[GRASS-SVN] r36003 - grass/trunk/lib/vector/rtree
svn_grass at osgeo.org
Sat Feb 21 04:02:23 EST 2009
Author: mmetz
Date: 2009-02-21 04:02:22 -0500 (Sat, 21 Feb 2009)
New Revision: 36003
grass/trunk/lib/vector/rtree/index.c
grass/trunk/lib/vector/rtree/index.h
grass/trunk/lib/vector/rtree/rect.c
vector lib rtree segfault bugfix
Modified: grass/trunk/lib/vector/rtree/index.c
--- grass/trunk/lib/vector/rtree/index.c 2009-02-21 07:57:19 UTC (rev 36002)
+++ grass/trunk/lib/vector/rtree/index.c 2009-02-21 09:02:22 UTC (rev 36003)
@@ -53,7 +53,7 @@
if (n->level > 0) { /* this is an internal node in the tree */
for (i = 0; i < NODECARD; i++)
if (n->branch[i].child && RTreeOverlap(r, &n->branch[i].rect)) {
- hitCount += RTreeSearch(n->branch[i].child, R, shcb, cbarg);
+ hitCount += RTreeSearch(n->branch[i].child, r, shcb, cbarg);
else { /* this is a leaf node */
@@ -79,7 +79,7 @@
* level to insert; e.g. a data rectangle goes in at level = 0.
static int RTreeInsertRect2(struct Rect *r,
- int tid, struct Node *n, struct Node **new_node,
+ struct Node *child, struct Node *n, struct Node **new_node,
int level)
@@ -99,7 +99,7 @@
/* Still above level for insertion, go down tree recursively */
if (n->level > level) {
i = RTreePickBranch(r, n);
- if (!RTreeInsertRect2(r, tid, n->branch[i].child, &n2, level)) {
+ if (!RTreeInsertRect2(r, child, n->branch[i].child, &n2, level)) {
/* child was not split */
n->branch[i].rect = RTreeCombineRect(r, &(n->branch[i].rect));
return 0;
@@ -116,7 +116,7 @@
/* Have reached level for insertion. Add rect, split if necessary */
else if (n->level == level) {
b.rect = *r;
- b.child = (struct Node *)tid;
+ b.child = child;
/* child field of leaves contains tid of data record */
return RTreeAddBranch(&b, n, new_node);
@@ -137,8 +137,14 @@
int RTreeInsertRect(struct Rect *R, int Tid, struct Node **Root, int Level)
+ assert(Level == 0);
+ return RTreeInsertRect1(R, (struct Node *) Tid, Root, Level);
+int RTreeInsertRect1(struct Rect *R, struct Node *Child, struct Node **Root, int Level)
register struct Rect *r = R;
- register int tid = Tid;
+ register struct Node *child = Child;
register struct Node **root = Root;
register int level = Level;
register int i;
@@ -153,7 +159,7 @@
assert(r->boundary[i] <= r->boundary[NUMDIMS + i]);
- if (RTreeInsertRect2(r, tid, *root, &newnode, level)) { /* root split */
+ if (RTreeInsertRect2(r, child, *root, &newnode, level)) { /* root split */
newroot = RTreeNewNode(); /* grow a new root, & tree taller */
newroot->level = (*root)->level + 1;
b.rect = RTreeNodeCover(*root);
@@ -208,23 +214,23 @@
* Returns 1 if record not found, 0 if success.
static int
-RTreeDeleteRect2(struct Rect *R, int Tid, struct Node *N,
+RTreeDeleteRect2(struct Rect *R, struct Node *Child, struct Node *N,
struct ListNode **Ee)
register struct Node *n = N;
register struct ListNode **ee = Ee;
register int i;
assert(r && n && ee);
- assert(tid >= 0);
+ assert(child);
assert(n->level >= 0);
if (n->level > 0) { /* not a leaf node */
for (i = 0; i < NODECARD; i++) {
if (n->branch[i].child && RTreeOverlap(r, &(n->branch[i].rect))) {
- if (!RTreeDeleteRect2(r, tid, n->branch[i].child, ee)) {
+ if (!RTreeDeleteRect2(r, child, n->branch[i].child, ee)) {
if (n->branch[i].child->count >= MinNodeFill) {
n->branch[i].rect =
RTreeNodeCover(n->branch[i].child);
@@ -244,7 +250,7 @@
for (i = 0; i < LEAFCARD; i++) {
- n->branch[i].child == (struct Node *)tid) {
+ n->branch[i].child == child) {
RTreeDisconnectBranch(n, i);
return 0;
@@ -261,8 +267,15 @@
int RTreeDeleteRect(struct Rect *R, int Tid, struct Node **Nn)
+ /* wrapper not really needed, but restricts compile warnings to rtree lib */
+ /* this way it's easier to fix if necessary? */
+ return RTreeDeleteRect1(R, (struct Node *) Tid, Nn);
+int RTreeDeleteRect1(struct Rect *R, struct Node *Child, struct Node **Nn)
register struct Node **nn = Nn;
register int i;
struct Node *tmp_nptr = NULL;
@@ -271,9 +284,9 @@
assert(r && nn);
assert(*nn);
- assert(tid >= 0);
+ assert(child);
- if (!RTreeDeleteRect2(r, tid, *nn, &reInsertList)) {
+ if (!RTreeDeleteRect2(r, child, *nn, &reInsertList)) {
/* found and deleted a data item */
/* reinsert any branches from eliminated nodes */
@@ -281,8 +294,8 @@
tmp_nptr = reInsertList->node;
for (i = 0; i < MAXKIDS(tmp_nptr); i++) {
if (tmp_nptr->branch[i].child) {
- RTreeInsertRect(&(tmp_nptr->branch[i].rect),
- (int)tmp_nptr->branch[i].child,
+ RTreeInsertRect1(&(tmp_nptr->branch[i].rect),
+ tmp_nptr->branch[i].child,
nn, tmp_nptr->level);
Modified: grass/trunk/lib/vector/rtree/index.h
--- grass/trunk/lib/vector/rtree/index.h 2009-02-21 07:57:19 UTC (rev 36002)
+++ grass/trunk/lib/vector/rtree/index.h 2009-02-21 09:02:22 UTC (rev 36003)
@@ -79,7 +79,9 @@
extern int RTreeSearch(struct Node *, struct Rect *, SearchHitCallback,
void *);
extern int RTreeInsertRect(struct Rect *, int, struct Node **, int depth);
+extern int RTreeInsertRect1(struct Rect *, struct Node *, struct Node **, int depth);
extern int RTreeDeleteRect(struct Rect *, int, struct Node **);
+extern int RTreeDeleteRect1(struct Rect *, struct Node *, struct Node **);
extern struct Node *RTreeNewIndex(void);
extern struct Node *RTreeNewNode(void);
extern void RTreeInitNode(struct Node *);
Modified: grass/trunk/lib/vector/rtree/rect.c
--- grass/trunk/lib/vector/rtree/rect.c 2009-02-21 07:57:19 UTC (rev 36002)
+++ grass/trunk/lib/vector/rtree/rect.c 2009-02-21 09:02:22 UTC (rev 36003)
@@ -354,7 +354,7 @@
register struct Rect *r = R, *s = S;
register int i, j, result;
- assert((int)r && (int)s);
+ assert(r && s); /* same as in RTreeOverlap() */
/* undefined rect is contained in any other */
if (Undefined(r))
