[GRASS-SVN] r38765 - grass/branches/develbranch_6/raster/r.li/r.li.daemon
Mon Aug 17 02:53:55 EDT 2009
Author: hamish
Date: 2009-08-17 02:53:55 -0400 (Mon, 17 Aug 2009)
New Revision: 38765
   grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
minor clean
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c	2009-08-17 05:52:05 UTC (rev 38764)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c	2009-08-17 06:53:55 UTC (rev 38765)
@@ -102,7 +102,7 @@
     /* TODO: check if this path is portable */
     sprintf(pathSetup, "%s/.r.li/history/%s", G_home(), file);
-    G_debug(1, "r.li.daemon pathSetup: %s", pathSetup);
+    G_debug(1, "r.li.daemon pathSetup: [%s]", pathSetup);
     parsed = parseSetup(pathSetup, l, g, raster);
@@ -294,43 +294,51 @@
     int sf_x, sf_y, sf_rl, sf_cl;
     int size;
+    /* TODO: if present, strip away G_home()/.r.li/history/ path from string */
+    /*  ? if(strncmp(G_rc_path(), path, strlen(G_rc_path()) ) == 0)
+	?     path += strlen(G_rc_path());
     if (stat(path, &s) != 0)
-	G_fatal_error(_("Cannot make stat of %s configuration file"), path);
+	G_fatal_error(_("Cannot find configuration file <%s>"), path);
     size = s.st_size * sizeof(char);
     buf = G_malloc(size);
     setup = open(path, O_RDONLY, 0755);
     if (setup == -1)
 	G_fatal_error(_("Cannot read setup file"));
     letti = read(setup, buf, s.st_size);
     if (letti < s.st_size)
     token = strtok(buf, " ");
     if (strcmp("SAMPLINGFRAME", token) != 0)
-	G_fatal_error(_("Illegal configuration file"));
+	G_fatal_error(_("Unable to parse configuration file"));
     rel_x = atof(strtok(NULL, "|"));
     rel_y = atof(strtok(NULL, "|"));
     rel_rl = atof(strtok(NULL, "|"));
     rel_cl = atof(strtok(NULL, "\n"));
-    /*finding raster map */
+    /* find raster map */
     mapset = G_find_cell(raster, "");
     if (G_get_cellhd(raster, mapset, &cellhd) == -1)
 	G_fatal_error(_("Cannot read raster header file"));
-    /*calculating absolute sampling frame definition */
+    /* calculate absolute sampling frame definition */
     sf_x = (int)rint(cellhd.cols * rel_x);
     sf_y = (int)rint(cellhd.rows * rel_y);
     sf_rl = (int)rint(cellhd.rows * rel_rl);
     sf_cl = (int)rint(cellhd.cols * rel_cl);
-    /*calculating sample frame boundaries */
+    /* calculate sample frame boundaries */
     sf_n = cellhd.north - (cellhd.ns_res * sf_y);
     sf_s = sf_n - (cellhd.ns_res * sf_rl);
     sf_w = cellhd.west + (cellhd.ew_res * sf_x);
     sf_e = sf_w + (cellhd.ew_res * sf_cl);
-    /* parsing configuration file */
+    /* parse configuration file */
     token = strtok(NULL, " ");
     if (strcmp("SAMPLEAREA", token) == 0) {
@@ -376,10 +384,12 @@
 		aid++;
 		insertNode(l, m);
-	while ((token = strtok(NULL, " ")) != NULL &&
+	} while ((token = strtok(NULL, " ")) != NULL &&
 	       strcmp(token, "SAMPLEAREA") == 0);
 	close(setup);
 	return toReturn;
     else if (strcmp("MASKEDSAMPLEAREA", token) == 0) {
