[GRASS-SVN] r35788 -
grass/branches/releasebranch_6_4/scripts/i.landsat.rgb
svn_grass at osgeo.org
Fri Feb 6 05:10:37 EST 2009
Author: hamish
Date: 2009-02-06 05:10:37 -0500 (Fri, 06 Feb 2009)
New Revision: 35788
grass/branches/releasebranch_6_4/scripts/i.landsat.rgb/i.landsat.rgb
fix mapset check, remove bashism and unimportant warning (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/i.landsat.rgb/i.landsat.rgb
--- grass/branches/releasebranch_6_4/scripts/i.landsat.rgb/i.landsat.rgb 2009-02-06 10:05:22 UTC (rev 35787)
+++ grass/branches/releasebranch_6_4/scripts/i.landsat.rgb/i.landsat.rgb 2009-02-06 10:10:37 UTC (rev 35788)
@@ -161,22 +161,16 @@
BLUE_MAPSET=`g.findfile -n elem=cell file=$BLUE | grep mapset | cut -d'=' -f2`
GREEN_MAPSET=`g.findfile -n elem=cell file=$GREEN | grep mapset | cut -d'=' -f2`
-if [ "$BLUE_MAPSET" == "$MAPSET" ] ; then
+if [ "$BLUE_MAPSET" = "$CURRENT_MAPSET" ] ; then
r.support ${BLUE} history="${CMDLINE}"
-else
- g.message -w message="Unable to write history for <$BLUE>. Raster map <$BLUE> not found in current mapset."
fi
-if [ "$GREEN_MAPSET" == "$MAPSET" ] ; then
+if [ "$GREEN_MAPSET" = "$CURRENT_MAPSET" ] ; then
r.support ${GREEN} history="${CMDLINE}"
-else
- g.message -w message="Unable to write history for <$GREEN>. Raster map <$GREEN> not found in current mapset."
fi
-if [ "$RED_MAPSET" == "$MAPSET" ] ; then
+if [ "$RED_MAPSET" = "$CURRENT_MAPSET" ] ; then
r.support ${RED} history="${CMDLINE}"
-else
- g.message -w message="Unable to write history for <$RED>. Raster map <$RED> not found in current mapset."
fi
exit 0
