[GRASS-SVN] r36002 - grass-addons/raster/r.univar2.zonal
svn_grass at osgeo.org
Sat Feb 21 02:57:19 EST 2009
Author: mmetz
Date: 2009-02-21 02:57:19 -0500 (Sat, 21 Feb 2009)
New Revision: 36002
grass-addons/raster/r.univar2.zonal/globals.h
grass-addons/raster/r.univar2.zonal/r.univar.html
grass-addons/raster/r.univar2.zonal/r.univar_main.c
grass-addons/raster/r.univar2.zonal/stats.c
option for table format ouput instead of standard r.univar output
Modified: grass-addons/raster/r.univar2.zonal/globals.h
--- grass-addons/raster/r.univar2.zonal/globals.h 2009-02-20 22:34:02 UTC (rev 36001)
+++ grass-addons/raster/r.univar2.zonal/globals.h 2009-02-21 07:57:19 UTC (rev 36002)
@@ -45,13 +45,14 @@
CELL min, max, n_zones;
struct Categories cats;
+ char *sep;
} zone_type;
/* command line options are the same for raster and raster3d maps */
typedef struct
struct Option *inputfile, *zonefile, *percentile, *output_file;
- struct Flag *shell_style, *extended;
+ struct Flag *shell_style, *extended, *table;
} param_type;
#ifdef MAIN
@@ -67,6 +68,7 @@
void heapsort_float(float *data, int n);
void heapsort_int(int *data, int n);
int print_stats(univar_stat * stats);
+int print_stats2(univar_stat * stats);
univar_stat *create_univar_stat_struct(int map_type, int size, int n_perc);
void free_univar_stat_struct(univar_stat * stats);
Modified: grass-addons/raster/r.univar2.zonal/r.univar.html
--- grass-addons/raster/r.univar2.zonal/r.univar.html 2009-02-20 22:34:02 UTC (rev 36001)
+++ grass-addons/raster/r.univar2.zonal/r.univar.html 2009-02-21 07:57:19 UTC (rev 36002)
@@ -1,13 +1,18 @@
<h2>DESCRIPTION</h2>
-<em>r.univar</em> calculates the univariate statistics of a raster map.
+<em>r.univar.zonal</em> calculates the univariate statistics of a raster map.
This includes the number of cells counted, minimum and maximum cell values,
range, arithmetic mean, population variance, standard deviation, and
-coefficient of variation.
+coefficient of variation. Statistics are calculated separately for every
+category/zone found in the <b>zones</b> input map.
If the <b>-e</b> extended statistics flag is given the 1st quartile, median,
3rd quartile, and given <b>percentile</b> are calculated.
If the <b>-g</b> flag is given the results are presented in a format suitable
for use in a shell script.
+If the <b>-t</b> flag is given the results are presented in tabular format
+with ";" as field separator. The table can immediately be converted to a
+proper attribute table which can then be linked to a vector, e.g. the vector
+that was rasterized to create the <b>zones</b> input raster.
<h2>NOTES</h2>
Modified: grass-addons/raster/r.univar2.zonal/r.univar_main.c
--- grass-addons/raster/r.univar2.zonal/r.univar_main.c 2009-02-20 22:34:02 UTC (rev 36001)
+++ grass-addons/raster/r.univar2.zonal/r.univar_main.c 2009-02-21 07:57:19 UTC (rev 36002)
@@ -36,7 +36,7 @@
_("Raster map used for zoning, must be of type CELL");
param.output_file = G_define_standard_option(G_OPT_F_OUTPUT);
- param.output_file->required = NO;
+ param.output_file->required = YES;
param.output_file->description =
_("Name for output file (if omitted or \"-\" output to stdout)");
@@ -59,6 +59,10 @@
param.extended->key = 'e';
param.extended->description = _("Calculate extended statistics");
+ param.table = G_define_flag();
+ param.table->key = 't';
+ param.table->description = _("Table output format instead of r.univar like output format");
return;
@@ -104,6 +108,9 @@
+ /* TODO: make it an option */
+ zone_info.sep = ";";
G_get_window(®ion);
rows = region.rows;
cols = region.cols;
@@ -161,12 +168,16 @@
process_raster(stats, fd, fdz, ®ion);
- if (!(param.shell_style->answer))
- G_percent(rows, rows, 2); /* finish it off */
+ /* closing raster maps */
+ G_close_cell(fd);
+ G_close_cell(fdz);
/* create the output */
- print_stats(stats);
+ if (param.table->answer)
+ print_stats2(stats);
+ else
+ print_stats(stats);
/* release memory */
free_univar_stat_struct(stats);
@@ -279,19 +290,22 @@
for (col = 0; col < cols; col++) {
- if (G_is_null_value(ptr, map_type)) {
+ if (G_is_c_null_value(zptr)) {
ptr = G_incr_void_ptr(ptr, value_sz);
zptr++;
continue;
- if (G_is_c_null_value(zptr)) {
+ /* also count NULL cell in input map */
+ zone = *zptr - zone_info.min;
+ stats[zone].size++;
+ if (G_is_null_value(ptr, map_type)) {
zptr++;
continue;
- zone = *zptr - zone_info.min;
if (stats[zone].nextp) {
/* put the value into stats->XXXcell_array */
memcpy(stats[zone].nextp, ptr, value_sz);
@@ -324,7 +338,8 @@
zptr++;
stats[zone].n++;
- G_percent(row, rows, 2);
+ G_percent(row, rows, 2);
+ G_percent(rows, rows, 2); /* finish it off */
Modified: grass-addons/raster/r.univar2.zonal/stats.c
--- grass-addons/raster/r.univar2.zonal/stats.c 2009-02-20 22:34:02 UTC (rev 36001)
+++ grass-addons/raster/r.univar2.zonal/stats.c 2009-02-21 07:57:19 UTC (rev 36002)
@@ -36,7 +36,7 @@
stats[i].perc = NULL;
stats[i].sum_abs = 0.0;
stats[i].n = 0;
- stats[i].size = size;
+ stats[i].size = 0;
stats[i].dcell_array = NULL;
stats[i].fcell_array = NULL;
stats[i].cell_array = NULL;
@@ -46,12 +46,12 @@
if (param.extended->answer) {
if (map_type == DCELL_TYPE)
- (DCELL *) G_calloc(stats[i].size, sizeof(DCELL));
+ (DCELL *) G_calloc(size, sizeof(DCELL));
if (map_type == FCELL_TYPE)
- (FCELL *) G_calloc(stats[i].size, sizeof(FCELL));
+ (FCELL *) G_calloc(size, sizeof(FCELL));
if (map_type == CELL_TYPE)
- stats[i].cell_array = (CELL *) G_calloc(stats[i].size, sizeof(CELL));
+ stats[i].cell_array = (CELL *) G_calloc(size, sizeof(CELL));
@@ -125,7 +125,7 @@
if (param.shell_style->answer) {
- fprintf(stdout, "n=%d\n", stats[z].n);
+ fprintf(stdout, "non_null_cells=%d\n", stats[z].n);
fprintf(stdout, "null_cells=%d\n", stats[z].size - stats[z].n);
fprintf(stdout, "min=%.15g\n", stats[z].min);
fprintf(stdout, "max=%.15g\n", stats[z].max);
@@ -260,3 +260,182 @@
return 1;
+ int z;
+ unsigned int i;
+ /* print column headers */
+ fprintf(stdout, "zone%s", zone_info.sep);
+ fprintf(stdout, "label%s", zone_info.sep);
+ fprintf(stdout, "non_null_cells%s", zone_info.sep);
+ fprintf(stdout, "null_cells%s", zone_info.sep);
+ fprintf(stdout, "min%s", zone_info.sep);
+ fprintf(stdout, "max%s", zone_info.sep);
+ fprintf(stdout, "range%s", zone_info.sep);
+ fprintf(stdout, "mean%s", zone_info.sep);
+ fprintf(stdout, "mean_of_abs%s", zone_info.sep);
+ fprintf(stdout, "stddev%s", zone_info.sep);
+ fprintf(stdout, "variance%s", zone_info.sep);
+ fprintf(stdout, "coeff_var%s", zone_info.sep);
+ fprintf(stdout, "sum%s", zone_info.sep);
+ fprintf(stdout, "sum_abs%s", zone_info.sep);
+ fprintf(stdout, "first_quart%s", zone_info.sep);
+ fprintf(stdout, "median%s", zone_info.sep);
+ fprintf(stdout, "third_quart%s", zone_info.sep);
+ for (i = 0; i < stats[0].n_perc; i++) {
+ fprintf(stdout, "perc_%d%s", stats[0].perc[i],
+ zone_info.sep);
+ fprintf(stdout, "\n");
+ /* print stats */
+ for (z = 0; z < zone_info.n_zones; z++) {
+ char sum_str[100];
+ double mean, variance, stdev, var_coef;
+ /*for extendet stats */
+ double quartile_25 = 0.0, quartile_75 = 0.0, *quartile_perc;
+ double median = 0.0;
+ int qpos_25, qpos_75, *qpos_perc;
+ /* stats collected for this zone? */
+ if (stats[z].n == 0)
+ continue;
+ i = 0;
+ /* all these calculations get promoted to doubles, so any DIV0 becomes nan */
+ mean = stats[z].sum / stats[z].n;
+ variance = (stats[z].sumsq - stats[z].sum * stats[z].sum / stats[z].n) / stats[z].n;
+ if (variance < GRASS_EPSILON)
+ variance = 0.0;
+ stdev = sqrt(variance);
+ var_coef = (stdev / mean) * 100.; /* perhaps stdev/fabs(mean) ? */
+ /* zone number */
+ fprintf(stdout, "%d%s", z + zone_info.min, zone_info.sep);
+ /* zone label */
+ fprintf(stdout,"%s%s", G_get_c_raster_cat(&z + zone_info.min, &(zone_info.cats)), zone_info.sep);
+ /* total cells */
+ fprintf(stdout, "%d%s", stats[z].n, zone_info.sep);
+ /* null cells */
+ fprintf(stdout, "%d%s", stats[z].size - stats[z].n, zone_info.sep);
+ /* min */
+ fprintf(stdout, "%.15g%s", stats[z].min, zone_info.sep);
+ /* max */
+ fprintf(stdout, "%.15g%s", stats[z].max, zone_info.sep);
+ /* range */
+ fprintf(stdout, "%.15g%s", stats[z].max - stats[z].min, zone_info.sep);
+ /* mean */
+ fprintf(stdout, "%.15g%s", mean, zone_info.sep);
+ /* mean of abs */
+ fprintf(stdout, "%.15g%s", stats[z].sum_abs / stats[z].n, zone_info.sep);
+ /* stddev */
+ fprintf(stdout, "%.15g%s", stdev, zone_info.sep);
+ /* variance */
+ fprintf(stdout, "%.15g%s", variance, zone_info.sep);
+ /* coefficient of variance */
+ fprintf(stdout, "%.15g%s", var_coef, zone_info.sep);
+ /* sum */
+ sprintf(sum_str, "%.10f", stats[z].sum);
+ G_trim_decimal(sum_str);
+ fprintf(stdout, "%s%s", sum_str, zone_info.sep);
+ /* absolute sum */
+ sprintf(sum_str, "%.10f", stats[z].sum_abs);
+ /* TODO: mode, skewness, kurtosis */
+ if (param.extended->answer) {
+ qpos_perc = (int *)G_calloc(stats[z].n_perc, sizeof(int));
+ quartile_perc = (double *)G_calloc(stats[z].n_perc, sizeof(double));
+ for (i = 0; i < stats[z].n_perc; i++) {
+ qpos_perc[i] = (int)(stats[z].n * 1e-2 * stats[z].perc[i] - 0.5);
+ qpos_25 = (int)(stats[z].n * 0.25 - 0.5);
+ qpos_75 = (int)(stats[z].n * 0.75 - 0.5);
+ switch (stats[z].map_type) {
+ case CELL_TYPE:
+ heapsort_int(stats[z].cell_array, stats[z].n);
+ quartile_25 = (double)stats[z].cell_array[qpos_25];
+ if (stats[z].n % 2) /* odd */
+ median = (double)stats[z].cell_array[(int)(stats[z].n / 2)];
+ else /* even */
+ median =
+ (double)(stats[z].cell_array[stats[z].n / 2 - 1] +
+ stats[z].cell_array[stats[z].n / 2]) / 2.0;
+ quartile_75 = (double)stats[z].cell_array[qpos_75];
+ quartile_perc[i] = (double)stats[z].cell_array[qpos_perc[i]];
+ break;
+ case FCELL_TYPE:
+ heapsort_float(stats[z].fcell_array, stats[z].n);
+ quartile_25 = (double)stats[z].fcell_array[qpos_25];
+ median = (double)stats[z].fcell_array[(int)(stats[z].n / 2)];
+ else /* even */
+ median =
+ (double)(stats[z].fcell_array[stats[z].n / 2 - 1] +
+ stats[z].fcell_array[stats[z].n / 2]) / 2.0;
+ quartile_75 = (double)stats[z].fcell_array[qpos_75];
+ quartile_perc[i] = (double)stats[z].fcell_array[qpos_perc[i]];
+ break;
+ case DCELL_TYPE:
+ heapsort_double(stats[z].dcell_array, stats[z].n);
+ quartile_25 = stats[z].dcell_array[qpos_25];
+ median = stats[z].dcell_array[(int)(stats[z].n / 2)];
+ else /* even */
+ median =
+ (stats[z].dcell_array[stats[z].n / 2 - 1] +
+ stats[z].dcell_array[stats[z].n / 2]) / 2.0;
+ quartile_75 = stats[z].dcell_array[qpos_75];
+ quartile_perc[i] = stats[z].dcell_array[qpos_perc[i]];
+ break;
+ default:
+ break;
+ /* first quartile */
+ fprintf(stdout, "%g%s", quartile_25, zone_info.sep);
+ /* median */
+ fprintf(stdout, "%g%s", median, zone_info.sep);
+ /* third quartile */
+ fprintf(stdout, "%g%s", quartile_75, zone_info.sep);
+ /* percentiles */
+ quartile_perc[i], zone_info.sep);
+ G_free((void *)quartile_perc);
+ G_free((void *)qpos_perc);
+ /* zone z finished */
+ return 1;
