[GRASS-SVN] r38744 - grass/trunk/lib/cairodriver
svn_grass at osgeo.org
Sat Aug 15 12:56:58 EDT 2009
Author: neteler
Date: 2009-08-15 12:56:57 -0400 (Sat, 15 Aug 2009)
New Revision: 38744
grass/trunk/lib/cairodriver/cairodriver.html
some cleanup; GRASS_PNGFILE for pdf etc remains confusing
Modified: grass/trunk/lib/cairodriver/cairodriver.html
--- grass/trunk/lib/cairodriver/cairodriver.html 2009-08-15 16:15:30 UTC (rev 38743)
+++ grass/trunk/lib/cairodriver/cairodriver.html 2009-08-15 16:56:57 UTC (rev 38744)
@@ -95,54 +95,31 @@
<H3>Examples</H3>
-Example using the driver directly (bash-syntax):
+Example using the driver to generate a PNG file (bash-syntax):
<div class="code"><PRE>
export GRASS_WIDTH=800
export GRASS_HEIGHT=800
+export GRASS_RENDER_IMMEDIATE=CAIRO
-d.mon start=cairo
d.rast map=elevation.10m
d.vect map=streams width=1 color=blue fcolor=aqua type=area,line
d.vect map=roads width=2
-d.mon stop=cairo
</PRE></div>
-Example using <em><a href="d.out.file.html">d.out.file</a></em>:
+Example using the driver to generate a PDF file (bash-syntax):
-d.mon x0
+export GRASS_PNGFILE=spearfish.pdf
+export GRASS_WIDTH=800
+export GRASS_HEIGHT=800
-d.out.file -c sf_cairo format=png size=800,800
</PRE></div>
-<P>
-A more complicated example using <em><a href="d.out.file.html">d.out.file</a></em>:
-<div class="code"><PRE>
-r.shaded.relief map=elevation.dem
-r.watershed elev=elevation.dem basin=watershed.basin thresh=10000
-d.mon x1
-d.shadedmap rel=elevation.dem.shade drape=watershed.basin bright=30
-d.vect streams color=aqua fcolor=aqua type=area,line
-d.vect roads where="label ~ 'light-duty road'" color=grey
-d.vect roads where="label ~ 'unimproved'" color=orange
-d.vect roads where="label ~ 'secondary highway'" color=100:100:100 width=2
-d.vect roads where="label ~ 'primary highway'" color=50:50:50 width=2
-d.vect railroads col=red width=2
-d.vect roads where="label = 'interstate'" color=black width=3
-d.vect archsites icon=basic/star size=25 fcolor=yellow
-d.font Andale_Mono
-echo "Spearfish, SD" | d.text color=black at=28,53 -b
-d.out.file -c sf_cairo2 format=png
-</PRE></div>
<H2>NOTES</H2>
The driver is still in development. Enable it by specifying
@@ -160,24 +137,17 @@
fall back on rendering a bitmap representation of the image wrapped in
the selected vector format.
-<P>
-Cairo driver output via <em><A HREF="d.out.file.html">d.out.file</A></em>
-is supported via the -c flag.</P>
<h2>SEE ALSO</h2>
<EM>
-<A HREF="htmlmapdriver.html">HTMLMAP driver</A>,
<A HREF="pngdriver.html">PNG driver</A>,
<A HREF="psdriver.html">PostScript driver</A>,
-<A href="xdriver.html">XDRIVER</A>
<BR>
<A HREF="d.frame.html">d.frame</A>,
-<A href="d.mon.html">d.mon</A>,
<A href="d.rast.html">d.rast</A>,
<A href="d.vect.html">d.vect</A>
-<A href="d.out.file.html">d.out.file</A>
</EM>
<H2>AUTHOR</H2>
Lars Ahlzen <<I>lars (at) ahlzen.com</I>><BR>
and the GRASS Development Team.
