[s[top].branch_id - 1] = newnode;
+ s[top].sn.branch[s[top].branch_id - 1].child = newnode;
