[GRASS-SVN] r38766 - grass/trunk/raster/r.li/r.li.daemon
svn_grass at osgeo.org
Mon Aug 17 02:56:51 EDT 2009
Author: hamish
Date: 2009-08-17 02:56:51 -0400 (Mon, 17 Aug 2009)
New Revision: 38766
grass/trunk/raster/r.li/r.li.daemon/daemon.c
minor cleanup (merge from devbr6)
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.c
--- grass/trunk/raster/r.li/r.li.daemon/daemon.c 2009-08-17 06:53:55 UTC (rev 38765)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.c 2009-08-17 06:56:51 UTC (rev 38766)
@@ -305,42 +305,50 @@
int sf_x, sf_y, sf_rl, sf_cl;
int size;
+ /* TODO: if present, strip away G_home()/.r.li/history/ path from string */
+ /* ? if(strncmp(G_rc_path(), path, strlen(G_rc_path()) ) == 0)
+ ? path += strlen(G_rc_path());
if (stat(path, &s) != 0)
- G_fatal_error(_("Cannot make stat of %s configuration file"), path);
+ G_fatal_error(_("Cannot find configuration file <%s>"), path);
size = s.st_size * sizeof(char);
buf = G_malloc(size);
setup = open(path, O_RDONLY, 0755);
if (setup == -1)
G_fatal_error(_("Cannot read setup file"));
letti = read(setup, buf, s.st_size);
if (letti < s.st_size)
token = strtok(buf, " ");
if (strcmp("SAMPLINGFRAME", token) != 0)
- G_fatal_error(_("Illegal configuration file"));
+ G_fatal_error(_("Unable to parse configuration file"));
rel_x = atof(strtok(NULL, "|"));
rel_y = atof(strtok(NULL, "|"));
rel_rl = atof(strtok(NULL, "|"));
rel_cl = atof(strtok(NULL, "\n"));
- /*finding raster map */
+ /* find raster map */
if (Rast_get_cellhd(raster, "", &cellhd) == -1)
G_fatal_error(_("Cannot read raster header file"));
- /*calculating absolute sampling frame definition */
+ /* calculate absolute sampling frame definition */
sf_x = (int)rint(cellhd.cols * rel_x);
sf_y = (int)rint(cellhd.rows * rel_y);
sf_rl = (int)rint(cellhd.rows * rel_rl);
sf_cl = (int)rint(cellhd.cols * rel_cl);
- /*calculating sample frame boundaries */
+ /* calculate sample frame boundaries */
sf_n = cellhd.north - (cellhd.ns_res * sf_y);
sf_s = sf_n - (cellhd.ns_res * sf_rl);
sf_w = cellhd.west + (cellhd.ew_res * sf_x);
sf_e = sf_w + (cellhd.ew_res * sf_cl);
- /* parsing configuration file */
+ /* parse configuration file */
token = strtok(NULL, " ");
if (strcmp("SAMPLEAREA", token) == 0) {
@@ -386,10 +394,12 @@
aid++;
insertNode(l, m);
- while ((token = strtok(NULL, " ")) != NULL &&
+ } while ((token = strtok(NULL, " ")) != NULL &&
strcmp(token, "SAMPLEAREA") == 0);
close(setup);
return toReturn;
else if (strcmp("MASKEDSAMPLEAREA", token) == 0) {
