[GRASS-SVN] r38624 - grass/branches/develbranch_6/vector/v.buffer2
svn_grass at osgeo.org
Thu Aug 6 04:45:46 EDT 2009
Author: hamish
Date: 2009-08-06 04:45:45 -0400 (Thu, 06 Aug 2009)
New Revision: 38624
grass/branches/develbranch_6/vector/v.buffer2/main.c
+missing guisections
Modified: grass/branches/develbranch_6/vector/v.buffer2/main.c
--- grass/branches/develbranch_6/vector/v.buffer2/main.c 2009-08-06 07:47:27 UTC (rev 38623)
+++ grass/branches/develbranch_6/vector/v.buffer2/main.c 2009-08-06 08:45:45 UTC (rev 38624)
@@ -180,6 +180,7 @@
angle_opt->required = NO;
angle_opt->answer = "0";
angle_opt->description = _("Angle of major axis in degrees");
+ angle_opt->guisection = _("Distance");
bufcol_opt = G_define_standard_option(G_OPT_COLUMN);
bufcol_opt->key = "bufcolumn";
@@ -193,6 +194,7 @@
scale_opt->required = NO;
scale_opt->answer = "1.0";
scale_opt->description = _("Scaling factor for attribute column values");
+ scale_opt->guisection = _("Distance");
tol_opt = G_define_option();
tol_opt->key = "tolerance";
