[GRASS-SVN] r36072 - grass-addons/raster/r.univar2.zonal
svn_grass at osgeo.org
Tue Feb 24 01:25:57 EST 2009
Author: hamish
Date: 2009-02-24 01:25:57 -0500 (Tue, 24 Feb 2009)
New Revision: 36072
grass-addons/raster/r.univar2.zonal/r.univar.html
working example using SQL command file | db.execute added
Modified: grass-addons/raster/r.univar2.zonal/r.univar.html
--- grass-addons/raster/r.univar2.zonal/r.univar.html 2009-02-24 05:16:33 UTC (rev 36071)
+++ grass-addons/raster/r.univar2.zonal/r.univar.html 2009-02-24 06:25:57 UTC (rev 36072)
@@ -40,9 +40,29 @@
#### preform analysis
r.univar.zonal -t in=elevation.10m zones=fields.10m | \
- cut -f1,2,5,6,8 -d'|' > fields_stats.txt
+ cut -f1,5,6,8 -d'|' > fields_stats.txt
+#### populate vector DB with stats
+# create working copy of vector map
+g.copy vect=fields,fields_stats
+# create new attribute columns to hold output
+v.db.addcol map=fields_stats \
+ columns='mean_elev DOUBLE PRECISION, min_elev DOUBLE PRECISION, max_elev DOUBLE PRECISION'
+# create SQL command file, and execute it
+sed -e '1d' fields_stats.txt | awk -F'|' \
+ '{print "UPDATE fields_stats SET min_elev = "$2", max_elev = "$3", \
+ mean_elev = "$4" WHERE cat = "$1";"}' \
+ > fields_stats_sqlcmd.txt
+db.execute input=fields_stats_sqlcmd.txt
+###### alternate method with db.in.ogr: (needs work) ######
#### convert text file table to a database table
# not safe for commas in the label
tr '|' ',' < fields_stats.txt > fields_stats.csv
@@ -71,6 +91,10 @@
## how to automatically collate by key column, ie copy between tables?
## SELECT INTO? JOIN?
echo "INSERT INTO fields_stats (mean_elev,min_elev,max_elev) SELECT mean,min,max FROM fields_data" | db.execute
+#### view completed table
+v.db.select fields_stats
</pre></div>
