[GRASS-SVN] r38810 - grass/branches/develbranch_6/lib/external
svn_grass at osgeo.org
Fri Aug 21 02:51:14 EDT 2009
Author: hamish
Date: 2009-08-21 02:51:14 -0400 (Fri, 21 Aug 2009)
New Revision: 38810
Added:
grass/branches/develbranch_6/lib/external/README.license
add README about what can be found here (merge from trunk)
Copied: grass/branches/develbranch_6/lib/external/README.license (from rev 38809, grass/trunk/lib/external/README.license)
--- grass/branches/develbranch_6/lib/external/README.license (rev 0)
+++ grass/branches/develbranch_6/lib/external/README.license 2009-08-21 06:51:14 UTC (rev 38810)
@@ -0,0 +1,16 @@
+In the following directories you will find code which was not
+written by The GRASS Development Team.
+Parts of GRASS are not copyright by The GRASS Development Team.
+The original authors hold the copyrights and you have to abide
+to their licensing terms where noted.
+(Keep in mind that code linking into GRASS can only be distributed
+if compatible with the GPL.)
+Specifically the source code below this directory is not necessarily
+licensed under the GPL. Check the READMEs and source code header
+comments carefully.
