[GRASS-SVN] r36071 - grass/trunk/lib/init
svn_grass at osgeo.org
Tue Feb 24 00:16:34 EST 2009
Author: hamish
Date: 2009-02-24 00:16:33 -0500 (Tue, 24 Feb 2009)
New Revision: 36071
grass/trunk/lib/init/functions.sh
grass/trunk/lib/init/grass.bat
grass/trunk/lib/init/grass7.html
grass/trunk/lib/init/init.bat
grass/trunk/lib/init/init.sh
sync with devbr6: -wx alias, smaller prompt, don't try and clean non-existent .tmp files
Modified: grass/trunk/lib/init/functions.sh
--- grass/trunk/lib/init/functions.sh 2009-02-24 05:01:00 UTC (rev 36070)
+++ grass/trunk/lib/init/functions.sh 2009-02-24 05:16:33 UTC (rev 36071)
@@ -10,7 +10,7 @@
cat <<-EOF
Usage:
$CMD_NAME [-h | -help | --help] [-v | --version] [-c]
- [-text | -gui | -wxpython]
+ [-text | -gui | -wxpython | -wx]
[[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]
Flags:
@@ -21,7 +21,7 @@
and set as default
-gui use graphical user interface ($DEFAULT_GUI by default)
and set as default
- -wxpython use wxPython based graphical user interface
+ -wxpython or -wx use wxPython based graphical user interface
and set as default
Parameters:
Modified: grass/trunk/lib/init/grass.bat
--- grass/trunk/lib/init/grass.bat 2009-02-24 05:01:00 UTC (rev 36070)
+++ grass/trunk/lib/init/grass.bat 2009-02-24 05:16:33 UTC (rev 36071)
@@ -29,5 +29,5 @@
rem set GRASS_PROJSHARE=c:/grass/share/proj
set WINGISBASE=GISBASE_VALUE
-"%WINGISBASE%\etc\init.bat" %*
+"%WINGISBASE%\etc\Init.bat" %*
Modified: grass/trunk/lib/init/grass7.html
--- grass/trunk/lib/init/grass7.html 2009-02-24 05:01:00 UTC (rev 36070)
+++ grass/trunk/lib/init/grass7.html 2009-02-24 05:16:33 UTC (rev 36071)
@@ -17,7 +17,7 @@
<H2>SYNOPSIS</H2>
<B>grass70</B> [<B>-</B>] [<B>-v</B>] [<B>-h | -help | --help</B>]
- [<B>-text | -gui | -wxpython]</B>]
+ [<B>-text | -gui | -wxpython | -wx]</B>]
[[[<B><GISDBASE>/</B>]<B><LOCATION_NAME>/</B>]
<B><MAPSET></B>]
@@ -67,7 +67,7 @@
<DT><B>-text</B>
<DD> Indicates that the text based user interface should be used
-<DT><B>-gui</B> (or <B>-wxpython</B>)
+<DT><B>-gui</B> (or <B>-wxpython</B>, or <B>-wx</B>)
<DD> Indicates that the new Python based graphical user interface should be used
<DT><B>-v</B> <B>--version</B>
Modified: grass/trunk/lib/init/init.bat
--- grass/trunk/lib/init/init.bat 2009-02-24 05:01:00 UTC (rev 36070)
+++ grass/trunk/lib/init/init.bat 2009-02-24 05:16:33 UTC (rev 36071)
@@ -53,23 +53,28 @@
:aftertextcheck
if "%1" == "-gui" goto setguimode
+if "%1" == "-wx" goto setguimode
+if "%1" == "-wxpython" goto setguimode
:afterguicheck
+if exist "%WINGISRC%" (
+ set HAVE_GISRC=true
+ goto aftercreategisrc
-if exist "%WINGISRC%" goto aftercreategisrc
+set HAVE_GISRC=false
rem Create an initial GISRC file based on current directory
"%WINGISBASE%\etc\echo" "GISDBASE: %CD%" | g.dirseps -g > "%WINGISRC%"
"%WINGISBASE%\etc\echo" "LOCATION_NAME: <UNKNOWN>" >> "%WINGISRC%"
"%WINGISBASE%\etc\echo" "MAPSET: <UNKNOWN>" >> "%WINGISRC%"
:aftercreategisrc
rem Now set the real GISRC
FOR /F "usebackq delims==" %%i IN (`g.dirseps -g "%WINGISRC%"`) DO @set GISRC=%%i
rem Set GRASS_GUI
if "%GRASS_GUI%" == "" (
FOR /F "usebackq delims==" %%i IN (`g.gisenv "get=GRASS_GUI"`) DO @set GRASS_GUI=%%i
) else (
@@ -79,10 +84,12 @@
rem Set wxpython as default if not specified elsewhere
if "%GRASS_GUI%"=="" set GRASS_GUI=wxpython
+rem Clean out old .tmp files from the mapset
+if "%HAVE_GISRC%"=="true" (
+ "%WINGISBASE%\etc\clean_temp" > NUL:
+set HAVE_GISRC=
-"%WINGISBASE%\etc\clean_temp" > NUL:
if "%GRASS_GUI%"=="text" goto text
rem if return ok, wxpython start:
@@ -121,7 +128,7 @@
"%WINGISBASE%\etc\echo" "See the licence terms with: g.version -c"
"%WINGISBASE%\etc\echo" ""
-prompt GRASS %GRASS_VERSION% $C%LOCATION_NAME%$F:$P $G
+prompt GRASS %GRASS_VERSION% $C%LOCATION_NAME%$F$G
cmd.exe
@@ -149,6 +156,9 @@
:exitinit
+"%WINGISBASE%\etc\clean_temp" > NUL:
set PATH=%SAVEPATH%
set SAVEPATH=
exit /b
Modified: grass/trunk/lib/init/init.sh
--- grass/trunk/lib/init/init.sh 2009-02-24 05:01:00 UTC (rev 36070)
+++ grass/trunk/lib/init/init.sh 2009-02-24 05:16:33 UTC (rev 36071)
@@ -119,7 +119,7 @@
# Check if the -wxpython flag was given
- -wxpython)
+ -wxpython | -wx)
GRASS_GUI="wxpython"
shift
