[GRASS-SVN] r38643 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Sat Aug 8 06:37:01 EDT 2009
Author: mmetz
Date: 2009-08-08 06:37:01 -0400 (Sat, 08 Aug 2009)
New Revision: 38643
grass/trunk/lib/vector/diglib/spindex_rw.c
breaking backwards compatibility, sorry
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c 2009-08-08 10:13:17 UTC (rev 38642)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c 2009-08-08 10:37:01 UTC (rev 38643)
@@ -309,6 +309,16 @@
" Consider to rebuild topology or upgrade GRASS."),
ptr->spidx_Version_Major, ptr->spidx_Version_Minor);
+ if (ptr->spidx_Version_Major < GV_SIDX_VER_MAJOR ||
+ (ptr->spidx_Version_Major == GV_SIDX_VER_MAJOR &&
+ ptr->spidx_Version_Minor < GV_SIDX_VER_MINOR)) {
+ /* The file was created by GRASS library with lower version than this one */
+ G_fatal_error(_("Spatial index format version %d.%d is not "
+ "supported by this release."
+ " Please rebuild topology."),
+ ptr->spidx_Version_Major, ptr->spidx_Version_Minor);
+ return (-1);
dig_init_portable(&(ptr->spidx_port), byte_order);
dig_set_cur_port(&(ptr->spidx_port));
