[GRASS-SVN] r35860 - grass/trunk/locale/po
svn_grass at osgeo.org
Thu Feb 12 14:36:00 EST 2009
Author: neteler
Date: 2009-02-12 14:35:59 -0500 (Thu, 12 Feb 2009)
New Revision: 35860
grass/trunk/locale/po/grasswxpy_de.po
kbabel rough translation based on grassmods_de.po
Modified: grass/trunk/locale/po/grasswxpy_de.po
--- grass/trunk/locale/po/grasswxpy_de.po 2009-02-12 19:34:28 UTC (rev 35859)
+++ grass/trunk/locale/po/grasswxpy_de.po 2009-02-12 19:35:59 UTC (rev 35860)
@@ -12,7 +12,7 @@
"Project-Id-Version: grasswxpy_de\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2009-01-09 23:29+0100\n"
-"PO-Revision-Date: 2009-01-30 20:49+0100\n"
+"PO-Revision-Date: 2009-02-12 20:35+0100\n"
"Last-Translator: Markus Neteler <neteler osgeo.org>\n"
"Language-Team: deutsch <Deutsch <grass-translations at lists.osgeo.org>>\n"
"MIME-Version: 1.0\n"
@@ -24,7 +24,7 @@
#: ../gui/wxpython/gui_modules/profile.py:65
#, fuzzy
msgid "Profile Analysis"
-msgstr "Oberflächenanalysen"
+msgstr "Analyse"
#: ../gui/wxpython/gui_modules/profile.py:153
#: ../gui/wxpython/gui_modules/profile.py:272
@@ -54,8 +54,9 @@
msgstr "Raster Werte"
#: ../gui/wxpython/gui_modules/profile.py:447
+#, fuzzy
msgid "You must draw a transect to profile in the map display window."
-msgstr ""
+msgstr "Darstellung."
#: ../gui/wxpython/gui_modules/profile.py:448
msgid "Nothing to profile"
@@ -158,7 +159,7 @@
#: ../gui/wxpython/gui_modules/profile.py:1116
#, fuzzy
msgid "Profile line settings"
-msgstr "Linien"
+msgstr "Linie"
#: ../gui/wxpython/gui_modules/profile.py:1126
#: ../gui/wxpython/gui_modules/wxgui_utils.py:345
@@ -168,13 +169,13 @@
#: ../gui/wxpython/gui_modules/profile.py:1131
#, fuzzy
msgid "Line color"
-msgstr "Linie Farbe"
+msgstr "Linien-Farbe"
#: ../gui/wxpython/gui_modules/profile.py:1138
#: ../gui/wxpython/gui_modules/vdigit.py:1150
#, fuzzy
msgid "Line width"
-msgstr "Breite:"
+msgstr "Linienbreite"
#: ../gui/wxpython/gui_modules/profile.py:1148
#, fuzzy
@@ -195,7 +196,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:849
#, fuzzy
msgid "Color"
-msgstr "Farbe"
+msgstr "Farben"
#: ../gui/wxpython/gui_modules/profile.py:1192
msgid "Size"
@@ -226,12 +227,12 @@
#: ../gui/wxpython/gui_modules/profile.py:1256
#, fuzzy
msgid "Custom min"
-msgstr "Benutzerdefiniert"
+msgstr "kundenspezifisch"
#: ../gui/wxpython/gui_modules/profile.py:1264
#, fuzzy
msgid "Custom max"
#: ../gui/wxpython/gui_modules/profile.py:1272
#, fuzzy
@@ -246,7 +247,7 @@
#: ../gui/wxpython/gui_modules/profile.py:1301
#, fuzzy
msgid "Grid color"
-msgstr "Farbe"
+msgstr "Gitternetz Farbe"
#: ../gui/wxpython/gui_modules/profile.py:1308
msgid "Show grid"
@@ -321,7 +322,7 @@
"See 'Command output' window for details.\n"
"\n"
"Number of skipped lines: %(line)d"
-msgstr "Zeilen Zeilen"
+msgstr "Linie"
#: ../gui/wxpython/gui_modules/workspace.py:633
#: ../gui/wxpython/gui_modules/mapdisp_window.py:2387
@@ -386,7 +387,7 @@
#: ../gui/wxpython/gui_modules/wxgui_utils.py:298
#, fuzzy
msgid "Use as background vector map"
-msgstr "Benutze Vektor"
+msgstr "Vektor"
#: ../gui/wxpython/gui_modules/wxgui_utils.py:329
#: ../gui/wxpython/gui_modules/wxgui_utils.py:347
@@ -436,7 +437,7 @@
#: ../gui/wxpython/gui_modules/wxgui_utils.py:596
#, fuzzy
msgid "Layer group:"
-msgstr "Layer %d:"
+msgstr "Layer:"
#: ../gui/wxpython/gui_modules/wxgui_utils.py:601
#: ../gui/wxpython/gui_modules/wxgui_utils.py:1152
@@ -517,7 +518,7 @@
#: ../gui/wxpython/gui_modules/wxgui_utils.py:681
#, fuzzy
msgid "geodesic line"
-msgstr "Linien"
+msgstr "Linie"
#: ../gui/wxpython/gui_modules/wxgui_utils.py:684
msgid "rhumbline"
@@ -635,7 +636,7 @@
#: ../gui/wxpython/icons/icon.py:176
#, fuzzy
msgid "Print display"
-msgstr "Drucke"
+msgstr "Drucke Darstellung"
#: ../gui/wxpython/gui_modules/mapdisp.py:999
msgid "No map layer selected for querying."
@@ -657,12 +658,12 @@
#: ../gui/wxpython/gui_modules/mapdisp.py:1150
#, fuzzy
msgid "Query raster/vector map(s) (display mode)"
-msgstr "Abfragen Vektor"
+msgstr "Abfrage Raster Vektor Darstellung"
#: ../gui/wxpython/gui_modules/mapdisp.py:1158
#, fuzzy
msgid "Query vector map (edit mode)"
+msgstr "Abfrage Vektor"
#: ../gui/wxpython/gui_modules/mapdisp.py:1272
#, python-format
@@ -729,7 +730,7 @@
#: ../gui/wxpython/gui_modules/mapdisp.py:1574
#, fuzzy
msgid "Save display geometry to named region"
-msgstr "Speichern"
+msgstr "Darstellung"
#: ../gui/wxpython/gui_modules/dbm.py:71
#: ../gui/wxpython/gui_modules/dbm.py:260
@@ -750,7 +751,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:235
#, fuzzy
msgid "Can display only 256 columns."
-msgstr "Spalten."
#: ../gui/wxpython/gui_modules/dbm.py:269
#, fuzzy, python-format
@@ -831,7 +832,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:565
#, fuzzy
msgid "SQL Query"
-msgstr "Abfragen"
+msgstr "Abfrage"
#: ../gui/wxpython/gui_modules/dbm.py:588
#, fuzzy
@@ -927,19 +928,21 @@
#: ../gui/wxpython/gui_modules/dbm.py:974
#, fuzzy
msgid "Delete all records"
-msgstr "Löschen"
+msgstr "Alle"
#: ../gui/wxpython/gui_modules/dbm.py:976
#: ../gui/wxpython/gui_modules/gdialogs.py:737
#: ../gui/wxpython/gui_modules/gdialogs.py:1092
+#, fuzzy
msgid "Select all"
-msgstr ""
+msgstr "Alle"
#: ../gui/wxpython/gui_modules/dbm.py:977
#: ../gui/wxpython/gui_modules/gdialogs.py:738
#: ../gui/wxpython/gui_modules/gdialogs.py:1093
+#, fuzzy
msgid "Deselect all"
-msgstr ""
+msgstr "Alle"
#: ../gui/wxpython/gui_modules/dbm.py:979
#, fuzzy
@@ -1003,7 +1006,7 @@
#, python-format
#, fuzzy
msgid "Casting value '%(value)s' to %(type)s failed."
-msgstr "Eingabe fehlgeschlagen.."
+msgstr "fehlgeschlagen."
#: ../gui/wxpython/gui_modules/dbm.py:1244
msgid "Unable to insert new record."
@@ -1043,7 +1046,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:1488
#, fuzzy
msgid "Drop all columns"
-msgstr "Spalten"
+msgstr "Alle"
#: ../gui/wxpython/gui_modules/dbm.py:1551
#, fuzzy
@@ -1062,7 +1065,7 @@
"Loading attribute data failed.\n"
"\n"
"%s"
-msgstr "Daten"
+msgstr "fehlgeschlagen"
#: ../gui/wxpython/gui_modules/dbm.py:1738
@@ -1071,7 +1074,7 @@
"Invalid SQL select statement.\n"
"\n"
"%s"
-msgstr "Daten"
#: ../gui/wxpython/gui_modules/dbm.py:1823
msgid "Database connection"
@@ -1103,7 +1106,7 @@
#: ../gui/wxpython/gui_modules/gdialogs.py:1055
#, fuzzy
msgid "Layer"
-msgstr "Layer %d"
+msgstr "Layer"
#: ../gui/wxpython/gui_modules/dbm.py:2090
#: ../gui/wxpython/gui_modules/dbm.py:2201
@@ -1150,7 +1153,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:2244
#, fuzzy
msgid "Table name"
-msgstr "Tabelle"
+msgstr "Name"
#: ../gui/wxpython/gui_modules/dbm.py:2257
msgid "&Create table"
@@ -1167,7 +1170,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:2278
#, fuzzy
msgid "Layer description"
-msgstr "Layer %d"
+msgstr "Layer"
#: ../gui/wxpython/gui_modules/dbm.py:2339
#, fuzzy
@@ -1182,7 +1185,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:2381
#, fuzzy
msgid "Layer to detele"
-msgstr "Layer %d"
+msgstr "Layer"
#: ../gui/wxpython/gui_modules/dbm.py:2402
#, fuzzy
@@ -1207,7 +1210,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:2664
#, fuzzy
msgid "Unable to create new table. Table name or key column name is missing."
-msgstr "Tabelle."
+msgstr "Name Name."
#: ../gui/wxpython/gui_modules/dbm.py:2671
@@ -1219,7 +1222,7 @@
msgid ""
"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
"exists."
-msgstr "Vektor Vektor."
+msgstr "Vektor Vektor Layer."
#: ../gui/wxpython/gui_modules/dbm.py:2904
msgid "Database connection is not defined in DB file."
@@ -1231,7 +1234,7 @@
"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
"You can disable this message from digitization settings. Or you can create "
"and link attribute table to the vector map using Attribute Table Manager."
-msgstr "Vektor Vektor Vektor Tabelle."
+msgstr "Vektor Vektor Vektor."
#: ../gui/wxpython/gui_modules/dbm.py:2927
#, fuzzy
@@ -1254,7 +1257,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:2947
#, fuzzy
msgid "Display attributes"
-msgstr "Zeige Attribute"
#: ../gui/wxpython/gui_modules/dbm.py:2951
msgid "&Reload"
@@ -1391,8 +1394,9 @@
msgstr "Verfügbare Karten auflisten"
#: ../gui/wxpython/gui_modules/nviz_tools.py:163
+#, fuzzy
msgid "Height:"
-msgstr ""
+msgstr "Höhe:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:170
msgid "Z-exag:"
@@ -1582,7 +1586,7 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:422
#, fuzzy
msgid "Use for all loaded surfaces"
-msgstr "Benutze"
+msgstr "Alle"
#: ../gui/wxpython/gui_modules/nviz_tools.py:437
msgid "Mask zeros:"
@@ -1605,13 +1609,13 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:524
#, fuzzy
msgid "Show vector lines"
-msgstr "Vektor Zeilen"
+msgstr "Vektor"
#: ../gui/wxpython/gui_modules/nviz_tools.py:532
#: ../gui/wxpython/gui_modules/nviz_tools.py:1157
#, fuzzy
msgid "Vector lines"
-msgstr "Zeilen"
+msgstr "Vektorlinien"
#: ../gui/wxpython/gui_modules/nviz_tools.py:538
#: ../gui/wxpython/gui_modules/nviz_tools.py:1214
@@ -1624,7 +1628,7 @@
#: ../gui/wxpython/gui_modules/georect.py:1510
#, fuzzy
msgid "Color:"
-msgstr "Farbe:"
+msgstr "Farben:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:569
#: ../gui/wxpython/gui_modules/preferences.py:1175
@@ -1641,18 +1645,18 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:688
#, fuzzy
msgid "Height above surface:"
-msgstr "Karten auflisten"
+msgstr "Höhe:"
#: ../gui/wxpython/gui_modules/nviz_tools.py:618
#, fuzzy
msgid "Show vector points"
-msgstr "Vektor Punkte"
+msgstr "Vektor"
#: ../gui/wxpython/gui_modules/nviz_tools.py:626
#: ../gui/wxpython/gui_modules/nviz_tools.py:1182
#, fuzzy
msgid "Vector points"
-msgstr "Punkte"
+msgstr "Vektorpunkte"
#: ../gui/wxpython/gui_modules/nviz_tools.py:632
#, fuzzy
@@ -1738,8 +1742,9 @@
msgstr ""
#: ../gui/wxpython/gui_modules/nviz_tools.py:1054
+#, fuzzy
msgid "Height"
-msgstr ""
+msgstr "Höhe"
#: ../gui/wxpython/gui_modules/nviz_tools.py:1073
#, fuzzy
@@ -1802,17 +1807,17 @@
#: ../gui/wxpython/gui_modules/nviz_tools.py:2332
#, fuzzy
msgid "Layer properties"
-msgstr "Layer %d"
+msgstr "Layer"
#: ../gui/wxpython/gui_modules/nviz_tools.py:2443
msgid "Vector map <%s> is 3D"
-msgstr "Vektorkarte %s nicht gefunden."
+msgstr "Vektorkarte <%s> ist 3D."
#: ../gui/wxpython/gui_modules/nviz_tools.py:2446
msgid "Vector map <%s> is 2D"
+msgstr "Vektorkarte <%s> ist 2D."
#: ../gui/wxpython/gui_modules/nviz_tools.py:2448
@@ -1824,20 +1829,24 @@
msgstr ""
#: ../gui/wxpython/gui_modules/preferences.py:494
+#, fuzzy
msgid "Collapse all except PERMANENT and current"
-msgstr ""
+msgstr "Alle"
#: ../gui/wxpython/gui_modules/preferences.py:495
+#, fuzzy
msgid "Collapse all except PERMANENT"
-msgstr ""
+msgstr "Alle"
#: ../gui/wxpython/gui_modules/preferences.py:496
+#, fuzzy
msgid "Collapse all"
-msgstr ""
+msgstr "Alle"
#: ../gui/wxpython/gui_modules/preferences.py:497
+#, fuzzy
msgid "Expand all"
-msgstr ""
+msgstr "Alle"
#: ../gui/wxpython/gui_modules/preferences.py:499
#, fuzzy
@@ -1888,8 +1897,8 @@
" Details: %(detail)s\n"
" Line: '%(line)s'"
msgstr ""
+"fehlgeschlagen\n"
"\n"
-"\n"
" Linie"
#: ../gui/wxpython/gui_modules/preferences.py:633
@@ -1903,7 +1912,7 @@
"Writing settings to file <%(file)s> failed.\n"
"\n"
"Details: %(detail)s"
-msgstr "Eingabe fehlgeschlagen."
#: ../gui/wxpython/gui_modules/preferences.py:763
msgid "Unable to set "
@@ -1939,12 +1948,12 @@
msgid ""
"Save current position and size of Layer Manager window and opened Map "
"Display window(s) and use as default for next sessions."
-msgstr "Speichern."
+msgstr "Layer Darstellung."
#: ../gui/wxpython/gui_modules/preferences.py:917
#, fuzzy
msgid "Layer Manager settings"
-msgstr "Layer %d"
+msgstr "Layer"
#: ../gui/wxpython/gui_modules/preferences.py:929
#, fuzzy
@@ -2084,7 +2093,7 @@
#: ../gui/wxpython/gui_modules/preferences.py:1351
#, fuzzy
msgid "Suppress positioning Layer Manager window"
-msgstr "Layer %d"
+msgstr "Layer"
#: ../gui/wxpython/gui_modules/preferences.py:1372
#, fuzzy
@@ -2184,7 +2193,7 @@
#: ../gui/wxpython/gui_modules/toolbars.py:807
#, fuzzy
msgid "Copy features from (background) vector map"
-msgstr "Kopiere Karten Vektor"
+msgstr "Vektor"
#: ../gui/wxpython/gui_modules/toolbars.py:815
#, fuzzy
@@ -2199,7 +2208,7 @@
#: ../gui/wxpython/gui_modules/toolbars.py:831
#, fuzzy
msgid "Break selected lines/boundaries at intersection"
-msgstr "Zeilen Umrandung"
+msgstr "Teile"
#: ../gui/wxpython/gui_modules/toolbars.py:839
#, fuzzy
@@ -2214,7 +2223,7 @@
#: ../gui/wxpython/gui_modules/toolbars.py:855
#, fuzzy
msgid "Query features"
-msgstr "Abfragen"
+msgstr "Abfrage"
#: ../gui/wxpython/gui_modules/toolbars.py:863
#, fuzzy
@@ -2241,7 +2250,7 @@
#: ../gui/wxpython/gui_modules/toolbars.py:1138
msgid "Do you want to save changes in vector map <%s>?"
-msgstr "Speichern Vektor?"
+msgstr "Vektor?"
#: ../gui/wxpython/gui_modules/toolbars.py:1140
#, fuzzy
@@ -2251,13 +2260,13 @@
#: ../gui/wxpython/gui_modules/toolbars.py:1147
msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
-msgstr "Topologie Vektor."
+msgstr "Vektor."
#: ../gui/wxpython/gui_modules/toolbars.py:1211
#: ../gui/wxpython/gui_modules/toolbars.py:1216
#, fuzzy
msgid "New vector map"
-msgstr "Neu Vektor"
+msgstr "Vektor"
#: ../gui/wxpython/gui_modules/menuform.py:138
#: ../gui/wxpython/gui_modules/menuform.py:1249
@@ -2843,7 +2852,7 @@
#: ../gui/wxpython/gui_modules/gcmd.py:362
#, fuzzy
msgid "Execution failed:"
-msgstr "Eingabe fehlgeschlagen.:"
+msgstr "fehlgeschlagen:"
#: ../gui/wxpython/gui_modules/gcmd.py:365
msgid "Details:"
@@ -2936,7 +2945,7 @@
#: ../gui/wxpython/gui_modules/georect.py:544
#, fuzzy
msgid "Select image/map to display for ground control point (GCP) creation"
-msgstr "Darstellung Punkte"
+msgstr "Darstellung Punkt"
#: ../gui/wxpython/gui_modules/georect.py:552
#, fuzzy
@@ -3006,12 +3015,12 @@
#: ../gui/wxpython/gui_modules/georect.py:893
#, fuzzy
msgid "Writing POINTS file failed"
#: ../gui/wxpython/gui_modules/georect.py:930
#, fuzzy
msgid "Reading POINTS file failed"
#: ../gui/wxpython/gui_modules/georect.py:975
#, fuzzy
@@ -3118,7 +3127,7 @@
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:489
#, fuzzy
msgid "failed"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:491
#, python-format
@@ -3133,7 +3142,7 @@
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:546
#, fuzzy
msgid "Raster map"
-msgstr "Rasterkarte"
+msgstr "Raster"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:550
#, fuzzy
@@ -3152,12 +3161,12 @@
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:609
msgid "Loading vector map <%(name)s> (%(type)s) failed"
-msgstr "Vektor"
+msgstr "Vektor Name fehlgeschlagen"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:660
msgid "Unable to unload vector map <%(name)s> (%(type)s)"
-msgstr "Vektor"
+msgstr "Vektor Name"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:663
@@ -3167,7 +3176,7 @@
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1185
msgid "Vector point layer not found (id=%d)"
+msgstr "Vektor Punkt"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1187
@@ -3180,12 +3189,12 @@
"Setting data layer properties failed.\n"
"\n"
"%s"
-msgstr "Daten"
#: ../gui/wxpython/gui_modules/colorrules.py:94
#, fuzzy
msgid "Create new color table for raster map"
-msgstr "Farbe"
+msgstr "Raster"
#: ../gui/wxpython/gui_modules/colorrules.py:96
#: ../gui/wxpython/gui_modules/colorrules.py:389
@@ -3196,7 +3205,7 @@
#: ../gui/wxpython/gui_modules/colorrules.py:98
#, fuzzy
msgid "Create new color table for vector map"
-msgstr "Farbe Vektor"
+msgstr "Vektor"
#: ../gui/wxpython/gui_modules/colorrules.py:100
#, fuzzy
@@ -3221,7 +3230,7 @@
#: ../gui/wxpython/gui_modules/colorrules.py:128
#, fuzzy
msgid "Layer:"
-msgstr "Ebene:"
+msgstr "Layer:"
#: ../gui/wxpython/gui_modules/colorrules.py:130
#, fuzzy
@@ -3340,7 +3349,7 @@
#: ../gui/wxpython/gui_modules/render.py:938
#, fuzzy
msgid "ERROR: Rendering failed"
-msgstr "Rendering Eingabe fehlgeschlagen."
+msgstr "Rendering fehlgeschlagen"
#: ../gui/wxpython/gui_modules/render.py:984
#: ../gui/wxpython/gui_modules/render.py:1071
@@ -3374,12 +3383,12 @@
"\n"
"Data are probably corrupted, try to run v.build to rebuild the topology "
"(Vector->Develop vector map->Create/rebuild topology)."
-msgstr "Vektor Topologie Vektor Topologie."
#: ../gui/wxpython/gui_modules/vdigit.py:648
#, fuzzy
msgid "Undo failed, data corrupted."
-msgstr "Daten."
#: ../gui/wxpython/gui_modules/vdigit.py:1072
msgid "Apply changes for this session"
@@ -3429,8 +3438,9 @@
msgstr ""
#: ../gui/wxpython/gui_modules/vdigit.py:1240
+#, fuzzy
msgid "By default are selected all features overlapping selection bounding box "
-msgstr ""
+msgstr "Alle "
#: ../gui/wxpython/gui_modules/vdigit.py:1243
msgid "Check for duplicates"
@@ -3439,12 +3449,12 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1255
#, fuzzy
msgid "Digitize line features"
-msgstr "Digitalisieren"
+msgstr "Linie"
#: ../gui/wxpython/gui_modules/vdigit.py:1258
#, fuzzy
msgid "Break lines at intersection"
-msgstr "Zeilen"
+msgstr "Teile"
#: ../gui/wxpython/gui_modules/vdigit.py:1268
#, fuzzy
@@ -3459,7 +3469,7 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1284
#, fuzzy
msgid "Query tool"
-msgstr "Abfragen"
+msgstr "Abfrage-Werkzeug"
#: ../gui/wxpython/gui_modules/vdigit.py:1291
msgid "Choose query tool"
@@ -3563,12 +3573,12 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1459
#, fuzzy
msgid "Boundary (no area)"
-msgstr "Boundary (keine Fläche)"
+msgstr "Fläche"
#: ../gui/wxpython/gui_modules/vdigit.py:1460
#, fuzzy
msgid "Boundary (one area)"
-msgstr "Fläche:\n"
+msgstr "Fläche"
#: ../gui/wxpython/gui_modules/vdigit.py:1461
#, fuzzy
@@ -3578,22 +3588,22 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1462
#, fuzzy
msgid "Centroid (in area)"
-msgstr "Zentroid (in Fläche)"
+msgstr "Fläche"
#: ../gui/wxpython/gui_modules/vdigit.py:1463
#, fuzzy
msgid "Centroid (outside area)"
-msgstr "Zentroid (außerhalb einer Fläche)"
+msgstr "Fläche"
#: ../gui/wxpython/gui_modules/vdigit.py:1464
#, fuzzy
msgid "Centroid (duplicate in area)"
-msgstr "Zentroid (Duplikat in einer Fläche)"
+msgstr "Fläche"
#: ../gui/wxpython/gui_modules/vdigit.py:1465
#, fuzzy
msgid "Node (one line)"
-msgstr "Linien"
+msgstr "Linie"
#: ../gui/wxpython/gui_modules/vdigit.py:1466
#, fuzzy
@@ -3607,7 +3617,7 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1468
#, fuzzy
msgid "Area (closed boundary + centroid)"
-msgstr "Grenzen"
+msgstr "Grenze Zentroid"
#: ../gui/wxpython/gui_modules/vdigit.py:1469
#, fuzzy
@@ -3667,7 +3677,7 @@
#: ../gui/wxpython/gui_modules/vdigit.py:1930
#, fuzzy
msgid "Delete all"
-msgstr "Löschen"
+msgstr "Alle"
#: ../gui/wxpython/gui_modules/vdigit.py:2075
#, fuzzy
@@ -3704,7 +3714,7 @@
#: ../gui/wxpython/gui_modules/vdigit.py:2383
#, fuzzy
msgid "Layer (Categories)"
-msgstr "Kategorien"
+msgstr "Layer"
#: ../gui/wxpython/gui_modules/gdialogs.py:58
#, fuzzy
@@ -3741,7 +3751,7 @@
#: ../gui/wxpython/gui_modules/gdialogs.py:205
msgid "New vector map <%s> created"
+msgstr "Vektor"
#: ../gui/wxpython/gui_modules/gdialogs.py:227
msgid "Load region:"
@@ -3865,12 +3875,12 @@
#: ../gui/wxpython/gui_modules/gdialogs.py:855
#, fuzzy
msgid "&Import"
-msgstr "&Importieren"
+msgstr "&Import"
#: ../gui/wxpython/gui_modules/gdialogs.py:856
#, fuzzy
msgid "Import selected layers"
-msgstr "Importieren"
+msgstr "Import"
#: ../gui/wxpython/gui_modules/gdialogs.py:896
@@ -3880,17 +3890,17 @@
#: ../gui/wxpython/gui_modules/gdialogs.py:1056
#, fuzzy
msgid "Layer name"
-msgstr "Layer %d Name"
+msgstr "Layer Name"
#: ../gui/wxpython/gui_modules/gdialogs.py:1057
#, fuzzy
msgid "Output vector map name"
-msgstr "Ergebnis Vektor"
#: ../gui/wxpython/gui_modules/gdialogs.py:1139
#, fuzzy
msgid "Set Map Layer Opacity"
-msgstr "Layer %d"
+msgstr "Layer"
#: ../gui/wxpython/gui_modules/gdialogs.py:1163
#, fuzzy
@@ -3997,7 +4007,7 @@
#: ../gui/wxpython/icons/icon.py:174
#, fuzzy
msgid "Save display to PNG file"
-msgstr "Speichern"
#: ../gui/wxpython/icons/icon.py:179
msgid "Start new display"
@@ -4099,7 +4109,7 @@
#: ../gui/wxpython/icons/icon.py:222
#, fuzzy
msgid "Add geodesic line layer"
-msgstr "Linien"
+msgstr "Linie"
#: ../gui/wxpython/icons/icon.py:224
msgid "Add rhumbline layer"
@@ -4118,33 +4128,33 @@
#: ../gui/wxpython/icons/icon.py:233
#, fuzzy
msgid "Digitize new point"
-msgstr "Neuen Punkt digitalisieren"
+msgstr "Punkt"
#: ../gui/wxpython/icons/icon.py:234 ../gui/wxpython/icons/icon.py:243
#, fuzzy
msgid "Left: new point"
-msgstr "Punkte"
+msgstr "Punkt"
#: ../gui/wxpython/icons/icon.py:236
#, fuzzy
msgid "Digitize new line"
-msgstr "Neue Linie digitalisieren"
+msgstr "Linie"
#: ../gui/wxpython/icons/icon.py:237 ../gui/wxpython/icons/icon.py:240
#: ../gui/wxpython/icons/icon.py:261
#, fuzzy
msgid "Left: new point; Middle: undo last point; Right: close line"
-msgstr "Punkte Punkte Linien"
+msgstr "Punkt Punkt Linie"
#: ../gui/wxpython/icons/icon.py:239
#, fuzzy
msgid "Digitize new boundary"
-msgstr "Digitalisiere neue Umrandung (Boundary)"
+msgstr "Grenze"
#: ../gui/wxpython/icons/icon.py:242
#, fuzzy
msgid "Digitize new centroid"
-msgstr "Digitalisiere neuen Zentroid"
+msgstr "Zentroid"
#: ../gui/wxpython/icons/icon.py:245
msgid "Add new vertex"
@@ -4174,12 +4184,12 @@
#: ../gui/wxpython/icons/icon.py:257
#, fuzzy
msgid "Display/update categories"
#: ../gui/wxpython/icons/icon.py:260
#, fuzzy
msgid "Edit line/boundary"
-msgstr "Editiere Linie/Boundary"
+msgstr "Linie Grenze"
#: ../gui/wxpython/icons/icon.py:263
#, fuzzy
@@ -4204,7 +4214,7 @@
#: ../gui/wxpython/icons/icon.py:275
#, fuzzy
msgid "Split line/boundary"
-msgstr "Linien Grenzen"
#: ../gui/wxpython/icons/icon.py:278
#, fuzzy
@@ -4588,7 +4598,7 @@
#: ../gui/wxpython/menustrings.py:19
#, fuzzy
msgid "Import raster data using GDAL"
-msgstr "Importieren Daten"
+msgstr "Import Raster"
#: ../gui/wxpython/menustrings.py:20
msgid "Import GDAL supported raster file into a binary raster map layer."
@@ -4597,7 +4607,7 @@
#: ../gui/wxpython/menustrings.py:21
#, fuzzy
msgid "Multiple raster data import using GDAL"
-msgstr "Daten"
+msgstr "Raster"
#: ../gui/wxpython/menustrings.py:22
#, fuzzy
@@ -4712,7 +4722,7 @@
#: ../gui/wxpython/menustrings.py:46
#, fuzzy
msgid "Import vector data using OGR"
-msgstr "Importieren Vektor Daten"
+msgstr "Import Vektor"
#: ../gui/wxpython/menustrings.py:47
msgid "Convert OGR vector layers to GRASS vector map."
@@ -4721,7 +4731,7 @@
#: ../gui/wxpython/menustrings.py:48
#, fuzzy
msgid "Multiple vector data import using OGR"
-msgstr "Vektor Daten"
+msgstr "Vektor"
#: ../gui/wxpython/menustrings.py:49
#, fuzzy
@@ -5029,7 +5039,7 @@
#: ../gui/wxpython/menustrings.py:115
#, fuzzy
msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
-msgstr "Vektor."
+msgstr "Vektor Format."
#: ../gui/wxpython/menustrings.py:117
msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
@@ -5139,7 +5149,7 @@
#: ../gui/wxpython/menustrings.py:143
#, fuzzy
msgid "Raster to vector"
-msgstr "Raster zu Vektorkonvertierung"
+msgstr "Raster Vektor"
#: ../gui/wxpython/menustrings.py:144
msgid "Converts a raster map into a vector map layer."
@@ -5148,7 +5158,7 @@
#: ../gui/wxpython/menustrings.py:145
#, fuzzy
msgid "Raster series to volume"
-msgstr "Rasterkartenserie zu Volumina"
+msgstr "Raster"
#: ../gui/wxpython/menustrings.py:146
#, fuzzy
@@ -5158,7 +5168,7 @@
#: ../gui/wxpython/menustrings.py:147
#, fuzzy
msgid "Raster 2.5D to volume"
-msgstr "2.5D Rasterkarte zu Volumina"
+msgstr "Raster"
#: ../gui/wxpython/menustrings.py:148
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
@@ -5167,7 +5177,7 @@
#: ../gui/wxpython/menustrings.py:149
#, fuzzy
msgid "Vector to raster"
-msgstr "Vektor -> Raster"
+msgstr "Vektor Raster"
#: ../gui/wxpython/menustrings.py:150
msgid "Converts a binary GRASS vector map layer into a GRASS raster map layer."
@@ -5193,12 +5203,12 @@
#: ../gui/wxpython/menustrings.py:154
#, fuzzy
msgid "Performs transformation of 2D vector features to 3D."
-msgstr "Vektor."
+msgstr "Führt die Transformation von 2D Vektorfeature nach 3D durch."
#: ../gui/wxpython/menustrings.py:155
#, fuzzy
msgid "Sites to vector"
-msgstr "Sites (GRASS 5.0) -> Vektor"
+msgstr "Vektor"
#: ../gui/wxpython/menustrings.py:156
msgid "Converts a GRASS site_lists file into a vector map."
@@ -5207,7 +5217,7 @@
#: ../gui/wxpython/menustrings.py:157
#, fuzzy
msgid "Volume to raster series"
-msgstr "Volumen zu Rasterkartenserien"
+msgstr "Volumen Raster"
#: ../gui/wxpython/menustrings.py:158
#, fuzzy
@@ -5516,12 +5526,12 @@
#: ../gui/wxpython/menustrings.py:228
#, fuzzy
msgid "Color tables (stddev)"
-msgstr "Tabelle kopieren"
+msgstr "Farben"
#: ../gui/wxpython/menustrings.py:229
#, fuzzy
msgid "Set color rules based on stddev from a map's mean value."
-msgstr "Farbe."
+msgstr "Bestimme Farbregeln basierend auf den Standardabweichungen."
#: ../gui/wxpython/menustrings.py:230 ../gui/wxpython/menustrings.py:487
msgid "Color rules"
@@ -5603,7 +5613,7 @@
#: ../gui/wxpython/menustrings.py:248
#, fuzzy
msgid "Neighborhood analysis"
-msgstr "Nachbarschaftsanalysen"
+msgstr "Nachbarschaft"
#: ../gui/wxpython/menustrings.py:249
msgid "Moving window"
@@ -6225,7 +6235,7 @@
msgid ""
"It optionally produces raster maps to contain backlink UTM coordinates for "
"tracing spread paths."
-msgstr "Raster."
+msgstr "Dies erzeugt optional Rasterkarten mit 'backlink'-UTM-Koordinaten, um Ausbreitungspfade nachzuzeichnen."
#: ../gui/wxpython/menustrings.py:365
#, fuzzy
@@ -6270,7 +6280,9 @@
msgid ""
"Creates a new map layer whose category values are based upon a "
"reclassification of the categories in an existing raster map layer."
-msgstr "Kategorien."
+msgstr ""
+"Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der "
+"Kategorien einer existierenden Rasterkarte basieren."
#: ../gui/wxpython/menustrings.py:374
msgid "Recode interactively"
@@ -6291,7 +6303,7 @@
#: ../gui/wxpython/menustrings.py:377
#, fuzzy
msgid "r.recode.rules - Use ascii rules file to recode categories in raster map"
-msgstr "Benutze Kategorien"
+msgstr "Raster"
#: ../gui/wxpython/menustrings.py:378
msgid "Rescale"
@@ -6340,7 +6352,7 @@
#: ../gui/wxpython/menustrings.py:387
#, fuzzy
msgid "Random cells and vector points"
-msgstr "Zufällige Zellen und Vektorpunkte aus einer Rasterkarte erzeugen"
+msgstr "Vektor"
#: ../gui/wxpython/menustrings.py:388
msgid ""
@@ -6402,7 +6414,9 @@
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
-msgstr "Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung (inclination), Ausrichtung (azimuth) und einem Punkt."
+msgstr ""
+"Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung "
+"(inclination), Ausrichtung (azimuth) und einem Punkt."
#: ../gui/wxpython/menustrings.py:398
#, fuzzy
@@ -6436,7 +6450,7 @@
#: ../gui/wxpython/menustrings.py:403
#, fuzzy
msgid "Produces a vector map layer of specified contours from a raster map layer."
-msgstr "Vektor."
+msgstr "Vektor Raster."
#: ../gui/wxpython/menustrings.py:404
#, fuzzy
@@ -6446,7 +6460,7 @@
#: ../gui/wxpython/menustrings.py:405
#, fuzzy
msgid "Bilinear from raster points"
-msgstr "Rasterpunkte mit der bilinearen Interpolation errechnen"
+msgstr "Raster"
#: ../gui/wxpython/menustrings.py:406
#, fuzzy
@@ -6456,7 +6470,7 @@
#: ../gui/wxpython/menustrings.py:407
#, fuzzy
msgid "Bilinear and bicubic from vector points"
+msgstr "Vektor"
#: ../gui/wxpython/menustrings.py:408
msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
@@ -6465,7 +6479,7 @@
#: ../gui/wxpython/menustrings.py:409
#, fuzzy
msgid "IDW from raster points"
-msgstr "Interpolation von Rasterkonturen"
+msgstr "Raster"
#: ../gui/wxpython/menustrings.py:410
#, fuzzy
@@ -6475,19 +6489,21 @@
#: ../gui/wxpython/menustrings.py:411
#, fuzzy
msgid "IDW from vector points"
-msgstr "Mit Vektorpunkten arbeiten"
+msgstr "Vektor"
#: ../gui/wxpython/menustrings.py:412
#, fuzzy
msgid ""
"Surface interpolation from vector point data by Inverse Distance Squared "
"Weighting."
-msgstr "Vektor Daten."
+msgstr ""
+"Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance "
+"Squared Weighting."
#: ../gui/wxpython/menustrings.py:413
#, fuzzy
msgid "Raster contours"
+msgstr "Raster"
#: ../gui/wxpython/menustrings.py:414
#, fuzzy
@@ -6507,7 +6523,7 @@
"Spatial approximation and topographic analysis from given point or isoline "
"data in vector format to floating point raster format using regularized "
"spline with tension."
-msgstr "Daten Vektor."
+msgstr "Räumliche Approximation und topographische Analyse auf Basis gegebener Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-Rasterkarte geschrieben."
#: ../gui/wxpython/menustrings.py:417
msgid "Fill NULL cells"
@@ -6516,7 +6532,9 @@
#: ../gui/wxpython/menustrings.py:418
#, fuzzy
msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-msgstr "Daten Flächen"
+msgstr ""
+"Fülle Flächen ohne Daten in Rasterkarten mit Hilfe der v.surf.rst Spline-"
+"Interpolation."
#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:653
msgid "Report and statistics"
@@ -6530,7 +6548,7 @@
#: ../gui/wxpython/menustrings.py:421
#, fuzzy
msgid "Output basic information about a raster map layer."
-msgstr "Ergebnis."
+msgstr "Gibt grundlegende Informationen über eine Rasterkarte aus."
#: ../gui/wxpython/menustrings.py:422
#, fuzzy
@@ -6576,7 +6594,7 @@
#: ../gui/wxpython/menustrings.py:430
#, fuzzy
msgid "Sum area by raster map and category"
-msgstr "Fläche:\n Raster"
+msgstr "Fläche Raster"
#: ../gui/wxpython/menustrings.py:431
#, fuzzy
@@ -6592,12 +6610,14 @@
msgid ""
"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
"vector points map containing the calculated centroids of these clumps."
-msgstr "Daten Vektor Punkte Zentroide."
+msgstr ""
+"Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-"
+"Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
#: ../gui/wxpython/menustrings.py:434
#, fuzzy
msgid "Total corrected area"
-msgstr "Fläche:\n"
+msgstr "Fläche"
#: ../gui/wxpython/menustrings.py:435
#, fuzzy
@@ -6671,7 +6691,9 @@
msgid ""
"Tabulates the mutual occurrence (coincidence) of categories for two raster "
"map layers."
+msgstr ""
+"Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei "
+"Rasterkarten."
#: ../gui/wxpython/menustrings.py:448
#, fuzzy
@@ -6698,7 +6720,9 @@
msgid ""
"Edits a vector map, allows adding, deleting and modifying selected vector "
"features."
+msgstr ""
+"Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern "
+"ausgewählter Vektor Feature."
#: ../gui/wxpython/menustrings.py:454
#, fuzzy
@@ -6708,7 +6732,7 @@
#: ../gui/wxpython/menustrings.py:455
#, fuzzy
msgid "Creates topology for GRASS vector map."
+msgstr "Erzeugt Topologie für GRASS Vektorkarten."
#: ../gui/wxpython/menustrings.py:456
#, fuzzy
@@ -6718,7 +6742,7 @@
#: ../gui/wxpython/menustrings.py:457
#, fuzzy
msgid "Toolset for cleaning topology of vector map."
+msgstr "Werkzeugkasten zum Säubern Topologie von Vektorkarten."
#: ../gui/wxpython/menustrings.py:458
#, fuzzy
@@ -6736,8 +6760,9 @@
msgstr "Vektortypen konvertieren"
#: ../gui/wxpython/menustrings.py:461
+#, fuzzy
msgid "Change the type of geometry elements."
-msgstr ""
+msgstr "Ändere die Art der geometrischen Elemente."
#: ../gui/wxpython/menustrings.py:462
#, fuzzy
@@ -6747,7 +6772,7 @@
#: ../gui/wxpython/menustrings.py:463
#, fuzzy
msgid "Adds missing centroids to closed boundaries."
-msgstr "Zentroide Umrandung."
+msgstr "Fügt fehlende Zentroide zu geschlossenen Grenzen hinzu."
#: ../gui/wxpython/menustrings.py:464
msgid "Build polylines"
@@ -6756,7 +6781,7 @@
#: ../gui/wxpython/menustrings.py:465
#, fuzzy
msgid "Builds polylines from lines or boundaries."
-msgstr "Zeilen Umrandung."
+msgstr "Erstellt Poly-Linien aus Linien und Grenzen."
#: ../gui/wxpython/menustrings.py:466
#, fuzzy
@@ -6766,7 +6791,7 @@
#: ../gui/wxpython/menustrings.py:467
#, fuzzy
msgid "Creates points/segments from input vector lines and positions."
-msgstr "Punkte Vektor Zeilen."
+msgstr "Erzeuge Punkte/Segmente aus den Input Vektorlinien und Positionen."
#: ../gui/wxpython/menustrings.py:468
#, fuzzy
@@ -6776,7 +6801,7 @@
#: ../gui/wxpython/menustrings.py:469
#, fuzzy
msgid "Create parallel line to input lines"
-msgstr "Zeilen"
+msgstr "Erzeuge eine parallele Linie zu der eingegebenen Linie."
#: ../gui/wxpython/menustrings.py:470
#, fuzzy
@@ -6788,17 +6813,19 @@
msgid ""
"Dissolves boundaries between adjacent areas sharing a common category number "
"or attribute."
-msgstr "Umrandung Flächen."
+msgstr ""
+"Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder "
+"gleichem Attributwert auf."
#: ../gui/wxpython/menustrings.py:472
#, fuzzy
msgid "Create 3D vector over raster"
-msgstr "Vektorpuffer erstellen"
#: ../gui/wxpython/menustrings.py:473
#, fuzzy
msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr "Vektor."
+msgstr "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit Höheninformationen."
#: ../gui/wxpython/menustrings.py:474
#, fuzzy
@@ -6808,7 +6835,7 @@
#: ../gui/wxpython/menustrings.py:475
#, fuzzy
msgid "Extrudes flat vector object to 3D with defined height."
-msgstr "Vektor."
+msgstr "Presst flache Vektorobjekte in eine 3D-Form mit definierter Höhe."
#: ../gui/wxpython/menustrings.py:476
msgid "Link to OGR"
@@ -6817,7 +6844,9 @@
#: ../gui/wxpython/menustrings.py:477
#, fuzzy
msgid "Creates a new vector as a read-only link to OGR layer."
-msgstr "Vektor."
+msgstr ""
+"Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu "
+"einem OGR-Layer."
#: ../gui/wxpython/menustrings.py:478
#, fuzzy
@@ -6827,7 +6856,7 @@
#: ../gui/wxpython/menustrings.py:479
#, fuzzy
msgid "Creates paint labels for a vector map from attached attributes."
-msgstr "Vektor."
+msgstr "Erzeugt Paint-Label für Vektorkarten von zugehörigen Attributen."
#: ../gui/wxpython/menustrings.py:480
#, fuzzy
@@ -6839,7 +6868,7 @@
msgid ""
"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
"vector map."
-msgstr "Vektor."
+msgstr "Führt eine affine Transformation (schieben, skalieren und rotieren oder GPCs) von Vektorkarten durch."
#: ../gui/wxpython/menustrings.py:482
#, fuzzy
@@ -6849,39 +6878,41 @@
#: ../gui/wxpython/menustrings.py:483
#, fuzzy
msgid "Allows projection conversion of vector maps."
-msgstr "Vektor."
+msgstr "Ermöglicht die Umwandlung der Projektion von Vektorkarten."
#: ../gui/wxpython/menustrings.py:486
#, fuzzy
msgid "Set color rules for features in a vector using a numeric attribute column."
-msgstr "Farbe Vektor."
+msgstr ""
+"Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer "
+"numerischen Spalte der Attributtabelle."
#: ../gui/wxpython/menustrings.py:489
#, fuzzy
msgid "Query with attributes"
-msgstr "Nach Attributen abfragen"
+msgstr "Abfrage"
#: ../gui/wxpython/menustrings.py:490
#, fuzzy
msgid ""
"Selects vector objects from an existing vector map and creates a new map "
"containing only the selected objects."
+msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
#: ../gui/wxpython/menustrings.py:491
#, fuzzy
msgid "Query with coordinate(s)"
-msgstr "Abfragen unter Koordinaten"
+msgstr "Abfrage"
#: ../gui/wxpython/menustrings.py:492
#, fuzzy
msgid "Queries a vector map layer at given locations."
-msgstr "Vektor."
+msgstr "Fraget Vektorkarten an gegebenen Positionen ab."
#: ../gui/wxpython/menustrings.py:493
#, fuzzy
msgid "Query with another vector map"
#: ../gui/wxpython/menustrings.py:494
#, fuzzy
@@ -6896,7 +6927,9 @@
#: ../gui/wxpython/menustrings.py:496
#, fuzzy
msgid "Creates a buffer around features of given type (areas must contain centroid)."
-msgstr "Flächen."
+msgstr ""
+"Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen "
+"Zentroide enthalten)."
#: ../gui/wxpython/menustrings.py:497
#, fuzzy
@@ -6910,7 +6943,7 @@
#: ../gui/wxpython/menustrings.py:499
#, fuzzy
msgid "Detects the object's edges from a LIDAR data set."
-msgstr "Daten."
+msgstr "Erkennt Kanten von Objekten aus einem LIDAR-Datensatz."
#: ../gui/wxpython/menustrings.py:500
msgid "Detect interiors"
@@ -6944,8 +6977,9 @@
msgstr "Erzeuge Tabelle"
#: ../gui/wxpython/menustrings.py:506
+#, fuzzy
msgid "Create Linear Reference System"
-msgstr ""
+msgstr "Erzeuge Linearesreferenzsystem"
#: ../gui/wxpython/menustrings.py:507
#, fuzzy
@@ -6955,7 +6989,7 @@
#: ../gui/wxpython/menustrings.py:508
#, fuzzy
msgid "Create stationing from input lines, and linear reference system"
-msgstr "Zeilen"
+msgstr "Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
#: ../gui/wxpython/menustrings.py:509
#, fuzzy
@@ -6967,19 +7001,19 @@
msgid ""
"Creates points/segments from input lines, linear reference system and "
"positions read from stdin or a file."
-msgstr "Punkte Zeilen."
+msgstr "Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des Linearenreferenzsystems und Positionen von stdin oder einer Datei."
#: ../gui/wxpython/menustrings.py:511
#, fuzzy
msgid "Find line id and offset"
-msgstr "Linien"
+msgstr "Linie"
#: ../gui/wxpython/menustrings.py:512
#, fuzzy
msgid ""
"Finds line id and real km+offset for given points in vector map using linear "
"reference system."
-msgstr "Punkte Vektor."
+msgstr "Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
#: ../gui/wxpython/menustrings.py:513
#, fuzzy
@@ -6991,7 +7025,9 @@
msgid ""
"Finds the nearest element in vector map 'to' for elements in vector map "
"'from'."
+msgstr ""
+"Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der "
+"Vektorkarte 'from'. "
#: ../gui/wxpython/menustrings.py:515
#, fuzzy
@@ -7004,10 +7040,11 @@
msgstr "Subnetze ausweisen"
#: ../gui/wxpython/menustrings.py:517
+#, fuzzy
msgid ""
"Centre node must be opened (costs >= 0). Costs of centre node are used in "
"calculation"
-msgstr ""
+msgstr "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knoten gehen im die Berechnung mit ein."
#: ../gui/wxpython/menustrings.py:518
#, fuzzy
@@ -7024,8 +7061,9 @@
msgstr "Sichtbarkeitsanalyse"
#: ../gui/wxpython/menustrings.py:521
+#, fuzzy
msgid "Visibility graph construction."
-msgstr ""
+msgstr "Konstruktion des Sichtbarkeits-Graphen."
#: ../gui/wxpython/menustrings.py:522
msgid "Shortest path"
@@ -7034,7 +7072,7 @@
#: ../gui/wxpython/menustrings.py:523
#, fuzzy
msgid "Finds shortest path on vector network."
-msgstr "Vektor."
+msgstr "Findet den kürzesten Weg in einem Vektor-Netzwerk."
#: ../gui/wxpython/menustrings.py:524
#, fuzzy
@@ -7042,11 +7080,12 @@
msgstr "Teile Linie"
#: ../gui/wxpython/menustrings.py:525
+#, fuzzy
msgid ""
"Splits net to bands between cost isolines (direction from centre). Centre "
"node must be opened (costs >= 0). Costs of centre node are used in "
"calculation."
-msgstr ""
+msgstr "Teilt das Netz in Bänder zwischen Isokostenlinien (Richtung vom Zentrum). Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knotens gehen in die Berechnung ein."
#: ../gui/wxpython/menustrings.py:526
#, fuzzy
@@ -7054,10 +7093,11 @@
msgstr "Steiner-Problematik"
#: ../gui/wxpython/menustrings.py:527
+#, fuzzy
msgid ""
"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
"is used in this module so the result may be sub optimal"
-msgstr ""
+msgstr "Bedenken Sie das 'Minimum Steiner Tree'-Problem ist NP-hart und in diesem Modul wird ein heuristischer Algorithmus verwenden, so kann das Ergebnis suboptimal sein."
#: ../gui/wxpython/menustrings.py:528
#, fuzzy
@@ -7065,20 +7105,21 @@
msgstr "Traveling-Salesman-Problematik"
#: ../gui/wxpython/menustrings.py:529
+#, fuzzy
msgid ""
"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
"created cycle may be sub optimal"
-msgstr ""
+msgstr "Bedenken Sie das: Das Handelsreisenden-Problem ist NP-hart. Dies Modul setzt ein heuristischen Algorithmus ein und erzeugte Ringen können suboptimal sein."
#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:531
#, fuzzy
msgid "Overlay vector maps"
-msgstr "Karten überlagern Vektor"
+msgstr "Vektor"
#: ../gui/wxpython/menustrings.py:532
#, fuzzy
msgid "Overlays two vector maps."
-msgstr "Vektor."
+msgstr "Überlagert zwei Vektorkarten."
#: ../gui/wxpython/menustrings.py:533
#, fuzzy
@@ -7088,7 +7129,7 @@
#: ../gui/wxpython/menustrings.py:534
#, fuzzy
msgid "Create a new vector map layer by combining other vector map layers."
+msgstr "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten."
#: ../gui/wxpython/menustrings.py:535
#, fuzzy
@@ -7103,7 +7144,7 @@
#: ../gui/wxpython/menustrings.py:537
#, fuzzy
msgid "Attach, delete or report vector categories to map geometry."
-msgstr "Vektor Kategorien."
+msgstr "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
#: ../gui/wxpython/menustrings.py:538
#, fuzzy
@@ -7124,17 +7165,17 @@
msgid ""
"Changes vector category values for an existing vector map according to "
"results of SQL queries or a value in attribute table column."
+msgstr "Ändert die Kategorien einer existierenden Vektorkarte entsprechend den Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
#: ../gui/wxpython/menustrings.py:542
#, fuzzy
msgid "Generate area for current region"
-msgstr "Bereich feature für von"
+msgstr "Fläche"
#: ../gui/wxpython/menustrings.py:543
#, fuzzy
msgid "Create a new vector from the current region."
-msgstr "Vektor."
+msgstr "Erzeuge einen neuen Vektor aus der aktuellen Region."
#: ../gui/wxpython/menustrings.py:544
#, fuzzy
@@ -7148,7 +7189,7 @@
#: ../gui/wxpython/menustrings.py:546
#, fuzzy
msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-msgstr "Vektor Punkte Vektor."
+msgstr "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer Hülle zu erzeugen."
#: ../gui/wxpython/menustrings.py:547
#, fuzzy
@@ -7160,7 +7201,7 @@
msgid ""
"Creates a Delaunay triangulation from an input vector map containing points "
"or centroids."
-msgstr "Vektor Punkte Zentroide."
+msgstr "Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit Punkten oder Zentroiden."
#: ../gui/wxpython/menustrings.py:549
#, fuzzy
@@ -7172,7 +7213,7 @@
msgid ""
"Creates a Voronoi diagram from an input vector map containing points or "
"centroids."
+msgstr "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder Zentroiden."
#: ../gui/wxpython/menustrings.py:551
#, fuzzy
@@ -7182,7 +7223,7 @@
#: ../gui/wxpython/menustrings.py:552
#, fuzzy
msgid "Creates a GRASS vector map of a user-defined grid."
-msgstr "Vektor."
+msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
#: ../gui/wxpython/menustrings.py:553
#, fuzzy
@@ -7196,7 +7237,9 @@
#: ../gui/wxpython/menustrings.py:555
#, fuzzy
msgid "Creates new vector (points) map from database table containing coordinates."
-msgstr "Vektor Punkte."
+msgstr ""
+"Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die "
+"Koordinaten beinhaltet."
#: ../gui/wxpython/menustrings.py:556
#, fuzzy
@@ -7206,7 +7249,9 @@
#: ../gui/wxpython/menustrings.py:557
#, fuzzy
msgid "Create points along input lines in new vector with 2 layers."
-msgstr "Punkte Zeilen Vektor."
+msgstr ""
+"Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei "
+"Layern."
#: ../gui/wxpython/menustrings.py:558
#, fuzzy
@@ -7216,7 +7261,7 @@
#: ../gui/wxpython/menustrings.py:559
#, fuzzy
msgid "Randomly generate a 2D/3D vector points map."
+msgstr "Erzeugt zufällige 2D/3D GRASS Vektor-Punktkarten."
#: ../gui/wxpython/menustrings.py:560
#, fuzzy
@@ -7226,74 +7271,78 @@
#: ../gui/wxpython/menustrings.py:561
#, fuzzy
msgid "Random location perturbations of GRASS vector points"
+msgstr "Zufällige Störung der Position von GRASS Vektorpunkten."
#: ../gui/wxpython/menustrings.py:562
#, fuzzy
msgid "Remove outliers in point sets"
-msgstr "Interpoliere Volumen aus Punkten mit Hilfe von Splines"
+msgstr "Punkt"
#: ../gui/wxpython/menustrings.py:563
#, fuzzy
msgid "Removes outliers from vector point data."
+msgstr "Entfernt Ausreißer aus einem Punkt-Vektordatensatz."
#: ../gui/wxpython/menustrings.py:564
#, fuzzy
msgid "Test/training point sets"
-msgstr "Testen"
+msgstr "Punkt"
#: ../gui/wxpython/menustrings.py:565
#, fuzzy
msgid "Randomly partition points into test/train sets."
-msgstr "Punkte."
+msgstr "Teile die Punkte zufällig in ein Test- und ein Training-Datensatz."
#: ../gui/wxpython/menustrings.py:566
#, fuzzy
msgid "Update area attributes from raster"
-msgstr "Editiere Attribute (im Formmodus)"
#: ../gui/wxpython/menustrings.py:567
#, fuzzy
msgid ""
"Calculates univariate statistics from a GRASS raster map based on vector "
"polygons and uploads statistics to new attribute columns."
-msgstr "Vektor Spalten."
+msgstr ""
+"Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
+"und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
#: ../gui/wxpython/menustrings.py:568
#, fuzzy
msgid "Update point attributes from areas"
+msgstr "Punkt"
#: ../gui/wxpython/menustrings.py:569
#, fuzzy
msgid "Uploads vector values at positions of vector points to the table."
-msgstr "Vektor Vektor Punkte."
+msgstr "Schreibt den Vektorwert an der Stelle der Vektorpunkte in die Tabelle."
#: ../gui/wxpython/menustrings.py:570
#, fuzzy
msgid "Update point attributes from raster"
+msgstr "Punkt Raster"
#: ../gui/wxpython/menustrings.py:571
#, fuzzy
msgid "Sample raster maps at point locations"
-msgstr "Raster Punkte"
+msgstr "Raster Punkt"
#: ../gui/wxpython/menustrings.py:572
#, fuzzy
msgid "Uploads raster values at positions of vector points to the table."
+msgstr ""
+"Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die "
+"Attributtabelle."
#: ../gui/wxpython/menustrings.py:573
#, fuzzy
msgid "Sample raster neighborhood around points"
-msgstr "Stichprobe"
+msgstr "Raster"
#: ../gui/wxpython/menustrings.py:574
#, fuzzy
msgid "Samples a raster map at vector point locations."
-msgstr "Vektor."
+msgstr "Fragt eine Rasterkarte an den Positionen von Vektorpunkten ab."
#: ../gui/wxpython/menustrings.py:575
#, fuzzy
@@ -7340,7 +7389,7 @@
msgid ""
"Calculates univariate statistics for attribute. Variance and standard "
"deviation is calculated only for points if specified."
-msgstr "Punkte."
+msgstr "Berechnet univariate Statistiken für die Attribute. Die Varianz und Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
#: ../gui/wxpython/menustrings.py:584
msgid "Quadrat indices"
@@ -7349,7 +7398,7 @@
#: ../gui/wxpython/menustrings.py:585
#, fuzzy
msgid "Indices for quadrat counts of sites lists."
-msgstr "Sites."
+msgstr "Indices der Quadrat-Count-Methode von site_lists."
#: ../gui/wxpython/menustrings.py:586
#, fuzzy
@@ -7359,7 +7408,7 @@
#: ../gui/wxpython/menustrings.py:587
#, fuzzy
msgid "Tests for normality for points."
-msgstr "Punkte."
+msgstr "Test auf Normalverteilung für Punkte."
#: ../gui/wxpython/menustrings.py:588
msgid "Imagery"
@@ -7398,7 +7447,9 @@
#: ../gui/wxpython/menustrings.py:595
#, fuzzy
msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
+msgstr ""
+"Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-"
+"Karten."
#: ../gui/wxpython/menustrings.py:596
#, fuzzy
@@ -7408,7 +7459,7 @@
#: ../gui/wxpython/menustrings.py:597
#, fuzzy
msgid "Color balance for RGB"
-msgstr "Farbe"
+msgstr "Farben"
#: ../gui/wxpython/menustrings.py:598
msgid "Auto-balancing of colors for LANDSAT images"
@@ -7424,14 +7475,14 @@
msgid ""
"Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color "
"transformation function."
-msgstr "Farbe."
+msgstr "Raster."
#: ../gui/wxpython/menustrings.py:602
#, fuzzy
msgid ""
"Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color "
"transformation function"
-msgstr "Farbe"
+msgstr "Raster"
#: ../gui/wxpython/menustrings.py:603
#, fuzzy
@@ -7507,7 +7558,9 @@
#: ../gui/wxpython/menustrings.py:619
#, fuzzy
msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr "Brovey-Transformation zum mischen multispektraler und hochaufgelöster panchromatischer Kanäle."
+msgstr ""
+"Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
+"panchromatischer Kanäle."
#: ../gui/wxpython/menustrings.py:620
#, fuzzy
@@ -7524,10 +7577,7 @@
msgid ""
"The resulting signature file is used as input for i.maxlik, to generate an "
"unsupervised image classification."
-msgstr ""
-"Ein Clusteralgorithmus, der spektrale Signaturen für Landbedeckungsklassen "
-"aus einem Bild ermittelt. Die resultierende Signaturdatei kann als Eingabe "
-"für i.maxlik für eine unüberwachte Klassifikation verwendet werden."
+msgstr "Die resultierende Signaturdatei wird als Eingabe für i.maxlik verwendet, um eine unüberwachte Bildklassifikation zu erzeugen."
#: ../gui/wxpython/menustrings.py:623
msgid "Maximum likelihood classification (MLC)"
@@ -7538,10 +7588,7 @@
msgid ""
"Classification is based on the spectral signature information generated by "
"either i.cluster, i.class, or i.gensig."
-msgstr ""
-"Eine Bildbearbeitungsfunktion, die die spektrale Reflektion einer Zelle "
-"basierend auf der spektralen Signaturinformation (generiert durch i.cluster, "
-"i.class oder i.gensig) klassifiziert."
+msgstr "Die Klassifikation basiert auf der Information der spektralen Signatur erzeugt von .cluster, i.class, oder i.gensig."
#: ../gui/wxpython/menustrings.py:625
msgid "Sequential maximum a posteriori classification (SMAP)"
@@ -7589,7 +7636,7 @@
#: ../gui/wxpython/menustrings.py:633
#, fuzzy
msgid "Zero-crossing \"edge detection\" raster function for image processing."
-msgstr "Raster."
+msgstr "Zero-crossing: Funktion der Bildverarbeitung zur Kantenerkennung."
#: ../gui/wxpython/menustrings.py:634
#, fuzzy
@@ -7621,7 +7668,7 @@
#: ../gui/wxpython/menustrings.py:641
#, fuzzy
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr "Daten"
+msgstr "Tasseled Cap (Kauth Thomas) Transformation für LANDSAT-TM Daten."
#: ../gui/wxpython/menustrings.py:642
#, fuzzy
@@ -7776,7 +7823,7 @@
msgid ""
"Interpolates point data to a G3D grid volume using regularized spline with "
"tension (RST) algorithm."
-msgstr "Daten."
+msgstr "Interpoliert Punkte zu einem G3D Grid Volumen unter Verwendung des regularized spline with tension (RST) Algorithmus."
#: ../gui/wxpython/menustrings.py:674
#, fuzzy
@@ -7817,7 +7864,7 @@
#: ../gui/wxpython/menustrings.py:682
#, fuzzy
msgid "List all columns for a given table."
-msgstr "Karten auflisten Spalten."
+msgstr "Listet alle Spalten einer Tabelle."
#: ../gui/wxpython/menustrings.py:683
#, fuzzy
@@ -7827,7 +7874,7 @@
#: ../gui/wxpython/menustrings.py:684
#, fuzzy
msgid "List all database drivers."
-msgstr "Karten auflisten."
+msgstr "Listet alle verfügbaren Datenbanktreiber auf."
#: ../gui/wxpython/menustrings.py:685
#, fuzzy
@@ -7885,7 +7932,9 @@
msgid ""
"Creates and adds a new attribute table to a given layer of an existing "
"vector map."
-msgstr "Vektor."
+msgstr ""
+"Erzeugt eine neue Attributtabelle für einen Layer einer existierenden "
+"Vektorkarte."
#: ../gui/wxpython/menustrings.py:696
#, fuzzy
@@ -7907,7 +7956,7 @@
msgid ""
"Adds one or more columns to the attribute table connected to a given vector "
"map."
-msgstr "Spalten Vektor."
+msgstr "Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte."
#: ../gui/wxpython/menustrings.py:700
#, fuzzy
@@ -7917,12 +7966,14 @@
#: ../gui/wxpython/menustrings.py:701
#, fuzzy
msgid "Allows to update a column in the attribute table connected to a vector map."
-msgstr "Vektor."
+msgstr "Aktualisiert eine Spalte einer Attributtabelle einer Vektorkarte."
#: ../gui/wxpython/menustrings.py:703
#, fuzzy
msgid "Renames a column in the attribute table connected to a given vector map."
-msgstr "Vektor."
+msgstr ""
+"Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten "
+"Vektorkarte um."
#: ../gui/wxpython/menustrings.py:704
#, fuzzy
@@ -7932,32 +7983,34 @@
#: ../gui/wxpython/menustrings.py:705
#, fuzzy
msgid "Test database driver, database must exist and set by db.connect."
-msgstr "Testen."
+msgstr ""
+"Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db."
+"connect verbunden sein."
#: ../gui/wxpython/menustrings.py:706
#, fuzzy
msgid "Query"
-msgstr "Abfragen"
+msgstr "Abfrage"
#: ../gui/wxpython/menustrings.py:707
#, fuzzy
msgid "Query any table"
-msgstr "Daten abfragen (SQL Select)"
+msgstr "Abfrage"
#: ../gui/wxpython/menustrings.py:708
#, fuzzy
msgid "Selects data from table."
-msgstr "Daten."
+msgstr "Selektiert Daten einer Tabelle."
#: ../gui/wxpython/menustrings.py:709
#, fuzzy
msgid "Query vector attribute data"
-msgstr "Abfragen Vektor Daten"
#: ../gui/wxpython/menustrings.py:710
#, fuzzy
msgid "Prints vector map attributes."
-msgstr "Vektor."
+msgstr "Gebe Vektorattribute aus."
#: ../gui/wxpython/menustrings.py:711
#, fuzzy
@@ -7977,7 +8030,7 @@
#: ../gui/wxpython/menustrings.py:714
#, fuzzy
msgid "Reconnect vector to database"
-msgstr "Zu Datenbank verbinden"
+msgstr "Vektor"
#: ../gui/wxpython/menustrings.py:715
#, fuzzy
@@ -7992,7 +8045,9 @@
#: ../gui/wxpython/menustrings.py:717
#, fuzzy
msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr "Vektor."
+msgstr ""
+"Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer "
+"Attributtabelle."
#: ../gui/wxpython/menustrings.py:718
#, fuzzy
@@ -8019,7 +8074,7 @@
#: ../gui/wxpython/wxgui.py:96
#, fuzzy
msgid "GRASS GIS Layer Manager (Experimental Prototype)"
-msgstr "Layer %d"
+msgstr "Layer"
#: ../gui/wxpython/wxgui.py:306
#, fuzzy
@@ -8052,7 +8107,7 @@
msgid ""
"Reading workspace file <%s> failed. Invalid file, unable to parse XML "
"document."
#: ../gui/wxpython/wxgui.py:652 ../gui/wxpython/wxgui.py:757
#: ../gui/wxpython/wxgui.py:793
@@ -8091,22 +8146,22 @@
#, python-format
#, fuzzy
msgid "Writing current settings to workspace file failed (%s)."
#: ../gui/wxpython/wxgui.py:1030
#, fuzzy
msgid "Import DXF layers"
+msgstr "Import"
#: ../gui/wxpython/wxgui.py:1036
#, fuzzy
msgid "Import GDAL layers"
+msgstr "Import"
#: ../gui/wxpython/wxgui.py:1042
#, fuzzy
msgid "Import OGR layers"
+msgstr "Import"
#: ../gui/wxpython/wxgui.py:1067
#, fuzzy
