[GRASS-SVN] r38809 - grass/trunk/lib/external
Fri Aug 21 02:48:14 EDT 2009
Author: hamish
Date: 2009-08-21 02:48:13 -0400 (Fri, 21 Aug 2009)
New Revision: 38809
Added:
   grass/trunk/lib/external/README.license
add README about what can be found here
Added: grass/trunk/lib/external/README.license
--- grass/trunk/lib/external/README.license	                        (rev 0)
+++ grass/trunk/lib/external/README.license	2009-08-21 06:48:13 UTC (rev 38809)
@@ -0,0 +1,16 @@
+In the following directories you will find code which was not
+written by The GRASS Development Team.
+Parts of GRASS are not copyright by The GRASS Development Team.
+The original authors hold the copyrights and you have to abide
+to their licensing terms where noted.
+(Keep in mind that code linking into GRASS can only be distributed
+if compatible with the GPL.)
+Specifically the source code below this directory is not necessarily
+licensed under the GPL. Check the READMEs and source code header
+comments carefully.
Property changes on: grass/trunk/lib/external/README.license
___________________________________________________________________
Added: svn:mime-type
   + text/plain
Added: svn:eol-style
   + native
