[GRASS-SVN] r35791 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Fri Feb 6 15:51:24 EST 2009
Author: neteler
Date: 2009-02-06 15:51:20 -0500 (Fri, 06 Feb 2009)
New Revision: 35791
grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
typos fixed
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9798,7 +9798,7 @@
#: ../vector/lidar/v.outlier/main.c:109
#: ../vector/lidar/v.surf.bspline/main.c:138
-msgid "Thychonov regularization weigth"
+msgid "Tychonov regularization weight"
msgstr ""
#: ../vector/lidar/v.outlier/main.c:116
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -27528,8 +27528,8 @@
#: ../vector/lidar/v.surf.bspline/main.c:140
-msgstr "Váha Thychonovy regularizace"
+msgstr "Váha Tychonovy regularizace"
#: ../vector/lidar/v.surf.bspline/main.c:157
msgid "Attribute table column with values to interpolate (if layer>0)"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9961,7 +9961,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9266,7 +9266,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_es.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_es.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9937,8 +9937,8 @@
-msgstr "Peso de regularización Thychonov "
+msgstr "Peso de regularización Tychonov "
msgid "Threshold for the outliers"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -24002,7 +24002,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9965,7 +9965,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9747,7 +9747,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9904,7 +9904,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9387,7 +9387,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9721,7 +9721,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9476,7 +9476,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9855,7 +9855,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -10130,7 +10130,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -10156,7 +10156,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9833,7 +9833,7 @@
msgstr "ÐÐµÑ ÑегÑлÑÑизаÑии ТиÑ
онова"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9853,7 +9853,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_th.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_th.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9633,8 +9633,8 @@
-msgstr "Thychonov regularization weigth"
+msgid "Tychonov regularization weigth"
+msgstr "Tychonov regularization weight"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po 2009-02-06 20:51:20 UTC (rev 35791)
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -10116,8 +10116,8 @@
-msgstr "Trá»ng sá» phép chÃnh quy hóa Tykhonov"
+msgstr "Trá»ng sá» phép chÃnh quy hóa Tychonov"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po 2009-02-06 20:22:07 UTC (rev 35790)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po 2009-02-06 20:51:20 UTC (rev 35791)
@@ -9790,7 +9790,7 @@
msgstr ""
