[GRASS-SVN] r39882 - grass/trunk/vector/v.out.dxf
svn_grass at osgeo.org
Thu Dec 3 14:11:51 EST 2009
Author: martinl
Date: 2009-12-03 14:11:50 -0500 (Thu, 03 Dec 2009)
New Revision: 39882
grass/trunk/vector/v.out.dxf/main.c
v.out.dxf: OGR support (read access)
Modified: grass/trunk/vector/v.out.dxf/main.c
--- grass/trunk/vector/v.out.dxf/main.c 2009-12-03 18:50:41 UTC (rev 39881)
+++ grass/trunk/vector/v.out.dxf/main.c 2009-12-03 19:11:50 UTC (rev 39882)
@@ -1,26 +1,32 @@
* MODULE: v.out.dxf
* AUTHOR(S): Chuck Ehlschlaeger
* Update to GRASS 5.7 by Radim Blazek
+ * OGR support by Martin Landa <landa.martin gmail.com>
- * PURPOSE: Convert vector maps into DXF files. This program is a
- * small demo and not to be taken seriously.
+ * PURPOSE: Convert vector maps into DXF files.
* COPYRIGHT: (C) 1989-2006 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
#include <grass/dbmi.h>
#include <grass/vector.h>
#include <grass/glocale.h>
#include "global.h"
FILE *dxf_fp;
@@ -32,7 +38,7 @@
static double do_limits(struct Map_info *);
static int make_layername(void);
-static int add_plines(struct Map_info *, double);
+static int add_plines(struct Map_info *, int, double);
int main(int argc, char *argv[])
@@ -41,7 +47,7 @@
char *dxf_file;
struct Map_info In;
struct GModule *module;
- struct Option *input, *output;
+ struct Option *input, *output, *field;
G_gisinit(argv[0]);
@@ -50,17 +56,15 @@
G_add_keyword(_("vector"));
G_add_keyword(_("export"));
module->description =
- _("Exports GRASS vector map layers to DXF file format.");
+ _("Exports vector map to DXF file format.");
input = G_define_standard_option(G_OPT_V_INPUT);
- output = G_define_option();
- output->key = "output";
- output->type = TYPE_STRING;
+ field = G_define_standard_option(G_OPT_V_FIELD);
+ output = G_define_standard_option(G_OPT_F_OUTPUT);
output->required = YES;
- output->multiple = NO;
- output->gisprompt = "new_file,file,output";
- output->description = _("DXF output file");
+ output->description = _("Name for DXF output file");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -71,14 +75,15 @@
dxf_file = G_store(output->answer);
Vect_set_open_level(2);
- Vect_open_old(&In, input->answer, "");
+ Vect_open_old2(&In, input->answer, "", field->answer);
dxf_open(dxf_file); /* open output */
textsize = do_limits(&In); /* does header in dxf_fp */
make_layername();
dxf_entities();
- nlines = add_plines(&In, textsize); /* puts plines in dxf_fp */
+ nlines = add_plines(&In, Vect_get_field_number(&In, field->answer),
+ textsize); /* puts plines in dxf_fp */
dxf_endsec();
dxf_eof(); /* puts final stuff in dxf_fp, closes file */
@@ -131,9 +136,9 @@
return 0;
-int add_plines(struct Map_info *Map, double textsize)
+int add_plines(struct Map_info *Map, int field, double textsize)
- int nlines, line;
+ int nlines, line, nlines_dxf;
struct line_pnts *Points;
struct line_cats *Cats;
char *layer, *llayer;
@@ -144,14 +149,17 @@
Cats = Vect_new_cats_struct();
nlines = Vect_get_num_lines(Map);
+ nlines_dxf = 0;
for (line = 1; line <= nlines; line++) {
int i, ltype;
G_percent(line, nlines, 2);
ltype = Vect_read_line(Map, Points, Cats, line);
- Vect_cat_get(Cats, 1, &cat);
+ Vect_cat_get(Cats, field, &cat);
+ if (cat < 0)
+ continue;
sprintf(cat_num, "%d", cat);
if (ltype == GV_POINT) {
@@ -185,7 +193,8 @@
dxf_poly_end(layer);
+ nlines_dxf++;
- return nlines;
+ return nlines_dxf;
