[GRASS-SVN] r38678 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Tue Aug 11 06:22:35 EDT 2009
Author: aghisla
Date: 2009-08-11 06:22:35 -0400 (Tue, 11 Aug 2009)
New Revision: 38678
grass-addons/vector/v.krige/v.krige.py
new option: output variance map [for markus]
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-08-11 09:51:40 UTC (rev 38677)
+++ grass-addons/vector/v.krige/v.krige.py 2009-08-11 10:22:35 UTC (rev 38678)
@@ -89,6 +89,14 @@
#% description: Automatically fixed if not set
#% required : no
#%end
+#%option
+#% key: output_var
+#% type: string
+#% gisprompt: new,cell,raster
+#% label: Name for output variance raster map
+#% description: If omitted, will be <input name>_kriging_var
+#% required : no
+#%end
import os, sys
from tempfile import gettempdir
@@ -229,7 +237,7 @@
robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
def Run(self, input, column, output, package, sill, nugget, range, logger, \
- overwrite, model, block, **kwargs):
+ overwrite, model, block, output_var, **kwargs):
""" Wrapper for all functions above. """
logger.message(_("Importing data..."))
@@ -258,10 +266,11 @@
column='var1.pred',
name = output,
- self.ExportMap(map = KrigingResult,
- column='var1.var',
- name = output + "_var",
- overwrite = overwrite)
+ if output_var is not '':
+ self.ExportMap(map = KrigingResult,
+ column='var1.var',
+ name = output_var,
+ overwrite = overwrite)
class KrigingPanel(wx.Panel):
""" Main panel. Contains all widgets except Menus and Statusbar. """
@@ -334,11 +343,23 @@
mapsets = [grass.gisenv()['MAPSET']])
OutputParameters.Add(item=self.OutputMapName, flag=wx.EXPAND | wx.ALL,
pos = (0, 1))
+ self.VarianceRasterCheckbox = wx.CheckBox(self, id=wx.ID_ANY, label=_("Export variance map as well: "))
+ self.VarianceRasterCheckbox.SetValue(state = True)
+ OutputParameters.Add(item = self.VarianceRasterCheckbox,
+ flag = wx.ALIGN_CENTER_VERTICAL,
+ pos = (1, 0))
+ self.OutputVarianceMapName = gselect.Select(parent = self, id = wx.ID_ANY,
+ type = 'raster',
+ mapsets = [grass.gisenv()['MAPSET']])
+ self.VarianceRasterCheckbox.Bind(wx.EVT_CHECKBOX, self.OnVarianceCBChecked)
+ OutputParameters.Add(item=self.OutputVarianceMapName, flag=wx.EXPAND | wx.ALL,
+ pos = (1, 1))
self.OverwriteCheckBox = wx.CheckBox(self, id=wx.ID_ANY,
label=_("Allow output files to overwrite existing files"))
self.OverwriteCheckBox.SetValue(state = False)
OutputParameters.Add(item = self.OverwriteCheckBox,
- pos = (1, 0), span = (1, 2))
+ pos = (2, 0), span = (1, 2))
OutputSizer.Add(OutputParameters, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
@@ -392,8 +413,10 @@
if self.InputDataColumn.GetSelection() is not -1:
self.OutputMapName.SetValue(MapName.split("@")[0]+"_kriging")
+ self.OutputVarianceMapName.SetValue(MapName.split("@")[0]+"_kriging_var")
else:
self.OutputMapName.SetValue('')
+ self.OutputVarianceMapName.SetValue('')
def OnRunButton(self,event):
""" Execute R analysis. """
@@ -424,6 +447,8 @@
command.append("block=" + '%s' % SelectedPanel.BlockSpinBox.GetValue())
if self.OverwriteCheckBox.IsChecked():
command.append("--overwrite")
+ if self.VarianceRasterCheckbox.IsChecked():
+ command.append("output_var=" + self.OutputVarianceMapName.GetValue())
print command
Command = command # store it in global variable
@@ -432,6 +457,9 @@
#@FIXME: it runs the command as a NEW instance. Reimports data, recalculates variogram fit..
#otherwise I can use Controller() and mimic RunCmd behaviour.
self.goutput.RunCmd(command, switchPage = True)
+ def OnVarianceCBChecked(self, event):
+ self.OutputVarianceMapName.Enable(event.IsChecked())
class KrigingModule(wx.Frame):
""" Kriging module for GRASS GIS. Depends on R and its packages gstat and geoR. """
@@ -654,6 +682,8 @@
# check for output map with same name. g.parser can't handle this, afaik.
if grass.find_file(options['output'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None:
grass.fatal(_("option: <output>: Raster map already exists."))
+ if options['output_var'] is not '' and (grass.find_file(options['output_var'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None):
+ grass.fatal(_("option: <output>: Variance raster map already exists."))
if options['model'] is '':
try:
@@ -673,6 +703,7 @@
sill = options['sill'],
nugget = options['nugget'],
range = options['range'],
+ output_var = options['output_var'],
logger = grass)
if __name__ == '__main__':
