[GRASS-SVN] r38791 - in grass/trunk: db/db.select
gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Aug 19 04:46:43 EDT 2009
Author: hamish
Date: 2009-08-19 04:46:42 -0400 (Wed, 19 Aug 2009)
New Revision: 38791
grass/trunk/db/db.select/main.c
grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
verbose confirmation; fix Verify (merge from devbr6)
Modified: grass/trunk/db/db.select/main.c
--- grass/trunk/db/db.select/main.c 2009-08-19 08:39:25 UTC (rev 38790)
+++ grass/trunk/db/db.select/main.c 2009-08-19 08:46:42 UTC (rev 38791)
@@ -84,6 +84,9 @@
+ if(parms.test_only)
+ G_verbose_message(_("Test %s."), stat ? _("failed") : _("succeeded"));
db_close_database(driver);
db_shutdown_driver(driver);
@@ -257,6 +260,7 @@
parms.h = 1;
else
parms.h = 0;
parms.test_only = flag_test->answer;
if (!parms.fs)
Modified: grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
--- grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py 2009-08-19 08:39:25 UTC (rev 38790)
+++ grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py 2009-08-19 08:46:42 UTC (rev 38791)
@@ -320,7 +320,7 @@
pass
def OnVerify(self,event):
if self.text_sql.GetValue():
- if os.system("""!db.select -t driver=%s database="%s" sql="SELECT * FROM %s WHERE %s" """ % \
+ if os.system("""db.select -t --verbose driver=%s database="%s" sql="SELECT * FROM %s WHERE %s" """ % \
(self.driver, self.database,self.tablename,
self.text_sql.GetValue().strip().replace("\n"," "))):
# FIXME: LOG
