[GRASS-SVN] r38745 - in grass/trunk/lib: cairodriver pngdriver
psdriver
svn_grass at osgeo.org
Sat Aug 15 13:05:12 EDT 2009
Author: neteler
Date: 2009-08-15 13:05:12 -0400 (Sat, 15 Aug 2009)
New Revision: 38745
grass/trunk/lib/cairodriver/cairodriver.html
grass/trunk/lib/pngdriver/pngdriver.html
grass/trunk/lib/psdriver/psdriver.html
more cleanup
Modified: grass/trunk/lib/cairodriver/cairodriver.html
--- grass/trunk/lib/cairodriver/cairodriver.html 2009-08-15 16:56:57 UTC (rev 38744)
+++ grass/trunk/lib/cairodriver/cairodriver.html 2009-08-15 17:05:12 UTC (rev 38745)
@@ -139,10 +139,11 @@
<h2>SEE ALSO</h2>
<EM>
+<a href="displaydrivers.html">Display drivers</a>
+<br>
<A HREF="pngdriver.html">PNG driver</A>,
<A HREF="psdriver.html">PostScript driver</A>,
<BR>
-<A HREF="d.frame.html">d.frame</A>,
<A href="d.rast.html">d.rast</A>,
<A href="d.vect.html">d.vect</A>
</EM>
Modified: grass/trunk/lib/pngdriver/pngdriver.html
--- grass/trunk/lib/pngdriver/pngdriver.html 2009-08-15 16:56:57 UTC (rev 38744)
+++ grass/trunk/lib/pngdriver/pngdriver.html 2009-08-15 17:05:12 UTC (rev 38745)
@@ -64,31 +64,17 @@
</UL>
<H3>Example</H3>
-<OL>
- <LI>Define driver settings (here: bash shell syntax)
<DIV class="code"><PRE>
-export GRASS_RENDER_IMMEDIATE=TRUE
+# Define driver settings (here: bash shell syntax)
+export GRASS_RENDER_IMMEDIATE=PNG
export GRASS_TRUECOLOR=TRUE
-</PRE></DIV>
- </LI>
- <LI>Start up the driver
-<DIV class="code"><PRE>
-d.mon start=PNG
-</PRE></DIV>
- </LI>
- <LI>Display raster map and vector polygons
+# Display raster map and vector polygons
d.rast <i>somerastermap</i>
d.vect <i>somevectormap</i> color=red
</PRE></DIV>
- </LI>
- <LI> Stop the driver subsequently. This will write a
- file named <tt>map.png</tt> to be created in your current directory:
-d.mon stop=PNG
-</PRE></DIV>
- </LI>
-</OL>
+This writes a file named <tt>map.png</tt> in your current directory.
<H2>NOTES</H2>
@@ -108,16 +94,13 @@
<h2>SEE ALSO</h2>
<EM>
- <a href="displaydrivers.html">Display drivers</a>
- <br>
- <A HREF="htmlmapdriver.html">HTMLMAP driver</A>,
- <A HREF="psdriver.html">PostScript driver</A>,
- <A href="xdriver.html">XDRIVER</A>
- <BR>
- <A HREF="d.frame.html">d.frame</A>,
- <A href="d.mon.html">d.mon</A>,
- <A href="d.rast.html">d.rast</A>,
- <A href="d.vect.html">d.vect</A>
+<br>
+<A HREF="cairodriver.html">CAIRO driver</A>,
+<A HREF="psdriver.html">PostScript driver</A>,
+<BR>
+<A href="d.rast.html">d.rast</A>,
+<A href="d.vect.html">d.vect</A>
</EM>
<H2>AUTHOR</H2>
Modified: grass/trunk/lib/psdriver/psdriver.html
--- grass/trunk/lib/psdriver/psdriver.html 2009-08-15 16:56:57 UTC (rev 38744)
+++ grass/trunk/lib/psdriver/psdriver.html 2009-08-15 17:05:12 UTC (rev 38745)
@@ -63,25 +63,17 @@
</UL>
<H3>Example</H3>
-<OL>
-d.mon start=PS
-</PRE></DIV>
- </LI>
+export GRASS_RENDER_IMMEDIATE=PS
+export GRASS_TRUECOLOR=TRUE
-d.vect map=<i>somevectormap</i> color=red
+d.vect <i>somevectormap</i> color=red
</PRE></DIV>
- </LI>
- file named <tt>map.ps</tt> to be created in your current directory:
-d.mon stop=PS
-</PRE></DIV>
- </LI>
-</OL>
+This writes a file named <tt>map.ps</tt> in your current directory.
<H2>NOTES</H2>
@@ -100,17 +92,13 @@
<h2>SEE ALSO</h2>
<EM>
- <br>
- <A HREF="pngdriver.html">PNG driver</A>,
- <BR>
- <A href="d.out.file.html">d.out.file</A>,
+<br>
+<A HREF="pngdriver.html">PNG driver</A>
+<BR>
</EM>
<H2>AUTHOR</H2>
