[GRASS-SVN] r35792 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Fri Feb 6 15:55:41 EST 2009
Author: neteler
Date: 2009-02-06 15:55:36 -0500 (Fri, 06 Feb 2009)
New Revision: 35792
grass/branches/develbranch_6/locale/po/grassmods_ar.po
grass/branches/develbranch_6/locale/po/grassmods_cs.po
grass/branches/develbranch_6/locale/po/grassmods_de.po
grass/branches/develbranch_6/locale/po/grassmods_el.po
grass/branches/develbranch_6/locale/po/grassmods_es.po
grass/branches/develbranch_6/locale/po/grassmods_fr.po
grass/branches/develbranch_6/locale/po/grassmods_hi.po
grass/branches/develbranch_6/locale/po/grassmods_it.po
grass/branches/develbranch_6/locale/po/grassmods_ja.po
grass/branches/develbranch_6/locale/po/grassmods_ko.po
grass/branches/develbranch_6/locale/po/grassmods_lv.po
grass/branches/develbranch_6/locale/po/grassmods_mr.po
grass/branches/develbranch_6/locale/po/grassmods_pl.po
grass/branches/develbranch_6/locale/po/grassmods_pt.po
grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
grass/branches/develbranch_6/locale/po/grassmods_ru.po
grass/branches/develbranch_6/locale/po/grassmods_sl.po
grass/branches/develbranch_6/locale/po/grassmods_th.po
grass/branches/develbranch_6/locale/po/grassmods_tr.po
grass/branches/develbranch_6/locale/po/grassmods_vi.po
grass/branches/develbranch_6/locale/po/grassmods_zh.po
typos fixed
Modified: grass/branches/develbranch_6/locale/po/grassmods_ar.po
--- grass/branches/develbranch_6/locale/po/grassmods_ar.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_ar.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16398,7 +16398,7 @@
#: ../vector/lidar/v.outlier/main.c:109
#: ../vector/lidar/v.surf.bspline/main.c:138
-msgid "Thychonov regularization weigth"
+msgid "Tychonov regularization weight"
msgstr ""
#: ../vector/lidar/v.outlier/main.c:116
Modified: grass/branches/develbranch_6/locale/po/grassmods_cs.po
--- grass/branches/develbranch_6/locale/po/grassmods_cs.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_cs.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -27607,8 +27607,8 @@
#: ../vector/lidar/v.surf.bspline/main.c:140
-msgstr "Váha Thychonovy regularizace"
+msgstr "Váha Tychonovy regularizace"
#: ../vector/lidar/v.surf.bspline/main.c:157
msgid "Attribute table column with values to interpolate (if layer>0)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_de.po
--- grass/branches/develbranch_6/locale/po/grassmods_de.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_de.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16284,7 +16284,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_el.po
--- grass/branches/develbranch_6/locale/po/grassmods_el.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_el.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -15532,7 +15532,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_es.po
--- grass/branches/develbranch_6/locale/po/grassmods_es.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_es.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16701,8 +16701,8 @@
-msgstr "Peso de regularización Thychonov "
+msgstr "Peso de regularización Tychonov"
msgid "Threshold for the outliers"
Modified: grass/branches/develbranch_6/locale/po/grassmods_fr.po
--- grass/branches/develbranch_6/locale/po/grassmods_fr.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_fr.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -17611,7 +17611,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_hi.po
--- grass/branches/develbranch_6/locale/po/grassmods_hi.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_hi.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16766,7 +16766,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_it.po
--- grass/branches/develbranch_6/locale/po/grassmods_it.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_it.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16379,7 +16379,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_ja.po
--- grass/branches/develbranch_6/locale/po/grassmods_ja.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_ja.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16729,7 +16729,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_ko.po
--- grass/branches/develbranch_6/locale/po/grassmods_ko.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_ko.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -15655,7 +15655,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_lv.po
--- grass/branches/develbranch_6/locale/po/grassmods_lv.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_lv.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16235,7 +16235,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_mr.po
--- grass/branches/develbranch_6/locale/po/grassmods_mr.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_mr.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -15792,7 +15792,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_pl.po
--- grass/branches/develbranch_6/locale/po/grassmods_pl.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_pl.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16371,7 +16371,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -17090,7 +17090,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -17093,7 +17093,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_ru.po
--- grass/branches/develbranch_6/locale/po/grassmods_ru.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_ru.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16366,7 +16366,7 @@
msgstr "ÐÐµÑ ÑегÑлÑÑизаÑии ТиÑ
онова"
Modified: grass/branches/develbranch_6/locale/po/grassmods_sl.po
--- grass/branches/develbranch_6/locale/po/grassmods_sl.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_sl.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16657,7 +16657,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_th.po
--- grass/branches/develbranch_6/locale/po/grassmods_th.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_th.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16002,8 +16002,8 @@
-msgstr "Thychonov regularization weigth"
+msgid "Tychonov regularization weigth"
+msgstr "Tychonov regularization weight"
Modified: grass/branches/develbranch_6/locale/po/grassmods_tr.po
--- grass/branches/develbranch_6/locale/po/grassmods_tr.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_tr.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -15597,7 +15597,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_vi.po
--- grass/branches/develbranch_6/locale/po/grassmods_vi.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_vi.po 2009-02-06 20:55:36 UTC (rev 35792)
@@ -16949,8 +16949,8 @@
-msgstr "Trá»ng sá» phép chÃnh quy hóa Tykhonov"
+msgstr "Trá»ng sá» phép chÃnh quy hóa Tychonov"
Modified: grass/branches/develbranch_6/locale/po/grassmods_zh.po
--- grass/branches/develbranch_6/locale/po/grassmods_zh.po 2009-02-06 20:51:20 UTC (rev 35791)
+++ grass/branches/develbranch_6/locale/po/grassmods_zh.po 2009-02-06 20:55:36 UTC (rev 35792)
msgstr ""
