[GRASS-SVN] r38679 - grass-addons/vector/v.krige
Tue Aug 11 06:31:34 EDT 2009
Author: neteler
Date: 2009-08-11 06:31:33 -0400 (Tue, 11 Aug 2009)
New Revision: 38679
   grass-addons/vector/v.krige/description.html
header/footer not needed (autogenerated during installation)
Modified: grass-addons/vector/v.krige/description.html
--- grass-addons/vector/v.krige/description.html	2009-08-11 10:22:35 UTC (rev 38678)
+++ grass-addons/vector/v.krige/description.html	2009-08-11 10:31:33 UTC (rev 38679)
@@ -1,52 +1,3 @@
-<h2>NAME</h2>
-<em><b>v.krige.py</b></em>  - Performs ordinary kriging.
-<h2>KEYWORDS</h2>
-kriging
-<h2>SYNOPSIS</h2>
-<b>v.krige.py</b><br>
-<b>v.krige.py help</b><br>
-<b>v.krige.py</b> [-<b>o</b>] <b>input</b>=<em>string</em> <b>column</b>=<em>string</em>  [<b>output</b>=<em>string</em>]   [<b>package</b>=<em>string</em>]   [<b>model</b>=<em>string</em>[,<i>string</i>,...]]   [<b>range</b>=<em>integer</em>]   [<b>nugget</b>=<em>integer</em>]   [<b>sill</b>=<em>integer</em>]   [--<b>verbose</b>]  [--<b>quiet</b>]
-<h3>Flags:</h3>
-<DL>
-<DT><b>-o</b></DT>
-<DD>Overwrite output map with same name</DD>
-<DT><b>--verbose</b></DT>
-<DD>Verbose module output</DD>
-<DT><b>--quiet</b></DT>
-<DD>Quiet module output</DD>
-</DL>
-<h3>Parameters:</h3>
-<DL>
-<DT><b>input</b>=<em>string</em></DT>
-<DD>Name of point vector map containing sample data.</DD>
-<DT><b>column</b>=<em>string</em></DT>
-<DD>Column with numerical value to be interpolated</DD>
-<DT><b>output</b>=<em>string</em></DT>
-<DD>Name of output map. If omitted, will be &lt;input name&gt;_kriging</DD>
-<DT><b>package</b>=<em>string</em></DT>
-<DD>R package to use. Choices: gstat, geor</DD>
-<DD>Options: <em>gstat, geor</em></DD>
-<DD>Default: <em>gstat</em></DD>
-<DT><b>model</b>=<em>string[,<i>string</i>,...]</em></DT>
-<DD>Variogram model(s). Leave empty to</DD>
-<DD>Options: <em>Exp,Sph,Gau,Mat,Lin</em></DD>
-<DT><b>range</b>=<em>integer</em></DT>
-<DD>Range value. Automatically fixed if not set</DD>
-<DT><b>nugget</b>=<em>integer</em></DT>
-<DD>Nugget value. Automatically fixed if not set</DD>
-<DT><b>sill</b>=<em>integer</em></DT>
-<DD>Sill value. Automatically fixed if not set</DD>
 <h2>DESCRIPTION</h2>
 <i>v.krige</i> allows to perform kriging operations in GRASS environment,
 using R software functions in background.
@@ -163,5 +114,3 @@
 Anne Ghisla, Google Summer of Code 2009
-<p>
-<i>Last changed: $Date$</i>
