[GRASS-SVN] r35954 - in grass/trunk/gui/wxpython: gui_modules vdigit
Thu Feb 19 12:54:41 EST 2009
Author: martinl
Date: 2009-02-19 12:54:41 -0500 (Thu, 19 Feb 2009)
New Revision: 35954
   grass/trunk/gui/wxpython/gui_modules/vdigit.py
   grass/trunk/gui/wxpython/vdigit/driver.cpp
   grass/trunk/gui/wxpython/vdigit/driver.h
wxGUI: redirect messages from vdigit
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py	2009-02-19 17:34:01 UTC (rev 35953)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py	2009-02-19 17:54:41 UTC (rev 35954)
@@ -766,10 +766,16 @@
         self.mapWindow = mapwindow
+        if self.mapwindow.gismanager:
+            logerr = self.mapwindow.gismanager.goutput.cmd_stderr
+        else:
+            logerr = None
         # initialize wx display driver
         try:
             self.__display = wxvdigit.DisplayDriver(mapwindow.pdcVector,
-                                                    mapwindow.pdcTmp)
+                                                    mapwindow.pdcTmp,
+                                                    logerr)
         except:
             self.__display = None
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp	2009-02-19 17:34:01 UTC (rev 35953)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp	2009-02-19 17:54:41 UTC (rev 35954)
@@ -19,6 +19,16 @@
 #include "driver.h"
+#define MSG  0
+#define WARN 1
+#define ERR  2
+static int print_error(const char *, const int);
+static int print_percent(int);
+static void print_sentence (PyObject*, const int, const char *);
+static PyObject *logStream;
+static int message_id = 1;
    \brief Initialize driver
@@ -29,7 +39,8 @@
    \return
-DisplayDriver::DisplayDriver(gwxPseudoDC *device, gwxPseudoDC *deviceTmp)
+DisplayDriver::DisplayDriver(gwxPseudoDC *device, gwxPseudoDC *deviceTmp,
+			     PyObject *log)
     G_gisinit(""); /* GRASS functions */
@@ -37,7 +48,8 @@
     dc = device;
     dcTmp = deviceTmp;
+    logStream = log;
     points = Vect_new_line_struct();
     pointsScreen = new wxList();
     cats = Vect_new_cats_struct();
@@ -49,11 +61,11 @@
     drawSegments = false;
-    G_set_verbose(0);
+    G_set_error_routine(&print_error);
+    G_set_percent_routine(&print_percent);
     // avoid GUI crash when G_fatal_error() is called (opening the vector map)
     // Vect_set_fatal_error(GV_FATAL_PRINT);
-    // G_set_error_routine(print_error);
@@ -70,6 +82,9 @@
     if (mapInfo)
 	CloseMap();
+    G_unset_error_routine();
+    G_unset_percent_routine();
     Vect_destroy_line_struct(points);
     delete pointsScreen;
     Vect_destroy_cats_struct(cats);
@@ -502,17 +517,103 @@
     return region;
-   \brief Error messages handling
+  \brief Print one message, prefix inserted before each new line
-   \param msg message
-   \param type type message (MSG, WARN, ERR)
+  From lib/gis/error.c
+void print_sentence (PyObject *pyFd, const int type, const char *msg)
+    char prefix[256];
+    const char *start;
+    char* sentence;
-   \return 0
+    switch (type) {
+    case MSG:
+	sprintf (prefix, "GRASS_INFO_MESSAGE(%d,%d): Vdigit: ", getpid(), message_id);
+	break;
+    case WARN:
+	sprintf (prefix, "GRASS_INFO_WARNING(%d,%d): Vdigit: ", getpid(), message_id);
+	break;
+    case ERR:
+	sprintf (prefix, "GRASS_INFO_ERROR(%d,%d): Vdigit: ", getpid(), message_id);
+	break;
+    start = msg;
+    PyFile_WriteString("\n", pyFd);
+    while (*start != '\0') {
+	const char *next = start;
+	PyFile_WriteString(prefix, pyFd);
+	while ( *next != '\0' ) {
+	    next++;
+	    if ( *next == '\n' ) {
+	        next++;
+		break;
+	sentence = (char *) G_malloc((next - start + 1) * sizeof (char));
+	strncpy(sentence, start, next - start + 1);
+	sentence[next-start] = '\0';
+	PyFile_WriteString(sentence, pyFd);
+	G_free((void *)sentence);
+	start = next;
+    sprintf(prefix, "GRASS_INFO_END(%d,%d)\n", getpid(), message_id);
+    message_id++;
+  \brief Print error/warning/message
+  \param msg message buffer
+  \param type message type
+  \return 0
-int print_error(const char *msg, int type)
+int print_error(const char *msg, const int type)
-    fprintf(stderr, "%s", msg);
+    if (logStream) {
+	print_sentence(logStream, type, msg);
+    else {
+	fprintf(stderr, "Vdigit: %s\n", msg);
+    return 0;
+  \brief Print percentage information
+  \param x value
+  \return 0
+int print_percent(int x)
+    char msg[256];
+    if (logStream) {
+	sprintf(msg, "GRASS_INFO_PERCENT: %d\n", x);
+	PyFile_WriteString(msg, logStream);
+    else {
+	fprintf(stderr, "GRASS_INFO_PERCENT: %d\n", x);
     return 0;
Modified: grass/trunk/gui/wxpython/vdigit/driver.h
--- grass/trunk/gui/wxpython/vdigit/driver.h	2009-02-19 17:34:01 UTC (rev 35953)
+++ grass/trunk/gui/wxpython/vdigit/driver.h	2009-02-19 17:54:41 UTC (rev 35954)
@@ -175,7 +175,7 @@
 public:
     /* constructor */
-    DisplayDriver(gwxPseudoDC *, gwxPseudoDC *);
+    DisplayDriver(gwxPseudoDC *, gwxPseudoDC *, PyObject *);
     /* destructor */
     ~DisplayDriver();
@@ -230,6 +230,4 @@
 			int, int);
-int print_error(const char *, int);
 #endif /* WXVDIGIT_DRIVER_H */
