[GRASS-SVN] r39926 - grass/branches/releasebranch_6_4/gui/wxpython
svn_grass at osgeo.org
Sun Dec 6 15:51:29 EST 2009
Author: cmbarton
Date: 2009-12-06 15:51:28 -0500 (Sun, 06 Dec 2009)
New Revision: 39926
grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
Fixed so that commands requiring xterms now run on Mac. The same approach might also work in Linux but I can't test.
Modified: grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
--- grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py 2009-12-06 20:45:02 UTC (rev 39925)
+++ grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py 2009-12-06 20:51:28 UTC (rev 39926)
@@ -990,21 +990,34 @@
# open available xmon
xmon = xmonlist[0]
- cmdlist = ["d.mon","start=%s" % xmon]
- p = gcmd.Command(cmdlist)
# run the command
- runbat = os.path.join(gisbase,'etc','grass-run.bat')
- xtermwrapper = os.path.join(gisbase,'etc','grass-xterm-wrapper')
- grassrun = os.path.join(gisbase,'etc','grass-run.sh')
- command = shlex.split(str(command))
- if platform.system() == 'Windows':
- cmdlist = ["cmd.exe", "/c", 'start "%s"' % runbat, command]
- else:
- cmdlist = [xtermwrapper, '-e "%s"' % grassrun, command]
+ command = ' '.join(command)
+ if sys.platform == "darwin":
+ cmdlist = ['xterm', '-e', 'd.mon', xmon]
+ p = gcmd.Command(cmdlist, wait=False)
+ cmdlist = ['xterm', '-e', command]
+ q = gcmd.Command(cmdlist, wait=False)
+ else:
+ cmdlist = ["d.mon","start=%s" % xmon]
+ p = gcmd.Command(cmdlist)
+ # run the command
+ runbat = os.path.join(gisbase,'etc','grass-run.bat')
+ xtermwrapper = os.path.join(gisbase,'etc','grass-xterm-wrapper')
+ grassrun = os.path.join(gisbase,'etc','grass-run.sh')
+ command = shlex.split(str(command))
+ if platform.system() == 'Windows':
+ cmdlist = ["cmd.exe", "/c", 'start "%s"' % runbat, command]
+ else:
+ cmdlist = [xtermwrapper, '-e "%s"' % grassrun, command]
# reset display mode
os.environ['GRASS_RENDER_IMMEDIATE'] = 'TRUE'
