[GRASS-SVN] r36047 - grass-addons/raster/r.univar2.zonal
svn_grass at osgeo.org
Sun Feb 22 09:59:30 EST 2009
Author: mmetz
Date: 2009-02-22 09:59:29 -0500 (Sun, 22 Feb 2009)
New Revision: 36047
grass-addons/raster/r.univar2.zonal/globals.h
grass-addons/raster/r.univar2.zonal/r.univar_main.c
grass-addons/raster/r.univar2.zonal/stats.c
less memory used
Modified: grass-addons/raster/r.univar2.zonal/globals.h
--- grass-addons/raster/r.univar2.zonal/globals.h 2009-02-22 13:35:41 UTC (rev 36046)
+++ grass-addons/raster/r.univar2.zonal/globals.h 2009-02-22 14:59:29 UTC (rev 36047)
@@ -39,6 +39,7 @@
CELL *cell_array;
int map_type;
void *nextp;
+ int n_alloc;
} univar_stat;
typedef struct
Modified: grass-addons/raster/r.univar2.zonal/r.univar_main.c
--- grass-addons/raster/r.univar2.zonal/r.univar_main.c 2009-02-22 13:35:41 UTC (rev 36046)
+++ grass-addons/raster/r.univar2.zonal/r.univar_main.c 2009-02-22 14:59:29 UTC (rev 36047)
@@ -36,7 +36,7 @@
_("Raster map used for zoning, must be of type CELL");
param.output_file = G_define_standard_option(G_OPT_F_OUTPUT);
- param.output_file->required = YES;
+ param.output_file->required = NO;
param.output_file->description =
_("Name for output file (if omitted or \"-\" output to stdout)");
@@ -290,6 +290,7 @@
for (col = 0; col < cols; col++) {
+ /* skip NULL cells in zone map altogether */
if (G_is_c_null_value(zptr)) {
ptr = G_incr_void_ptr(ptr, value_sz);
zptr++;
@@ -306,7 +307,30 @@
continue;
- if (stats[zone].nextp) {
+ if (param.extended->answer) {
+ /* check allocated memory */
+ if (stats[zone].n >= stats[zone].n_alloc) {
+ stats[zone].n_alloc += 1000;
+ size_t msize;
+ if (map_type == DCELL_TYPE) {
+ msize = stats[zone].n_alloc * sizeof(DCELL);
+ stats[zone].dcell_array =
+ (DCELL *)G_realloc((void *)stats[zone].dcell_array, msize);
+ stats[zone].nextp = (void *)&(stats[zone].dcell_array[stats[zone].n]);
+ else if (map_type == FCELL_TYPE) {
+ msize = stats[zone].n_alloc * sizeof(FCELL);
+ stats[zone].fcell_array =
+ (FCELL *)G_realloc((void *)stats[zone].fcell_array, msize);
+ stats[zone].nextp = (void *)&(stats[zone].fcell_array[stats[zone].n]);
+ else if (map_type == CELL_TYPE) {
+ msize = stats[zone].n_alloc * sizeof(CELL);
+ stats[zone].cell_array =
+ (CELL *)G_realloc((void *)stats[zone].cell_array, msize);
+ stats[zone].nextp = (void *)&(stats[zone].cell_array[stats[zone].n]);
/* put the value into stats->XXXcell_array */
memcpy(stats[zone].nextp, ptr, value_sz);
stats[zone].nextp = G_incr_void_ptr(stats[zone].nextp, value_sz);
Modified: grass-addons/raster/r.univar2.zonal/stats.c
--- grass-addons/raster/r.univar2.zonal/stats.c 2009-02-22 13:35:41 UTC (rev 36046)
+++ grass-addons/raster/r.univar2.zonal/stats.c 2009-02-22 14:59:29 UTC (rev 36047)
@@ -42,17 +42,23 @@
stats[i].cell_array = NULL;
stats[i].map_type = map_type;
+ stats[i].n_alloc = 0;
/* allocate memory for extended computation */
+ /* changed to on-demand block allocation */
- if (map_type == DCELL_TYPE)
- stats[i].dcell_array =
- (DCELL *) G_calloc(size, sizeof(DCELL));
- if (map_type == FCELL_TYPE)
- stats[i].fcell_array =
- (FCELL *) G_calloc(size, sizeof(FCELL));
- if (map_type == CELL_TYPE)
- stats[i].cell_array = (CELL *) G_calloc(size, sizeof(CELL));
+ stats[i].dcell_array = NULL;
+ stats[i].fcell_array =NULL;
+ stats[i].cell_array = NULL;
return stats;
