[GRASS-SVN] r35714 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Feb 1 12:41:29 EST 2009
Author: martinl
Date: 2009-02-01 12:41:29 -0500 (Sun, 01 Feb 2009)
New Revision: 35714
grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
wxGUI: fix vector georectifier and related issues
(merge from relbr64, r35704)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2009-02-01 17:41:27 UTC (rev 35713)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2009-02-01 17:41:29 UTC (rev 35714)
@@ -91,27 +91,30 @@
Support virtual list class
def __init__(self, parent, log, mapDBInfo, layer):
- wx.ListCtrl.__init__(self, parent=parent, id=wx.ID_ANY,
- style=wx.LC_REPORT | wx.LC_HRULES |
- wx.LC_VRULES | wx.LC_VIRTUAL | wx.LC_SORT_ASCENDING)
# initialize variables
+ self.parent = parent
self.log = log
self.mapDBInfo = mapDBInfo
self.layer = layer
+ self.columns = {} # <- LoadData()
- self.columns = {} # <- LoadData()
+ wx.ListCtrl.__init__(self, parent=parent, id=wx.ID_ANY,
+ style=wx.LC_REPORT | wx.LC_HRULES |
+ wx.LC_VRULES | wx.LC_VIRTUAL | wx.LC_SORT_ASCENDING)
- # self.selectedCats = []
- # self.lastTurnSelectedCats = [] # just temporary, for comparation
+ try:
+ keyColumn = self.LoadData(layer)
+ except gcmd.DBMError, e:
+ e.Show()
+ return
# add some attributes (colourful background for each item rows)
self.attr1 = wx.ListItemAttr()
- # self.attr1.SetBackgroundColour("light blue")
self.attr1.SetBackgroundColour(wx.Colour(238,238,238))
self.attr2 = wx.ListItemAttr()
self.attr2.SetBackgroundColour("white")
@@ -121,9 +124,7 @@
self.sm_dn = self.il.Add(wx.ArtProvider_GetBitmap(wx.ART_GO_DOWN, wx.ART_TOOLBAR,
(16,16)))
self.SetImageList(self.il, wx.IMAGE_LIST_SMALL)
- keyColumn = self.LoadData(layer)
# setup mixins
listmix.ListCtrlAutoWidthMixin.__init__(self)
listmix.ColumnSorterMixin.__init__(self, len(self.columns))
@@ -133,20 +134,12 @@
self.SortListItems(col=keyColumn, ascending=True)
else:
self.SortListItems(col=0, ascending=True)
# events
self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
self.Bind(wx.EVT_LIST_ITEM_DESELECTED, self.OnItemDeselected)
self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColumnClick) # sorting
- # self.Bind(wx.EVT_LIST_DELETE_ITEM, self.OnItemDelete, self.list)
- # self.Bind(wx.EVT_LIST_COL_RIGHT_CLICK, self.OnColRightClick, self.list)
- # self.Bind(wx.EVT_LIST_COL_BEGIN_DRAG, self.OnColBeginDrag, self.list)
- # self.Bind(wx.EVT_LIST_COL_DRAGGING, self.OnColDragging, self.list)
- # self.Bind(wx.EVT_LIST_COL_END_DRAG, self.OnColEndDrag, self.list)
- # self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnBeginEdit, self.list)
- # self.list.Bind(wx.EVT_LEFT_DCLICK, self.OnDoubleClick)
- # self.list.Bind(wx.EVT_RIGHT_DOWN, self.OnRightDown)
def Update(self, mapDBInfo):
"""Update list according new mapDBInfo description"""
@@ -166,7 +159,13 @@
tableName = self.mapDBInfo.layers[layer]['table']
keyColumn = self.mapDBInfo.layers[layer]['key']
- self.columns = self.mapDBInfo.tables[tableName]
+ try:
+ self.columns = self.mapDBInfo.tables[tableName]
+ except KeyError:
+ raise gcmd.DBMError(message=_("Attribute table <%s> not found. "
+ "For creating the table switch to "
+ "'Manage layers' tab.") % tableName,
+ parent=self.parent)
cmd = ["v.db.select",
"-c", "--q",
@@ -415,6 +414,13 @@
"""Used by the ColumnSorterMixin, see wx/lib/mixins/listctrl.py"""
return (self.sm_dn, self.sm_up)
+ def IsEmpty(self):
+ """Check if list if empty"""
+ if self.columns:
+ return False
+ return True
class AttributeManager(wx.Frame):
GRASS Attribute manager main window
@@ -549,6 +555,14 @@
continue
panel = wx.Panel(parent=self.browsePage, id=wx.ID_ANY)
+ win = VirtualAttributeList(panel, self.log,
+ self.mapDBInfo, layer)
+ if win.IsEmpty():
+ del panel
+ continue
+ win.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnDataItemActivated)
self.layerPage[layer] = {'browsePage': panel.GetId()}
self.browsePage.AddPage(page=panel, text=" %d / %s %s" % \
@@ -566,9 +580,6 @@
sqlSizer = wx.StaticBoxSizer(sqlBox, wx.VERTICAL)
- win = VirtualAttributeList(panel, self.log,
- self.mapDBInfo, layer)
- win.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnDataItemActivated)
win.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnDataRightUp) #wxMSW
win.Bind(wx.EVT_RIGHT_UP, self.OnDataRightUp) #wxGTK
if UserSettings.Get(group='atm', key='leftDbClick', subkey='selection') == 0:
@@ -671,7 +682,7 @@
self.OnChangeSql(None)
self.log.write(_("Number of loaded records: %d") % \
self.FindWindowById(self.layerPage[self.layer]['data']).GetItemCount())
- except IndexError:
+ except (IndexError, KeyError):
self.layer = None
def __createManageTablePage(self, onlyLayer=-1):
@@ -680,9 +691,15 @@
if onlyLayer > 0 and layer != onlyLayer:
continue
+ if not self.layerPage.has_key(layer):
+ continue
panel = wx.Panel(parent=self.manageTablePage, id=wx.ID_ANY)
self.layerPage[layer]['tablePage'] = panel.GetId()
- self.manageTablePage.AddPage(page=panel, text=" %d / %s %s" % (layer, _("Table"), self.mapDBInfo.layers[layer]['table']))
+ self.manageTablePage.AddPage(page=panel,
+ text=" %d / %s %s" % (layer,
+ _("Table"),
+ self.mapDBInfo.layers[layer]['table']))
pageSizer = wx.BoxSizer(wx.VERTICAL)
@@ -2588,7 +2605,7 @@
if ret == None:
return columns
for column in ret.splitlines():
columns.append(column)
@@ -3331,7 +3348,11 @@
def GetColumns(self, table):
"""Return list of columns names (based on their index)"""
- names = [''] * len(self.tables[table].keys())
+ try:
+ names = [''] * len(self.tables[table].keys())
+ except KeyError:
+ return []
for name, desc in self.tables[table].iteritems():
names[desc['index']] = name
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2009-02-01 17:41:27 UTC (rev 35713)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2009-02-01 17:41:29 UTC (rev 35714)
@@ -85,7 +85,7 @@
self.Show()
return ''
class GStdError(GException):
"""Generic exception"""
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py 2009-02-01 17:41:27 UTC (rev 35713)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py 2009-02-01 17:41:29 UTC (rev 35714)
@@ -1,25 +1,29 @@
@package georect.py
-Georectification module for GRASS GIS. Includes ground control
+ at brief Georectification module for GRASS GIS. Includes ground control
point management and interactive point and click GCP creation
Classes:
- - Georectify
+ - GeorectWizard
+ - LocationPage
+ - GroupPage
+ - DispMapPage
- GCP
- - GRMap
+ - GCPList
+ - VectGroup
+ - EditGCP
- GrSettingsDialog
-COPYRIGHT: (C) 2006-2008 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
+(C) 2006-2008 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
@author Michael Barton
-Updated by Martin Landa <landa.martin gmail.com>
+ at author Updated by Martin Landa <landa.martin gmail.com>
-# recheck once completed to see how many of these are still needed
import os
import sys
import tempfile
@@ -111,12 +115,14 @@
self.grouppage = GroupPage(self.wizard, self)
self.mappage = DispMapPage(self.wizard, self)
- # Set the initial order of the pages
+ # set the initial order of the pages
self.startpage.SetNext(self.grouppage)
self.grouppage.SetPrev(self.startpage)
self.grouppage.SetNext(self.mappage)
self.mappage.SetPrev(self.grouppage)
# do pages layout
@@ -164,14 +170,14 @@
if maptype == 'cell':
rendertype = 'raster'
cmdlist = ['d.rast', 'map=%s' % xy_map]
- elif maptype == 'vector':
+ else: # -> vector layer
rendertype = 'vector'
cmdlist = ['d.vect', 'map=%s' % xy_map]
self.Map.AddLayer(type=rendertype, command=cmdlist, l_active=True,
name=utils.GetLayerNameFromCmd(cmdlist),
l_hidden=False, l_opacity=1.0, l_render=False)
# start GCP form
@@ -307,8 +313,10 @@
self.sizer.AddGrowableCol(2)
# map type
- self.rb_maptype = wx.RadioBox(parent=self, id=wx.ID_ANY, label=' %s ' % _("Map type to georectify"),
- choices=[_('raster'), _('vector')], majorDimension=wx.RA_SPECIFY_COLS)
+ self.rb_maptype = wx.RadioBox(parent=self, id=wx.ID_ANY,
+ label=' %s ' % _("Map type to georectify"),
+ choices=[_('raster'), _('vector')],
+ majorDimension=wx.RA_SPECIFY_COLS)
self.sizer.Add(item=self.rb_maptype,
flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
pos=(1, 1), span=(1, 2))
@@ -353,7 +361,7 @@
maptype = 'cell'
else:
maptype = 'vector'
def OnLocation(self, event):
"""Sets source location for map(s) to georectify"""
self.xylocation = event.GetString()
@@ -393,9 +401,9 @@
wx.MessageBox(_('You must select a valid location and mapset in order to continue'))
event.Veto()
return
- else:
- self.parent.SetSrcEnv(self.xylocation, self.xymapset)
+ self.parent.SetSrcEnv(self.xylocation, self.xymapset)
def OnEnterPage(self, event=None):
if self.xylocation == '' or self.xymapset == '':
wx.FindWindowById(wx.ID_FORWARD).Enable(False)
@@ -440,8 +448,17 @@
self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Create group if none exists')),
flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=5,
pos=(2, 1))
+ btnSizer = wx.BoxSizer(wx.HORIZONTAL)
self.btn_mkgroup = wx.Button(parent=self, id=wx.ID_ANY, label=_("Create/edit group..."))
- self.sizer.Add(item=self.btn_mkgroup,
+ self.btn_vgroup = wx.Button(parent=self, id=wx.ID_ANY, label=_("Add vector map to group..."))
+ self.btn_vgroup.Hide()
+ btnSizer.Add(item=self.btn_mkgroup,
+ flag=wx.RIGHT, border=5)
+ btnSizer.Add(item=self.btn_vgroup,
+ flag=wx.LEFT, border=5)
+ self.sizer.Add(item=btnSizer,
pos=(2, 2))
@@ -459,7 +476,6 @@
# bindings
self.Bind(wx.EVT_COMBOBOX, self.OnGroup, self.cb_group)
- self.Bind(wx.EVT_BUTTON, self.OnMkGroup, self.btn_mkgroup)
self.Bind(wx.EVT_TEXT, self.OnExtension, self.ext_txt)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
@@ -470,19 +486,25 @@
def OnMkGroup(self, event):
"""Create new group in source location/mapset"""
- global maptype
+ menuform.GUI().ParseCommand(['i.group'],
+ completed=(self.GetOptData, None, ''),
+ parentframe=self.parent.parent, modal=True)
- # open dialog
- if maptype == 'cell':
- menuform.GUI().ParseCommand(['i.group'],
- completed=(self.GetOptData, None, ''),
- parentframe=self.parent.parent, modal=True)
- dlg = VectGroup(self, wx.ID_ANY, self.grassdatabase, self.xylocation, self.xymapset, self.xygroup)
- if dlg.ShowModal() == wx.ID_OK:
- dlg.MakeVGroup()
- self.OnEnterPage()
+ def OnVGroup(self, event):
+ """Add vector maps to group"""
+ dlg = VectGroup(parent = self,
+ id = wx.ID_ANY,
+ grassdb = self.grassdatabase,
+ location = self.xylocation,
+ mapset = self.xymapset,
+ group = self.xygroup)
+ if dlg.ShowModal() != wx.ID_OK:
+ return
+ dlg.MakeVGroup()
+ self.OnEnterPage()
def GetOptData(self, dcmd, layer, params, propwin):
"""Process i.group"""
# update the page
@@ -507,47 +529,64 @@
return
+ global maptype
self.groupList = []
- tmplist = []
self.xylocation = self.parent.gisrc_dict['LOCATION_NAME']
self.xymapset = self.parent.gisrc_dict['MAPSET']
# create a list of groups in selected mapset
- if os.path.isdir(os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group')):
- tmplist = os.listdir(os.path.join(self.grassdatabase, self.xylocation, self.xymapset, 'group'))
- else:
- tmplist = []
- # if (event and event.GetDirection()) and self.xygroup == '':
- # if tmplist == []:
- # wx.MessageBox(_('No map/imagery groups exist to georectify. '
- # 'You will need to create one.'))
- # else:
- for item in tmplist:
- if os.path.isdir(os.path.join(self.grassdatabase, self.xylocation, self.xymapset, 'group', item)):
- self.groupList.append(item)
+ if os.path.isdir(os.path.join(self.grassdatabase,
+ self.xylocation,
+ self.xymapset,
+ 'group')):
+ tmplist = os.listdir(os.path.join(self.grassdatabase,
+ self.xylocation,
+ self.xymapset,
+ 'group'))
+ for item in tmplist:
+ self.xylocation,
+ self.xymapset,
+ 'group',
+ item)):
+ self.groupList.append(item)
+ if maptype == 'cell':
+ self.Bind(wx.EVT_BUTTON, self.OnMkGroup, self.btn_mkgroup)
+ elif maptype == 'vector':
+ self.btn_vgroup.Show()
+ self.Bind(wx.EVT_BUTTON, self.OnVGroup, self.btn_vgroup)
utils.ListSortLower(self.groupList)
self.cb_group.SetItems(self.groupList)
- if len(self.groupList) > 0:
+ if len(self.groupList) > 0 and \
+ self.xygroup == '':
self.cb_group.SetSelection(0)
self.xygroup = self.groupList[0]
- if self.xygroup == '' or self.extension == '':
+ if self.xygroup == '' or \
+ self.extension == '':
else:
wx.FindWindowById(wx.ID_FORWARD).Enable(True)
# switch to source
self.parent.SwitchEnv('new')
class DispMapPage(TitledPage):
Select ungeoreferenced map to display for interactively
setting ground control points (GCPs).
def __init__(self, wizard, parent):
- TitledPage.__init__(self, wizard, _("Select image/map to display for ground control point (GCP) creation"))
+ TitledPage.__init__(self, wizard,
+ _("Select image/map to display for ground control point (GCP) creation"))
global maptype
@@ -558,8 +597,10 @@
self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select display image/map:')),
pos=(1, 1))
- self.selection = gselect.Select(self, id=wx.ID_ANY, size=globalvar.DIALOG_GSELECT_SIZE,
- type=maptype)
+ self.selection = gselect.Select(self, id=wx.ID_ANY,
+ size=globalvar.DIALOG_GSELECT_SIZE)
self.sizer.Add(item=self.selection,
pos=(1, 2))
@@ -597,7 +638,8 @@
global maptype
global xy_map
- self.selection.SetElementList(maptype)
+ self.selection.SetElementList(maptype,
+ mapsets = [self.parent.newmapset, ])
if xy_map == '':
@@ -999,7 +1041,7 @@
if self.CheckGCPcount(msg=True) == False:
return
self.grwiz.SwitchEnv('new')
cmdlist = ['i.rectify','-a','group=%s' % self.xygroup,
@@ -1009,45 +1051,99 @@
self.parent.goutput.RunCmd(cmdlist, compReg=False,
switchPage=True)
time.sleep(.1)
self.grwiz.SwitchEnv('original')
- # loop through all vectors in VREF and move resulting vector to target location
- f = open(self.vgrpfile)
+ # loop through all vectors in VREF
+ # and move resulting vector to target location
+ f = open(self.file['vgrp'])
vectlist = []
try:
- for vect in f:
- vect = vect.strip(' \n')
+ for vect in f.readlines():
+ vect = vect.strip('\n')
+ if len(vect) < 1:
+ continue
vectlist.append(vect)
finally:
f.close()
for vect in vectlist:
- outname = vect+'_'+self.extension
- p = gcmd.RunCommand('v.transform',
- parent = self,
- quiet = True,
- input = vect,
- output = outname,
- pointsfile = self.pointsfile)
+ self.grwiz.SwitchEnv('new')
+ self.outname = vect + '_' + self.extension
+ self.parent.goutput.WriteLog(text = _('Transforming <%s>...') % vect,
+ switchPage = True)
+ xyLayer = []
+ for layer in grass.vector_db(map = vect).itervalues():
+ xyLayer.append((layer['driver'],
+ layer['database'],
+ layer['table']))
+ self.parent.goutput.RunCmd(['v.transform',
+ '--o',
+ 'input=%s' % vect,
+ 'output=%s' % self.outname,
+ 'pointsfile=%s' % self.file['points']],
+ switchPage = True,
+ onDone = self.OnGeorectDone)
+ dbConnect = grass.db_connection()
+ for layer in xyLayer:
+ self.parent.goutput.RunCmd(['db.copy',
+ '--q',
+ '--o',
+ 'from_driver=%s' % layer[0],
+ 'from_database=%s' % layer[1],
+ 'from_table=%s' % layer[2],
+ 'to_driver=%s' % dbConnect['driver'],
+ 'to_database=%s' % dbConnect['database'],
+ 'to_table=%s' % layer[2] + '_' + self.extension])
+ def OnGeorectDone(self, **kargs):
+ """Print final message"""
+ global maptype
+ return
+ returncode = kargs['returncode']
+ xyvpath = os.path.join(self.grassdatabase,
+ self.xylocation,
+ self.xymapset,
+ 'vector',
+ self.outname)
+ vpath = os.path.join(self.grassdatabase,
+ self.currentlocation,
+ self.currentmapset,
+ 'vector',
+ self.outname)
+ if os.path.isdir(vpath):
+ self.parent.goutput.WriteWarning(_('Vector map <%s> already exists. '
+ 'Change extension name and '
+ 'georectify again.') % self.outname)
+ else:
+ if returncode == 0:
+ if not os.path.isdir(os.path.join(self.grassdatabase,
+ 'vector')):
+ os.mkdir(os.path.join(self.grassdatabase,
+ 'vector'))
+ shutil.move(xyvpath, vpath)
- if p == 0:
- wx.MessageBox("All maps were georectified successfully")
- for vect in vectlist:
- xyvpath = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'vector',outname)
- vpath = os.path.join(self.grassdatabase,self.currentlocation,self.currentmapset,'vector',outname)
- if os.path.isfile(vpath):
- wx.MessageBox("%s already exists. Change extension name and georectify again" % outname)
- else:
- shutil.move(xyvpath, vpath)
- wx.MessageBox('For vector files with attribute tables, you will need to manually copy the tables to the new location')
+ self.parent.goutput.WriteCmdLog(_('Vector map <%s> georectified '
+ 'successfully') % self.outname)
+ # copy attributes
+ self.parent.goutput.WriteLog(_('Copying attributes...'))
else:
- wx.MessageBox('Some maps were not georectified successfully')
- else:
- return
+ self.parent.goutput.WriteError(_('Georectification of vector map <%s> failed') %
+ self.outname)
+ del self.outname
+ self.grwiz.SwitchEnv('original')
def OnSettings(self, event):
"""Georectifier settings"""
@@ -1298,97 +1394,131 @@
class VectGroup(wx.Dialog):
Dialog to create a vector group (VREF file) for georectifying
+ @todo Replace by g.group
def __init__(self, parent, id, grassdb, location, mapset, group,
- style=wx.DEFAULT_DIALOG_STYLE):
- wx.Dialog.__init__(self, parent, id, style=style)
+ style=wx.DEFAULT_DIALOG_STYLE):
+ wx.Dialog.__init__(self, parent, id, style=style,
+ title = _("Create vector map group"))
self.grassdatabase = grassdb
self.xylocation = location
self.xymapset = mapset
self.xygroup = group
# get list of valid vector directories
- vectlist = os.listdir(os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'vector'))
+ vectlist = os.listdir(os.path.join(self.grassdatabase,
+ self.xylocation,
+ self.xymapset,
+ 'vector'))
for dir in vectlist:
- if os.path.isfile(os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'vector',dir,'coor')):
- pass
- else:
+ if not os.path.isfile(os.path.join(self.grassdatabase,
+ self.xylocation,
+ self.xymapset,
+ 'vector',
+ dir,
+ 'coor')):
vectlist.remove(dir)
- self.vgrouplist = []
- self.vgrpfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'VREF')
+ utils.ListSortLower(vectlist)
+ # path to vref file
+ self.vgrpfile = os.path.join(self.grassdatabase,
+ self.xylocation,
+ self.xymapset,
+ 'group',
+ self.xygroup,
+ 'VREF')
+ # buttons
+ self.btnCancel = wx.Button(parent = self,
+ id = wx.ID_CANCEL)
+ self.btnOK = wx.Button(parent = self,
+ id = wx.ID_OK)
+ self.btnOK.SetDefault()
+ # list of vector maps
+ self.listMap = wx.CheckListBox(parent = self, id = wx.ID_ANY,
+ choices = vectlist)
if os.path.isfile(self.vgrpfile):
try:
- for line in f:
- if line != '':
- self.vgrouplist.append(line.strip(' \n'))
+ checked = []
+ for line in f.readlines():
+ line = line.replace('\n', '')
+ if len(line) < 1:
+ continue
+ checked.append(line)
+ self.listMap.SetCheckedStrings(checked)
finally:
f.close()
- self.btnCancel = wx.Button(self, wx.ID_CANCEL)
- self.btnSubmit = wx.Button(self, wx.ID_OK)
- self.btnSubmit.SetDefault()
+ line = wx.StaticLine(parent = self,
+ id = wx.ID_ANY, size = (20, -1),
+ style = wx.LI_HORIZONTAL)
+ # layout
sizer = wx.BoxSizer(wx.VERTICAL)
box = wx.BoxSizer(wx.HORIZONTAL)
- label = wx.StaticText(parent=self, id=wx.ID_ANY,
- label='Select vector map(s) to add to group:')
- box.Add(label, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT, border=5)
- self.addmap = wx.CheckListBox(self, -1, wx.DefaultPosition, wx.DefaultSize, vectlist)
- box.Add(self.addmap, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT| wx.LEFT, border=5)
- sizer.Add(box, flag=wx.ALIGN_RIGHT | wx.ALL, border=3)
+ box.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = _('Select vector map(s) to add to group:')),
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT,
+ border = 5)
+ box.Add(item = self.listMap,
+ border = 5)
- box = wx.BoxSizer(wx.HORIZONTAL)
- label='Select vector map(s) to remove from group:')
- self.remmap = wx.CheckListBox(self, -1, wx.DefaultPosition, wx.DefaultSize, self.vgrouplist)
- box.Add(self.remmap, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT| wx.LEFT, border=5)
+ sizer.Add(box, flag = wx.ALIGN_RIGHT | wx.ALL,
+ border = 3)
+ sizer.Add(item = line, proportion = 0,
+ flag = wx.GROW | wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
+ border = 5)
# buttons
btnSizer = wx.StdDialogButtonSizer()
btnSizer.AddButton(self.btnCancel)
- btnSizer.AddButton(self.btnSubmit)
+ btnSizer.AddButton(self.btnOK)
btnSizer.Realize()
- sizer.Add(item=btnSizer, proportion=0,
- flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+ sizer.Add(item = btnSizer, proportion = 0,
+ flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER,
+ border = 5)
self.SetSizer(sizer)
sizer.Fit(self)
self.Layout()
- self.Bind(wx.EVT_CHECKLISTBOX, self.AddVect, self.addmap)
- self.Bind(wx.EVT_CHECKLISTBOX, self.RemoveVect, self.remmap)
- def AddVect(self, event):
- index = event.GetSelection()
- label = self.addmap.GetString(index)
- if self.addmap.IsChecked(index):
- self.vgrouplist.append(label)
- self.addmap.SetSelection(index)
- event.Skip()
+ def MakeVGroup(self):
+ """Create VREF file"""
+ vgrouplist = []
+ for item in range(self.listMap.GetCount()):
+ if not self.listMap.IsChecked(item):
+ continue
+ vgrouplist.append(self.listMap.GetString(item))
- def RemoveVect(self, event):
- label = self.remmap.GetString(index)
- if self.remmap.IsChecked(index):
- self.vgrouplist.remove(label)
- self.remmap.SetSelection(index)
- event.Skip()
+ f = open(self.vgrpfile, mode='w')
+ try:
+ for vect in vgrouplist:
+ f.write(vect + '\n')
+ finally:
+ f.close()
- def MakeVGroup(self):
- f = open(self.vgrpfile, mode='w')
- for vect in self.vgrouplist:
- f.write(vect+'\n')
class EditGPC(wx.Dialog):
def __init__(self, parent, data, id=wx.ID_ANY,
title=_("Edit GCP"),
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2009-02-01 17:41:27 UTC (rev 35713)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2009-02-01 17:41:29 UTC (rev 35714)
@@ -61,17 +61,17 @@
self.start()
- def RunCmd(self, callable, *args, **kwds):
+ def RunCmd(self, callable, onDone, *args, **kwds):
CmdThread.requestId += 1
self.requestCmd = None
- self.requestQ.put((CmdThread.requestId, callable, args, kwds))
+ self.requestQ.put((CmdThread.requestId, callable, onDone, args, kwds))
return CmdThread.requestId
def run(self):
while True:
- requestId, callable, args, kwds = self.requestQ.get()
+ requestId, callable, onDone, args, kwds = self.requestQ.get()
requestTime = time.time()
event = wxCmdRun(cmd=args[0],
@@ -96,10 +96,11 @@
time.sleep(.1)
- event = wxCmdDone(aborted=aborted,
- returncode=returncode,
- time=requestTime,
- pid=requestId)
+ event = wxCmdDone(aborted = aborted,
+ returncode = returncode,
+ time = requestTime,
+ pid = requestId,
+ onDone = onDone)
wx.PostEvent(self.parent, event)
@@ -213,7 +214,8 @@
return False
- def WriteLog(self, text, style=None, wrap=None):
+ def WriteLog(self, text, style = None, wrap = None,
+ switchPage = False):
"""Generic method for writing log message in
given style
@@ -221,6 +223,10 @@
@param style text style (see GMStc)
@param stdout write to stdout or stderr
+ if switchPage and \
+ self.parent.notebook.GetSelection() != self.parent.goutput.pageid:
+ self.parent.notebook.SetSelection(self.parent.goutput.pageid)
if not style:
style = self.cmd_output.StyleDefault
@@ -244,16 +250,21 @@
self.cmd_output.EnsureCaretVisible()
def WriteCmdLog(self, line, pid=None):
- """Write out line in selected style"""
+ """Write message in selected style"""
if pid:
line = '(' + str(pid) + ') ' + line
self.WriteLog(line, style=self.cmd_output.StyleCommand)
def WriteWarning(self, line):
- """Write out line in warning style"""
+ """Write message in warning style"""
self.WriteLog(line, style=self.cmd_output.StyleWarning)
- def RunCmd(self, command, compReg=True, switchPage=False):
+ def WriteError(self, line):
+ """Write message in error style"""
+ self.WriteLog(line, style=self.cmd_output.StyleError)
+ def RunCmd(self, command, compReg=True, switchPage=False,
+ onDone = None):
Run in GUI GRASS (or other) commands typed into
console command text widget, and send stdout output to output
@@ -269,6 +280,7 @@
@param command command (list)
@param compReg if true use computation region
@param switchPage switch to output page
+ @param onDone function to be called when command is finished
# map display window available ?
@@ -320,10 +332,13 @@
# switch to 'Command output'
- if switchPage and \
- self.parent.notebook.GetSelection() != self.parent.goutput.pageid:
- self.parent.notebook.SetSelection(self.parent.goutput.pageid)
+ if switchPage:
+ if self.parent.notebook.GetSelection() != self.parent.goutput.pageid:
+ self.parent.SetFocus() # -> set focus
+ self.parent.Raise()
# activate computational region (set with g.region)
# for all non-display commands.
if compReg:
@@ -338,8 +353,9 @@
else:
# process GRASS command with argument
self.cmdThread.RunCmd(GrassCmd,
+ onDone,
cmdlist,
- self.cmd_stdout, self.cmd_stderr)
+ self.cmd_stdout, self.cmd_stderr)
self.cmd_output_timer.Start(50)
@@ -494,6 +510,9 @@
# stopped deamon
pass
+ if event.onDone:
+ event.onDone(returncode = event.returncode)
self.console_progressbar.SetValue(0) # reset progress bar on '0%'
self.cmd_output_timer.Stop()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-02-01 17:41:27 UTC (rev 35713)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-02-01 17:41:29 UTC (rev 35714)
@@ -35,7 +35,7 @@
class Select(wx.combo.ComboCtrl):
def __init__(self, parent, id, size,
- type, multiple=False, mapsets=None, exceptOf=[]):
+ type=None, multiple=False, mapsets=None, exceptOf=[]):
Custom control to create a ComboBox with a tree control
to display and select GIS elements within acessible mapsets.
@@ -51,13 +51,17 @@
self.SetPopupControl(self.tcp)
self.SetPopupExtents(0,100)
- self.tcp.GetElementList(type, mapsets, exceptOf)
- self.tcp.SetData(type, mapsets, exceptOf, multiple)
+ if type:
+ self.tcp.GetElementList(type, mapsets, exceptOf)
+ self.tcp.SetData(type = type, mapsets = mapsets,
+ exceptOf = exceptOf, multiple = multiple)
- def SetElementList(self, type):
+ def SetElementList(self, type, mapsets = None, exceptOf = []):
self.tcp.seltree.DeleteAllItems()
self.tcp.GetElementList(type)
+ exceptOf = exceptOf)
class TreeCtrlComboPopup(wx.combo.ComboPopup):
Create a tree ComboBox for selecting maps and other GIS elements
@@ -303,12 +307,16 @@
evt.Skip()
- def SetData(self, type, mapsets, exceptOf, multiple):
- """Select multiple items?"""
- self.type = type
- self.mapsets = mapsets
- self.exceptOf = exceptOf
- self.multiple = multiple
+ def SetData(self, **kargs):
+ """Set object properties"""
+ if kargs.has_key('type'):
+ self.type = kargs['type']
+ if kargs.has_key('mapsets'):
+ self.mapsets = kargs['mapsets']
+ if kargs.has_key('exceptOf'):
+ self.exceptOf = kargs['exceptOf']
+ if kargs.has_key('multiple'):
+ self.multiple = kargs['multiple']
class VectorDBInfo:
"""Class providing information about attribute tables
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2009-02-01 17:41:27 UTC (rev 35713)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2009-02-01 17:41:29 UTC (rev 35714)
@@ -46,7 +46,7 @@
read = True,
pid = os.getpid())
- tempfile = tempfileCmd.splitlines()[0].strip()
+ tempfile = ret.splitlines()[0].strip()
# FIXME
# ugly hack for MSYS (MS Windows)
