[GRASS-SVN] r38644 - grass/trunk/vector/v.info
svn_grass at osgeo.org
Sat Aug 8 07:47:29 EDT 2009
Author: mmetz
Date: 2009-08-08 07:47:28 -0400 (Sat, 08 Aug 2009)
New Revision: 38644
grass/trunk/vector/v.info/main.c
grass/trunk/vector/v.info/v.info.html
v.info support for level 1 (no topology)
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c 2009-08-08 10:37:01 UTC (rev 38643)
+++ grass/trunk/vector/v.info/main.c 2009-08-08 11:47:28 UTC (rev 38644)
@@ -37,13 +37,13 @@
void format_double(double, char *);
+int level_one_info(struct Map_info *);
int main(int argc, char *argv[])
struct GModule *module;
struct Option *in_opt, *fieldopt;
- struct Flag *histf, *columns, *gflag, *tflag, *mflag;
+ struct Flag *histf, *columns, *gflag, *tflag, *mflag, *lflag;
struct Map_info Map;
struct bound_box box;
char line[200], buf[1001];
@@ -97,11 +97,27 @@
tflag->description = _("Print topology information only");
tflag->guisection = _("Print");
+ lflag = G_define_flag();
+ lflag->key = 'l';
+ lflag->description = _("Open Vector without topology (level 1)");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- Vect_set_open_level(2); /* topology required */
- Vect_open_old_head(&Map, in_opt->answer, "");
+ if (lflag->answer) {
+ Vect_set_open_level(1); /* no topology */
+ tflag->answer = 0;
+ else
+ Vect_set_open_level(2); /* topology requested */
+ Vect_open_old(&Map, in_opt->answer, "");
+ level_one_info(&Map);
+ else
+ Vect_open_old_head(&Map, in_opt->answer, "");
with_z = Vect_is_3d(&Map);
if (histf->answer) {
@@ -253,7 +269,7 @@
printline(line);
- if (Vect_level(&Map) > 1) {
+ if (Vect_level(&Map) > 0) {
printline("");
sprintf(line,
_(" Number of points: %-9ld Number of areas: %-9ld"),
@@ -283,10 +299,6 @@
(long)Vect_get_num_dblinks(&Map));
printline(line);
- else { /* should not be reached */
- sprintf(line, _(" No topology present"));
- printline(line);
printline("");
/* this differs from r.info in that proj info IS taken from the map here, not the location settings */
@@ -343,3 +355,88 @@
sprintf(buf, "%.8f", value);
G_trim_decimal(buf);
+/* code taken from Vect_build_nat() */
+int level_one_info(struct Map_info *Map)
+ struct Plus_head *plus;
+ int i, type, first = 1;
+ off_t offset;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ struct bound_box box;
+ int n_primitives, n_points, n_lines, n_boundaries, n_centroids, n_kernels;
+ G_debug(1, "Count vector objects for level 1");
+ plus = &(Map->plus);
+ n_primitives = n_points = n_lines = n_boundaries = n_centroids = n_kernels = 0;
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ Vect_rewind(Map);
+ /* G_message(_("Registering primitives...")); */
+ i = 1;
+ while (1) {
+ /* register line */
+ type = Vect_read_next_line(Map, Points, Cats);
+ /* Note: check for dead lines is not needed, because they are skipped by V1_read_next_line_nat() */
+ if (type == -1) {
+ G_warning(_("Unable to read vector map"));
+ return 0;
+ else if (type == -2) {
+ break;
+ /* count features */
+ n_primitives++;
+ if (type & GV_POINT) /* probably most common */
+ n_points++;
+ else if (type & GV_LINE)
+ n_lines++;
+ else if (type & GV_BOUNDARY)
+ n_boundaries++;
+ else if (type & GV_CENTROID)
+ n_centroids++;
+ else if (type & GV_KERNEL)
+ n_kernels++;
+ offset = Map->head.last_offset;
+ G_debug(3, "Register line: offset = %lu", (unsigned long)offset);
+ dig_line_box(Points, &box);
+ if (first == 1) {
+ Vect_box_copy(&(plus->box), &box);
+ first = 0;
+ else
+ Vect_box_extend(&(plus->box), &box);
+ /* can't print progress, unfortunately */
+ if (G_verbose() > G_verbose_min() && i % 1000 == 0) {
+ if (format == G_INFO_FORMAT_PLAIN)
+ fprintf(stderr, "%d..", i);
+ else
+ fprintf(stderr, "%11d\b\b\b\b\b\b\b\b\b\b\b", i);
+ i++;
+ /* save result in plus */
+ plus->n_lines = n_primitives;
+ plus->n_plines = n_points;
+ plus->n_llines = n_lines;
+ plus->n_blines = n_boundaries;
+ plus->n_clines = n_centroids;
+ plus->n_klines = n_kernels;
+ return 1;
Modified: grass/trunk/vector/v.info/v.info.html
--- grass/trunk/vector/v.info/v.info.html 2009-08-08 10:37:01 UTC (rev 38643)
+++ grass/trunk/vector/v.info/v.info.html 2009-08-08 11:47:28 UTC (rev 38644)
@@ -1,7 +1,11 @@
<h2>DESCRIPTION</h2>
<em>v.info</em> reports some basic information about a
-user-specified vector map layer and the topology status.
+user-specified vector map layer and the topology status.
+<p>
+Vector are opened without topology on level 1 when the <b>-l</b> flag is
+used. With the <b>-l</b> flag set, vector map extends and number of
+features need to be counted on the fly which may take some time.
<h2>EXAMPLE</h2>
