[GRASS-SVN] r35793 - grass/trunk/locale/po
Fri Feb 6 16:04:53 EST 2009
Author: neteler
Date: 2009-02-06 16:04:49 -0500 (Fri, 06 Feb 2009)
New Revision: 35793
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_hi.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_mr.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
typos fixed
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_ar.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11499,7 +11499,7 @@
 #: ../vector/lidar/v.outlier/main.c:111
 #: ../vector/lidar/v.surf.bspline/main.c:140
-msgid "Thychonov regularization weigth"
+msgid "Tychonov regularization weight"
 msgstr ""
 #: ../vector/lidar/v.outlier/main.c:118
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_cs.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -25920,8 +25920,8 @@
 #: ../vector/lidar/v.surf.bspline/main.c:142
-msgstr "Váha Thychonovy regularizace"
+msgstr "Váha Tychonovy regularizace"
 #: ../vector/lidar/v.surf.bspline/main.c:159
 msgid "Attribute table column with values to interpolate (if layer>0)"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_de.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11567,7 +11567,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_el.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -10836,7 +10836,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_es.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11590,8 +11590,8 @@
-msgstr "Peso de regularización Thychonov "
+msgstr "Peso de regularización Tychonov"
 msgid "Threshold for the outliers"
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_fr.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -12356,7 +12356,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_hi.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11662,7 +11662,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_it.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11445,7 +11445,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_ja.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11608,7 +11608,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_ko.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -10952,7 +10952,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_lv.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11417,7 +11417,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_mr.po
--- grass/trunk/locale/po/grassmods_mr.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_mr.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11071,7 +11071,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_pl.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11504,7 +11504,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_pt.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11942,7 +11942,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11971,7 +11971,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_ru.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11458,7 +11458,7 @@
 msgstr "Вес регуляризации Тихонова"
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_sl.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11570,7 +11570,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_th.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11219,8 +11219,8 @@
-msgstr "Thychonov regularization weigth"
+msgstr ""
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_tr.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -10921,7 +10921,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_vi.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11873,8 +11873,8 @@
-msgstr "Trọng số phép chính quy hóa Tykhonov"
+msgstr "Trọng số phép chính quy hóa Tkhonov"
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2009-02-06 20:55:36 UTC (rev 35792)
+++ grass/trunk/locale/po/grassmods_zh.po	2009-02-06 21:04:49 UTC (rev 35793)
@@ -11495,7 +11495,7 @@
 msgstr ""
