[GRASS-SVN] r35955 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules vdigit
svn_grass at osgeo.org
Thu Feb 19 13:09:38 EST 2009
Author: martinl
Date: 2009-02-19 13:09:37 -0500 (Thu, 19 Feb 2009)
New Revision: 35955
grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
wxGUI: redirect messages from vdigit
(merge from trunk, r35954)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2009-02-19 17:54:41 UTC (rev 35954)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2009-02-19 18:09:37 UTC (rev 35955)
@@ -766,10 +766,16 @@
self.mapWindow = mapwindow
+ if self.mapwindow.gismanager:
+ logerr = self.mapwindow.gismanager.goutput.cmd_stderr
+ else:
+ logerr = None
# initialize wx display driver
try:
self.__display = wxvdigit.DisplayDriver(mapwindow.pdcVector,
- mapwindow.pdcTmp)
+ mapwindow.pdcTmp,
+ logerr)
except:
self.__display = None
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp 2009-02-19 17:54:41 UTC (rev 35954)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp 2009-02-19 18:09:37 UTC (rev 35955)
@@ -19,6 +19,16 @@
#include "driver.h"
+#define MSG 0
+#define WARN 1
+#define ERR 2
+static int print_error(const char *, const int);
+static int print_percent(int);
+static void print_sentence (PyObject*, const int, const char *);
+static PyObject *logStream;
+static int message_id = 1;
\brief Initialize driver
@@ -29,7 +39,8 @@
\return
-DisplayDriver::DisplayDriver(gwxPseudoDC *device, gwxPseudoDC *deviceTmp)
+DisplayDriver::DisplayDriver(gwxPseudoDC *device, gwxPseudoDC *deviceTmp,
+ PyObject *log)
G_gisinit(""); /* GRASS functions */
@@ -37,7 +48,8 @@
dc = device;
dcTmp = deviceTmp;
+ logStream = log;
points = Vect_new_line_struct();
pointsScreen = new wxList();
cats = Vect_new_cats_struct();
@@ -49,11 +61,11 @@
drawSegments = false;
- G_set_verbose(0);
+ G_set_error_routine(&print_error);
+ // G_set_percent_routine(&print_percent);
// avoid GUI crash when G_fatal_error() is called (opening the vector map)
// Vect_set_fatal_error(GV_FATAL_PRINT);
- // G_set_error_routine(print_error);
@@ -70,6 +82,9 @@
if (mapInfo)
CloseMap();
+ G_unset_error_routine();
+ // G_unset_percent_routine();
Vect_destroy_line_struct(points);
delete pointsScreen;
Vect_destroy_cats_struct(cats);
@@ -502,17 +517,103 @@
return region;
- \brief Error messages handling
+ \brief Print one message, prefix inserted before each new line
- \param msg message
- \param type type message (MSG, WARN, ERR)
+ From lib/gis/error.c
+void print_sentence (PyObject *pyFd, const int type, const char *msg)
+ char prefix[256];
+ const char *start;
+ char* sentence;
- \return 0
+ switch (type) {
+ case MSG:
+ sprintf (prefix, "GRASS_INFO_MESSAGE(%d,%d): Vdigit: ", getpid(), message_id);
+ break;
+ case WARN:
+ sprintf (prefix, "GRASS_INFO_WARNING(%d,%d): Vdigit: ", getpid(), message_id);
+ break;
+ case ERR:
+ sprintf (prefix, "GRASS_INFO_ERROR(%d,%d): Vdigit: ", getpid(), message_id);
+ break;
+ start = msg;
+ PyFile_WriteString("\n", pyFd);
+ while (*start != '\0') {
+ const char *next = start;
+ PyFile_WriteString(prefix, pyFd);
+ while ( *next != '\0' ) {
+ next++;
+ if ( *next == '\n' ) {
+ next++;
+ break;
+ sentence = (char *) G_malloc((next - start + 1) * sizeof (char));
+ strncpy(sentence, start, next - start + 1);
+ sentence[next-start] = '\0';
+ PyFile_WriteString(sentence, pyFd);
+ G_free((void *)sentence);
+ start = next;
+ sprintf(prefix, "GRASS_INFO_END(%d,%d)\n", getpid(), message_id);
+ message_id++;
+ \brief Print error/warning/message
+ \param msg message buffer
+ \param type message type
+ \return 0
-int print_error(const char *msg, int type)
+int print_error(const char *msg, const int type)
- fprintf(stderr, "%s", msg);
+ if (logStream) {
+ print_sentence(logStream, type, msg);
+ else {
+ fprintf(stderr, "Vdigit: %s\n", msg);
+ return 0;
+ \brief Print percentage information
+ \param x value
+ \return 0
+int print_percent(int x)
+ char msg[256];
+ if (logStream) {
+ sprintf(msg, "GRASS_INFO_PERCENT: %d\n", x);
+ PyFile_WriteString(msg, logStream);
+ else {
+ fprintf(stderr, "GRASS_INFO_PERCENT: %d\n", x);
return 0;
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h 2009-02-19 17:54:41 UTC (rev 35954)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h 2009-02-19 18:09:37 UTC (rev 35955)
@@ -175,7 +175,7 @@
public:
/* constructor */
- DisplayDriver(gwxPseudoDC *, gwxPseudoDC *);
+ DisplayDriver(gwxPseudoDC *, gwxPseudoDC *, PyObject *);
/* destructor */
~DisplayDriver();
@@ -230,6 +230,4 @@
int, int);
-int print_error(const char *, int);
#endif /* WXVDIGIT_DRIVER_H */
