[GRASS-SVN] r38792 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Aug 19 06:53:01 EDT 2009
Author: hamish
Date: 2009-08-19 06:52:59 -0400 (Wed, 19 Aug 2009)
New Revision: 38792
grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py
fix backwards >=,> button labels;
use RunCommand instead of os.system();
Verify messages to Command Output window;
add some debug comments about broken curson posn
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py 2009-08-19 08:46:42 UTC (rev 38791)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/sqlbuilder.py 2009-08-19 10:52:59 UTC (rev 38792)
@@ -11,9 +11,10 @@
AUTHOR(S): GRASS Development Team
Original author: Jachym Cepicky <jachym.cepicky gmail.com>
- Various updates: Martin Landa <landa.martin gmail.com>
+ Various updates: Martin Landa <landa.martin gmail.com>,
+ Hamish Bowman <hamish_b yahoo com>
-COPYRIGHT: (C) 2007 by the GRASS Development Team
+COPYRIGHT: (C) 2007-2009 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -50,15 +51,24 @@
self.vectmap = vectmap
if not "@" in self.vectmap:
self.vectmap = self.vectmap + "@" + grass.gisenv()['MAPSET']
self.mapname, self.mapset = self.vectmap.split("@")
- self.layer,self.tablename, self.column, self.database, self.driver =\
- os.popen("v.db.connect -g fs=\"|\" map=%s" %\
- (self.vectmap)).readlines()[0].strip().split("|")
- self.qtype = qtype # type of the uqery: SELECT, UPDATE, DELETE, ...
- self.column_names = [] # array with column names
+ #FIXME: pass layer number to v.db.connect ???
+ ret = gcmd.RunCommand('v.db.connect',
+ quiet = True,
+ read = True,
+ flags = 'g',
+ fs = '|',
+ map = self.vectmap)
+ for line in ret.splitlines():
+ self.layer,self.tablename, self.column, self.database, self.driver =\
+ line.strip().split("|")
+ self.qtype = qtype # type of the uqery: SELECT, UPDATE, DELETE, ...
+ self.column_names = [] # array with column names
self.columns = {} # array with colum properties
- self.colvalues = [] # arrya with uniqe values in selected column
+ self.colvalues = [] # array with uniqe values in selected column
self.heading = ""
self.parent = parent
@@ -86,10 +96,10 @@
self.btn_is = wx.Button(self, -1, "=")
self.btn_isnot = wx.Button(self, -1, "!=")
self.btn_like = wx.Button(self, -1, "LIKE")
- self.btn_gt = wx.Button(self, -1, ">=")
- self.btn_gtis = wx.Button(self, -1, ">")
- self.btn_lt = wx.Button(self, -1, "<=")
- self.btn_ltis = wx.Button(self, -1, "<")
+ self.btn_gt = wx.Button(self, -1, ">")
+ self.btn_gtis = wx.Button(self, -1, ">=")
+ self.btn_lt = wx.Button(self, -1, "<")
+ self.btn_ltis = wx.Button(self, -1, "<=")
self.btn_or = wx.Button(self, -1, "OR")
self.btn_not = wx.Button(self, -1, "NOT")
self.btn_and = wx.Button(self, -1, "AND")
@@ -249,15 +259,24 @@
self.list_values.Clear()
column = self.list_columns.GetString(idx)
i = 0
- for line in os.popen("db.select -c database=\"%s\" driver=%s sql=\"SELECT %s FROM %s\"" %\
- (self.database,self.driver,column,self.tablename)):
- if justsample and i < 256 or \
- not justsample:
- self.list_values.Insert(line.strip(),0)
- else:
- break
- i += 1
+ querystring = "SELECT %s FROM %s" % (column, self.tablename)
+ ret = gcmd.RunCommand('db.select',
+ read = True,
+ quiet = True,
+ flags = 'c',
+ database = self.database,
+ driver = self.driver,
+ sql = querystring)
+ if justsample and i < 256 or \
+ not justsample:
+ self.list_values.Insert(line.strip(),0)
+ else:
+ break
+ i += 1
def GetSampleValues(self,event):
self.GetUniqueValues(None,True)
@@ -277,8 +296,6 @@
self.__addSomething(value)
def AddMark(self,event):
if event.GetId() == self.btn_is.GetId(): mark = "="
elif event.GetId() == self.btn_isnot.GetId(): mark = "!="
elif event.GetId() == self.btn_like.GetId(): mark = "LIKE"
@@ -306,11 +323,20 @@
newsqlstr += " "
except:
pass
newsqlstr += what
newsqlstr += " "+sqlstr[position:]
self.text_sql.SetValue(newsqlstr)
+ # FIXME: cursor position is messed up
+ # see also http://trac.wxwidgets.org/ticket/10051
+ #DEBUG: print "before: %d" % (position)
self.text_sql.SetInsertionPoint(position)
+ #? self.text_sql.SetInsertionPoint(position+len(what))
+ #? self.text_sql.SetInsertionPointEnd()
+ #DEBUG: print "len(what)=%d" % (len(what))
+ #DEBUG: print "after: %d" % (self.text_sql.GetPosition()[0])
+ #DEBUG: print " "
def OnApply(self,event):
if self.parent:
@@ -318,13 +344,25 @@
self.parent.text_query.SetValue= self.text_sql.GetValue().strip().replace("\n"," ")
except:
pass
def OnVerify(self,event):
if self.text_sql.GetValue():
- if os.system("""db.select -t --verbose driver=%s database="%s" sql="SELECT * FROM %s WHERE %s" """ % \
- (self.driver, self.database,self.tablename,
- self.text_sql.GetValue().strip().replace("\n"," "))):
- # FIXME: LOG
- # print self.text_sql.GetValue().strip().replace("\n"," "), "not correct!"
+ querystring = "SELECT * FROM %s WHERE %s" % \
+ (self.tablename,
+ self.text_sql.GetValue().strip().replace("\n"," "))
+ # FIXME: LOG
+ # print self.text_sql.GetValue().strip().replace("\n"," "), "not correct!"
+ print "Testing [%s] ..." % (querystring)
+ ret, msg = gcmd.RunCommand('db.select',
+ getErrorMsg = True,
+ verbose = True,
+ flags = 't',
+ print msg, " "
+ if ret == 0:
pass
def OnClear(self, event):
