[GRASS-SVN] r39927 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Dec 6 15:59:04 EST 2009
Author: martinl
Date: 2009-12-06 15:59:03 -0500 (Sun, 06 Dec 2009)
New Revision: 39927
grass/trunk/gui/wxpython/gui_modules/help.py
fix bug introduced in r39922 - menu items are not grass commands,
eval() required
(merge r39925 from devbr6)
Modified: grass/trunk/gui/wxpython/gui_modules/help.py
--- grass/trunk/gui/wxpython/gui_modules/help.py 2009-12-06 20:51:28 UTC (rev 39926)
+++ grass/trunk/gui/wxpython/gui_modules/help.py 2009-12-06 20:59:03 UTC (rev 39927)
@@ -65,7 +65,7 @@
self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
self.dataBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
- label=" %s " % _("Menu tree (double-click to run command)"))
+ label=" %s " % _("Menu tree (double-click to run command)"))
# tree
self.tree = MenuTree(parent = self.panel, data = menudata.Data())
self.tree.Load()
@@ -116,9 +116,6 @@
sizer = wx.BoxSizer(wx.VERTICAL)
# body
-# dataBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
-# label=" %s " % _("Menu tree (double-click to run command)"))
dataSizer = wx.StaticBoxSizer(self.dataBox, wx.HORIZONTAL)
dataSizer.Add(item = self.tree, proportion =1,
flag = wx.EXPAND)
@@ -177,14 +174,15 @@
return
handler = 'self.parent.' + data['handler'].lstrip('self.')
- print 'handler = '+data['handler']
if data['handler'] == 'self.OnXTerm':
- wx.MessageBox('You must run this command from the menu or command line',
- 'This command require an XTerm')
+ wx.MessageBox(parent = self,
+ message = _('You must run this command from the menu or command line',
+ 'This command require an XTerm'),
+ caption = _('Message'), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
elif data['command']:
- self.parent.goutput.RunCmd(data['command'], switchPage = True)
+ eval(handler)(event = None, cmd = data['command'].split())
else:
- pass
+ eval(handler)(None)
if self.closeOnRun.IsChecked():
self.OnCloseWindow(None)
