[GRASS-SVN] r38645 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Sat Aug 8 14:50:46 EDT 2009
Author: mmetz
Date: 2009-08-08 14:50:46 -0400 (Sat, 08 Aug 2009)
New Revision: 38645
grass/trunk/lib/vector/diglib/spindex_rw.c
read sidx: adjusted order of checks
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c 2009-08-08 11:47:28 UTC (rev 38644)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c 2009-08-08 18:50:46 UTC (rev 38645)
@@ -276,12 +276,6 @@
byte_order = buf[4];
ptr->spidx_port.off_t_size = buf[5];
- if (ptr->spidx_port.off_t_size > (int)sizeof(off_t)) {
- G_fatal_error("Spatial index was written with LFS but this "
- "GRASS version does not support LFS. "
- "Try to rebuild topology or upgrade GRASS.");
G_debug(2,
"Spidx header: file version %d.%d , supported from GRASS version %d.%d",
ptr->spidx_Version_Major, ptr->spidx_Version_Minor,
@@ -320,6 +314,13 @@
return (-1);
+ /* can this library read the sidx file ? */
+ if (ptr->spidx_port.off_t_size > (int)sizeof(off_t)) {
+ G_fatal_error("Spatial index was written with LFS but this "
+ "GRASS version does not support LFS. "
+ "Please get a GRASS version with LFS support.");
dig_init_portable(&(ptr->spidx_port), byte_order);
dig_set_cur_port(&(ptr->spidx_port));
