[GRASS-SVN] r39883 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Thu Dec 3 14:31:13 EST 2009
Author: martinl
Date: 2009-12-03 14:31:13 -0500 (Thu, 03 Dec 2009)
New Revision: 39883
grass/trunk/vector/v.out.ogr/main.c
v.out.ogr: OGR support (read access)
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2009-12-03 19:11:50 UTC (rev 39882)
+++ grass/trunk/vector/v.out.ogr/main.c 2009-12-03 19:31:13 UTC (rev 39883)
@@ -82,13 +82,12 @@
G_add_keyword(_("ogr"));
module->description =
- _("Converts GRASS vector map to one of the supported OGR vector formats.");
+ _("Converts vector map to one of the supported OGR vector formats.");
/* parse & read options */
parse_args(argc, argv,
&options, &flags);
- field = atoi(options.field->answer);
/* parse dataset creation options */
i = 0;
while (options.dsco->answers[i]) {
@@ -117,7 +116,7 @@
if (!flags.new->answer) {
/* open input vector (topology required) */
Vect_set_open_level(2);
- Vect_open_old(&In, options.input->answer, "");
+ Vect_open_old2(&In, options.input->answer, "", options.field->answer);
if (strcmp(options.type->answer, "auto") == 0) {
G_debug(2, "Automatic type determination.");
@@ -169,6 +168,8 @@
G_fatal_error(_("Unable to determine input map's vector feature type(s)."));
+ field = Vect_get_field_number(&In, options.field->answer);
/* check output feature type */
otype = Vect_option_to_types(options.type);
@@ -821,7 +822,6 @@
/* Summary */
- G_message(_("%d features written"), fout);
if (nocat > 0)
G_warning(_("%d features without category were written"), nocat);
if (noatt > 0)
@@ -838,7 +838,8 @@
G_warning ("%d features of different type skip", fskip);
- G_done_msg(" ");
+ G_done_msg(_("%d features written to <%s> (%s)."), fout,
+ options.layer->answer, options.format->answer);
exit(EXIT_SUCCESS);
