[GRASS-SVN] r35957 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Thu Feb 19 13:38:13 EST 2009
Author: martinl
Date: 2009-02-19 13:38:13 -0500 (Thu, 19 Feb 2009)
New Revision: 35957
grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: MapFrame standalone check
(merge from trunk, r35956)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py 2009-02-19 18:35:32 UTC (rev 35956)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py 2009-02-19 18:38:13 UTC (rev 35957)
@@ -190,7 +190,7 @@
self.xy_mapdisp = mapdisp.MapFrame(self.gcpmgr, title=_("Set ground control points (GCPs)"),
size=globalvar.MAP_WINDOW_SIZE,
toolbars=["georect"],
- Map=self.Map, gismgr=self.parent)
+ Map=self.Map, lmgr=self.parent)
self.gcpmgr.SetMapDisplay(self.xy_mapdisp)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2009-02-19 18:35:32 UTC (rev 35956)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2009-02-19 18:38:13 UTC (rev 35957)
@@ -8,7 +8,6 @@
Can be used either from Layer Manager or as p.mon backend.
Classes:
- - MapWindow
- MapFrame
- MapApp
@@ -90,7 +89,7 @@
def __init__(self, parent=None, id=wx.ID_ANY, title=_("GRASS GIS - Map display"),
pos=wx.DefaultPosition, size=wx.DefaultSize,
style=wx.DEFAULT_FRAME_STYLE, toolbars=["map"],
- tree=None, notebook=None, gismgr=None, page=None,
+ tree=None, notebook=None, lmgr=None, page=None,
Map=None, auimgr=None):
Main map display window with toolbars, statusbar and
@@ -99,15 +98,15 @@
@param toolbars array of activated toolbars, e.g. ['map', 'digit']
@param tree reference to layer tree
@param notebook control book ID in Layer Manager
- @param gismgr Layer Manager panel
+ @param mgr Layer Manager
@param page notebook page with layer tree
@param Map instance of render.Map
- self.gismanager = gismgr # GIS Manager object
+ self._layerManager = lmgr # Layer Manager object
self.Map = Map # instance of render.Map
- self.tree = tree # GIS Manager layer tree object
+ self.tree = tree # Layer Manager layer tree object
self.page = page # Notebook page holding the layer tree
- self.layerbook = notebook # GIS Manager layer tree notebook
+ self.layerbook = notebook # Layer Manager layer tree notebook
self.parent = parent
@@ -214,7 +213,7 @@
# Init map display (buffered DC & set default cursor)
self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY,
- Map=self.Map, tree=self.tree, gismgr=self.gismanager)
+ Map=self.Map, tree=self.tree, lmgr=self._layerManager)
# default is 2D display mode
self.MapWindow = self.MapWindow2D
self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
@@ -296,8 +295,8 @@
# vector digitizer
elif name == "vdigit":
- if self.gismanager:
- log = self.gismanager.goutput
+ if self._layerManager:
+ log = self._layerManager.goutput
else:
log = None
self.toolbars['vdigit'] = toolbars.VDigitToolbar(parent=self, map=self.Map,
@@ -386,7 +385,7 @@
if not self.MapWindow3D:
self.MapWindow3D = nviz.GLWindow(self, id=wx.ID_ANY,
# -> show after paint
self.nvizToolWin = nviz.NvizToolWindow(self, id=wx.ID_ANY,
mapWindow=self.MapWindow3D)
@@ -490,8 +489,8 @@
Change choicebook page to match display.
Or set display for georectifying
- if self.gismanager and \
- self.gismanager.georectifying:
+ if self._layerManager and \
+ self._layerManager.georectifying:
# in georectifying session; display used to get get geographic
# coordinates for GCPs
self.OnPointer(event)
@@ -595,7 +594,7 @@
else: # moveLine, deleteLine
self.MapWindow.mouse['box'] = 'box'
- elif self.gismanager and self.gismanager.georectifying:
+ elif self._layerManager and self._layerManager.georectifying:
self.MapWindow.SetCursor(self.cursors["cross"])
else:
@@ -1031,7 +1030,7 @@
if self.toolbars['nviz']:
self.toolbars['nviz'].OnExit()
- if not self.gismanager:
+ if not self._layerManager:
self.Destroy()
elif self.page:
pgnum = self.layerbook.GetPageIndex(self.page)
@@ -1055,7 +1054,7 @@
self.toolbars['map'].action['desc'] = 'displayAttrb'
# switch GIS Manager to output console to show query results
- self.gismanager.notebook.SetSelection(1)
+ self._layerManager.notebook.SetSelection(1)
self.MapWindow.mouse['use'] = "query"
self.MapWindow.mouse['box'] = "point"
@@ -1135,14 +1134,14 @@
vect = []
for vector in vectstr.split(','):
if map == vector:
- self.gismanager.goutput.WriteWarning("Vector map <%s> "
+ self._layerManager.goutput.WriteWarning("Vector map <%s> "
"opened for editing - skipped." % map)
continue
vect.append(vector)
vectstr = ','.join(vect)
if len(vectstr) <= 1:
- self.gismanager.goutput.WriteCmdLog("Nothing to query.")
+ self._layerManager.goutput.WriteCmdLog("Nothing to query.")
return
vcmd.append('-a')
@@ -1151,12 +1150,12 @@
vcmd.append('distance=%f' % float(qdist))
# parse query command(s)
if raststr:
- self.gismanager.goutput.RunCmd(rcmd,
+ self._layerManager.goutput.RunCmd(rcmd,
compReg=False)
if vectstr:
- self.gismanager.goutput.RunCmd(vcmd)
+ self._layerManager.goutput.RunCmd(vcmd)
else:
if raststr:
gcmd.RunCommand(rcmd)
@@ -1354,7 +1353,7 @@
self.totaldist = 0.0 # total measured distance
# switch GIS Manager to output console to show measure results
# change mouse to draw line for measurement
self.MapWindow.mouse['use'] = "measure"
@@ -1367,19 +1366,19 @@
self.MapWindow.SetCursor(self.cursors["pencil"])
# initiating output
- style = self.gismanager.goutput.cmd_output.StyleWarning
- self.gismanager.goutput.WriteLog(_('Click and drag with left mouse button '
+ style = self._layerManager.goutput.cmd_output.StyleWarning
+ self._layerManager.goutput.WriteLog(_('Click and drag with left mouse button '
'to measure.%s'
'Double click with left button to clear.') % \
(os.linesep), style)
if self.Map.projinfo['proj'] != 'xy':
units = self.Map.projinfo['units']
- style = self.gismanager.goutput.cmd_output.StyleCommand
- self.gismanager.goutput.WriteLog(_('Measuring distance') + ' ('
+ style = self._layerManager.goutput.cmd_output.StyleCommand
+ self._layerManager.goutput.WriteLog(_('Measuring distance') + ' ('
+ units + '):',
style)
else:
- self.gismanager.goutput.WriteLog(_('Measuring distance:'),
+ self._layerManager.goutput.WriteLog(_('Measuring distance:'),
style)
def MeasureDist(self, beginpt, endpt):
@@ -1388,8 +1387,8 @@
and print to output window
- if self.gismanager.notebook.GetSelection() != 1:
+ if self._layerManager.notebook.GetSelection() != 1:
dist, (north, east) = self.MapWindow.Distance(beginpt, endpt)
@@ -1413,7 +1412,7 @@
mstring = 'segment = %s %s\ttotal distance = %s %s' \
% (strdist,dunits,strtotdist,tdunits)
- self.gismanager.goutput.WriteLog(mstring)
+ self._layerManager.goutput.WriteLog(mstring)
return dist
@@ -1689,7 +1688,22 @@
self.compResolution.SetValue(constrainRes)
if showCompExtent:
self.MapWindow.regionCoords = []
+ def IsStandalone(self):
+ """Check if Map display is standalone"""
+ return False
+ return True
+ def GetLayerManager(self):
+ """Get reference to Layer Manager
+ @return window reference
+ @return None (if standalone)
+ return self._layerManager
# end of class MapFrame
class MapApp(wx.App):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-02-19 18:35:32 UTC (rev 35956)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2009-02-19 18:38:13 UTC (rev 35957)
@@ -48,7 +48,7 @@
style=wx.NO_FULL_REPAINT_ON_RESIZE,
- Map=None, tree=None, gismgr=None):
+ Map=None, tree=None, lmgr=None):
self.parent = parent # MapFrame
@@ -151,16 +151,15 @@
pos = wx.DefaultPosition,
size = wx.DefaultSize,
MapWindow.__init__(self, parent, id, pos, size, style,
- Map, tree, gismgr)
+ Map, tree, lmgr)
wx.Window.__init__(self, parent, id, pos, size, style)
self.Map = Map
self.tree = tree
# Flags
@@ -715,14 +714,14 @@
if len(self.polycoords) > 0:
self.DrawLines(self.pdcTmp)
- if self.parent.gismanager and \
- self.parent.gismanager.georectifying:
+ if not self.parent.IsStandalone() and \
+ self.parent.GetLayerManager().georectifying:
# -> georectifier (redraw GCPs)
if self.parent.toolbars['georect']:
coordtype = 'gcpcoord'
else:
coordtype = 'mapcoord'
- self.parent.gismanager.georectifying.DrawGCP(coordtype)
+ self.parent.GetLayerManager().georectifying.DrawGCP(coordtype)
# clear measurement
@@ -1717,7 +1716,8 @@
self.ClearLines(pdc=self.pdcTmp)
self.DrawLines(pdc=self.pdcTmp)
- elif self.mouse["use"] == "pointer" and self.parent.gismanager.georectifying:
+ elif self.mouse["use"] == "pointer" and \
# -> georectifying
coord = self.Pixel2Cell(self.mouse['end'])
@@ -1725,7 +1725,7 @@
else:
- self.parent.gismanager.georectifying.SetGCPData(coordtype, coord, self)
+ self.parent.GetLayerManager().georectifying.SetGCPData(coordtype, coord, self)
self.UpdateMap(render=False, renderVector=False)
elif self.mouse["use"] == "pointer" and self.parent.toolbars['vdigit']:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py 2009-02-19 18:35:32 UTC (rev 35956)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py 2009-02-19 18:38:13 UTC (rev 35957)
@@ -66,16 +66,16 @@
self.Map = Map
self.tree = tree
- self.gismgr = gismgr
+ self._layermanager = lmgr
glcanvas.GLCanvas.__init__(self, parent, id)
+ Map, tree, self._layermanager)
self.Hide()
self.init = False
@@ -98,9 +98,9 @@
# create nviz instance
- if self.gismgr:
- logerr = self.gismgr.goutput.cmd_stderr
- logmsg = self.gismgr.goutput.cmd_output
+ if self._layermanager:
+ logerr = self._layermanager.goutput.cmd_stderr
+ logmsg = self._layermanager.goutput.cmd_output
else:
logerr = logmsg = None
self.nvizThread = NvizThread(logerr,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py 2009-02-19 18:35:32 UTC (rev 35956)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py 2009-02-19 18:38:13 UTC (rev 35957)
@@ -45,7 +45,7 @@
style=wx.DEFAULT_FRAME_STYLE, mapWindow=None):
- self.lmgr = self.parent.gismanager # GMFrame
+ self.lmgr = self.parent.GetLayerManager() # GMFrame
self.mapWindow = mapWindow
wx.Frame.__init__(self, parent, id, title, pos, size, style)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py 2009-02-19 18:35:32 UTC (rev 35956)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py 2009-02-19 18:38:13 UTC (rev 35957)
@@ -1058,7 +1058,7 @@
UserSettings.ReadSettingsFile(settings=fileSettings)
fileSettings['profile'] = UserSettings.Get(group='profile')
file = UserSettings.SaveToFile(fileSettings)
- self.parent.parent.gismanager.goutput.WriteLog(_('Profile settings saved to file \'%s\'.') % file)
+ self.parent.parent.GetLayerManager().goutput.WriteLog(_('Profile settings saved to file \'%s\'.') % file)
self.Close()
def OnApply(self, event):
@@ -1403,7 +1403,7 @@
self.Close()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2009-02-19 18:35:32 UTC (rev 35956)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2009-02-19 18:38:13 UTC (rev 35957)
@@ -766,8 +766,8 @@
self.mapWindow = mapwindow
- if self.mapwindow.gismanager:
- logerr = self.mapwindow.gismanager.goutput.cmd_stderr
+ if not self.mapwindow.parent.IsStandalone():
+ logerr = self.mapwindow.parent.GetLayerManager().goutput.cmd_stderr
else:
logerr = None
@@ -1613,7 +1613,7 @@
fileSettings['vdigit'] = UserSettings.Get(group='vdigit')
- self.parent.gismanager.goutput.WriteLog(_('Vector digitizer settings saved to file <%s>.') % file)
+ self.parent.GetLayerManager().goutput.WriteLog(_('Vector digitizer settings saved to file <%s>.') % file)
self.Destroy()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2009-02-19 18:35:32 UTC (rev 35956)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2009-02-19 18:38:13 UTC (rev 35957)
@@ -88,7 +88,7 @@
self.first = True # indicates if a layer is just added or not
self.flag = '' # flag for drag and drop hittest
self.disp_idx = kargs['idx']
- self.gismgr = kargs['gismgr']
+ self.lmgr = kargs['lmgr']
self.notebook = kargs['notebook'] # GIS Manager notebook for layer tree
self.treepg = parent # notebook page holding layer tree
self.auimgr = kargs['auimgr'] # aui manager
@@ -102,7 +102,7 @@
tree=self, notebook=self.notebook,
- gismgr=self.gismgr, page=self.treepg,
+ lmgr=self.lmgr, page=self.treepg,
Map=self.Map, auimgr=self.auimgr)
# title
@@ -208,8 +208,8 @@
def OnKeyUp(self, event):
"""Key pressed"""
key = event.GetKeyCode()
- if key == wx.WXK_DELETE and self.gismgr:
- self.gismgr.OnDeleteLayer(None)
+ if key == wx.WXK_DELETE and self.lmgr:
+ self.lmgr.OnDeleteLayer(None)
event.Skip()
@@ -251,7 +251,7 @@
# general item
self.popupMenu.Append(self.popupID1, text=_("Remove"))
- self.Bind(wx.EVT_MENU, self.gismgr.OnDeleteLayer, id=self.popupID1)
+ self.Bind(wx.EVT_MENU, self.lmgr.OnDeleteLayer, id=self.popupID1)
if ltype != "command": # rename
self.popupMenu.Append(self.popupID2, text=_("Rename"))
@@ -286,7 +286,7 @@
if mltype and mltype == "vector":
self.popupMenu.AppendSeparator()
self.popupMenu.Append(self.popupID4, text=_("Show attribute data"))
- self.Bind (wx.EVT_MENU, self.gismgr.OnShowAttributeTable, id=self.popupID4)
+ self.Bind (wx.EVT_MENU, self.lmgr.OnShowAttributeTable, id=self.popupID4)
self.popupMenu.Append(self.popupID5, text=_("Start editing"))
self.popupMenu.Append(self.popupID6, text=_("Stop editing"))
@@ -388,7 +388,7 @@
cmd.append('map=%s' % mapLayer.name)
# print output to command log area
- self.gismgr.goutput.RunCmd(cmd, switchPage=True)
+ self.lmgr.goutput.RunCmd(cmd, switchPage=True)
def OnSetCompRegFromRaster(self, event):
"""Set computational region from selected raster map (ignore NULLs)"""
@@ -399,7 +399,7 @@
'zoom=%s' % mapLayer.name]
- self.gismgr.goutput.RunCmd(cmd)
+ self.lmgr.goutput.RunCmd(cmd)
def OnSetCompRegFromMap(self, event):
"""Set computational region from selected raster/vector map"""
@@ -428,7 +428,7 @@
if len(cmd) > 1:
cmd.append('-p')
def OnProfile(self, event):
"""Plot profile of given raster map layer"""
@@ -1064,7 +1064,7 @@
if self.GetPyData(layer) and self.GetPyData(layer)[0]['maplayer']:
cmd = self.GetPyData(layer)[0]['maplayer'].GetCmd(string=True)
if len(cmd) > 0:
- self.gismgr.SetStatusText(cmd)
+ self.lmgr.SetStatusText(cmd)
# update nviz tools
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2009-02-19 18:35:32 UTC (rev 35956)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2009-02-19 18:38:13 UTC (rev 35957)
@@ -1201,7 +1201,7 @@
size=wx.DefaultSize, style=wx.TR_HAS_BUTTONS
|wx.TR_LINES_AT_ROOT|wx.TR_HIDE_ROOT
|wx.TR_DEFAULT_STYLE|wx.NO_BORDER|wx.FULL_REPAINT_ON_RESIZE,
- idx=self.disp_idx, gismgr=self, notebook=self.gm_cb,
+ idx=self.disp_idx, lmgr=self, notebook=self.gm_cb,
auimgr=self._auimgr, showMapDisplay=show)
# layout for controls
