[GRASS-SVN] r36082 - grass-addons/raster/r.univar2.zonal
svn_grass at osgeo.org
Tue Feb 24 20:11:33 EST 2009
Author: hamish
Date: 2009-02-24 20:11:32 -0500 (Tue, 24 Feb 2009)
New Revision: 36082
Added:
grass-addons/raster/r.univar2.zonal/r.univar.zonal.html
Removed:
grass-addons/raster/r.univar2.zonal/r.univar.html
update option name, rename help file
Deleted: grass-addons/raster/r.univar2.zonal/r.univar.html
--- grass-addons/raster/r.univar2.zonal/r.univar.html 2009-02-24 20:52:07 UTC (rev 36081)
+++ grass-addons/raster/r.univar2.zonal/r.univar.html 2009-02-25 01:11:32 UTC (rev 36082)
@@ -1,134 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.univar.zonal</em> calculates the univariate statistics of a raster map.
-This includes the number of cells counted, minimum and maximum cell values,
-range, arithmetic mean, population variance, standard deviation, and
-coefficient of variation. Statistics are calculated separately for every
-category/zone found in the <b>zones</b> input map.
-If the <b>-e</b> extended statistics flag is given the 1st quartile, median,
-3rd quartile, and given <b>percentile</b> are calculated.
-If the <b>-g</b> flag is given the results are presented in a format suitable
-for use in a shell script.
-If the <b>-t</b> flag is given the results are presented in tabular format
-with "|" as field separator. The table can immediately be converted to a
-proper attribute table which can then be linked to a vector, e.g. the vector
-that was rasterized to create the <b>zones</b> input raster.
-<h2>NOTES</h2>
-As with most GRASS raster modules, <em>r.univar.zonal</em> operates on the cell
-array defined by the current region settings, not the original extent and
-resolution of the input map. See <em><a href="g.region.html">g.region</a></em>.
-<p>
-This module can use large amounts of system memory when the <b>-e</b>
-extended statistics flag is used with a very large region setting. If the
-region is too large the module should exit gracefully with a memory allocation
-error. Basic statistics can be calculated using any size input region.
-<h2>EXAMPLE</h2>
-Calculate the raster statistics for zones within a vector map coverage
-and upload the results for mean, min and max back to the vector map.
-<div class="code"><pre>
-#### set the raster region to match the map
-g.region vect=fields res=10 -ap
-#### create rasterized version of vector map
-v.to.rast in=fields out=fields.10m use=cat type=area labelcolumn=label
-r.colors fields.10m color=random
-#### perform analysis
-r.univar.zonal -t in=elevation.10m zones=fields.10m | \
- cut -f1,5,6,8 -d'|' > fields_stats.txt
-#### populate vector DB with stats
-# create working copy of vector map
-g.copy vect=fields,fields_stats
-# create new attribute columns to hold output
-v.db.addcol map=fields_stats \
- columns='mean_elev DOUBLE PRECISION, min_elev DOUBLE PRECISION, max_elev DOUBLE PRECISION'
-# create SQL command file, and execute it
-sed -e '1d' fields_stats.txt | awk -F'|' \
- '{print "UPDATE fields_stats SET min_elev = "$2", max_elev = "$3", \
- mean_elev = "$4" WHERE cat = "$1";"}' \
- > fields_stats_sqlcmd.txt
-db.execute input=fields_stats_sqlcmd.txt
-###### alternate method with db.in.ogr: (needs work) ######
-#### convert text file table to a database table
-# not safe for commas in the label
-tr '|' ',' < fields_stats.txt > fields_stats.csv
-echo '"Integer","String","Real","Real","Real"' > fields_stats.csvt
-# import table
-db.in.ogr dsn=fields_stats.csv output=fields_data
-# view table
-db.select fields_data
-# remove temporary files
-rm fields_stats.csv fields_stats.csvt fields_stats.txt
-# perform DB step (broken)
-## how to automatically collate by key column, ie copy between tables?
-## SELECT INTO? JOIN?
-echo "INSERT INTO fields_stats (mean_elev,min_elev,max_elev) SELECT mean,min,max FROM fields_data" | db.execute
-#### view completed table
-v.db.select fields_stats
-</pre></div>
-<h2>TODO</h2>
-<i>mode, skewness, kurtosis</i>
-<br>
-<i>3D zonal statistics</i>
-<h2>SEE ALSO</h2>
-<em>
-<a href="g.region.html">g.region</a><br>
-<a href="r3.univar.html">r3.univar</a><br>
-<a href="r.univar.sh.html">r.univar.sh</a><br>
-<a href="r.average.html">r.average</a><br>
-<a href="r.median.html">r.median</a><br>
-<a href="r.mode.html">r.mode</a><br>
-<a href="r.sum.html">r.sum</a><br>
-<a href="r.series.html">r.series</a><br>
-<a href="r.stats.html">r.stats</a><br>
-<a href="v.rast.stats.html">v.rast.stats</a><br>
-<a href="r.statistics.html">r.statistics</a><br>
-<a href="v.univar.html">v.univar</a><br>
-<a href="v.univar.sh.html">v.univar.sh</a><br>
-</em>
-<h2>AUTHORS</h2>
-Hamish Bowman, Otago University, New Zealand<br>
-Extended statistics by Martin Landa<br>
-Zonal loop by Markus Metz
-<p>
-<i>Last changed: $Date$</i>
Copied: grass-addons/raster/r.univar2.zonal/r.univar.zonal.html (from rev 36081, grass-addons/raster/r.univar2.zonal/r.univar.html)
--- grass-addons/raster/r.univar2.zonal/r.univar.zonal.html (rev 0)
+++ grass-addons/raster/r.univar2.zonal/r.univar.zonal.html 2009-02-25 01:11:32 UTC (rev 36082)
@@ -0,0 +1,134 @@
+<h2>DESCRIPTION</h2>
+<em>r.univar.zonal</em> calculates the univariate statistics of a raster map.
+This includes the number of cells counted, minimum and maximum cell values,
+range, arithmetic mean, population variance, standard deviation, and
+coefficient of variation. Statistics are calculated separately for every
+category/zone found in the <b>zones</b> input map.
+If the <b>-e</b> extended statistics flag is given the 1st quartile, median,
+3rd quartile, and given <b>percentile</b> are calculated.
+If the <b>-g</b> flag is given the results are presented in a format suitable
+for use in a shell script.
+If the <b>-t</b> flag is given the results are presented in tabular format
+with "|" as field separator. The table can immediately be converted to a
+proper attribute table which can then be linked to a vector, e.g. the vector
+that was rasterized to create the <b>zones</b> input raster.
+<h2>NOTES</h2>
+As with most GRASS raster modules, <em>r.univar.zonal</em> operates on the cell
+array defined by the current region settings, not the original extent and
+resolution of the input map. See <em><a href="g.region.html">g.region</a></em>.
+<p>
+This module can use large amounts of system memory when the <b>-e</b>
+extended statistics flag is used with a very large region setting. If the
+region is too large the module should exit gracefully with a memory allocation
+error. Basic statistics can be calculated using any size input region.
+<h2>EXAMPLE</h2>
+Calculate the raster statistics for zones within a vector map coverage
+and upload the results for mean, min and max back to the vector map.
+<div class="code"><pre>
+#### set the raster region to match the map
+g.region vect=fields res=10 -ap
+#### create rasterized version of vector map
+v.to.rast in=fields out=fields.10m use=cat type=area labelcolumn=label
+r.colors fields.10m color=random
+#### perform analysis
+r.univar.zonal -t map=elevation.10m zones=fields.10m | \
+ cut -f1,5,6,8 -d'|' > fields_stats.txt
+#### populate vector DB with stats
+# create working copy of vector map
+g.copy vect=fields,fields_stats
+# create new attribute columns to hold output
+v.db.addcol map=fields_stats \
+ columns='mean_elev DOUBLE PRECISION, min_elev DOUBLE PRECISION, max_elev DOUBLE PRECISION'
+# create SQL command file, and execute it
+sed -e '1d' fields_stats.txt | awk -F'|' \
+ '{print "UPDATE fields_stats SET min_elev = "$2", max_elev = "$3", \
+ mean_elev = "$4" WHERE cat = "$1";"}' \
+ > fields_stats_sqlcmd.txt
+db.execute input=fields_stats_sqlcmd.txt
+###### alternate method with db.in.ogr: (needs work) ######
+#### convert text file table to a database table
+# not safe for commas in the label
+tr '|' ',' < fields_stats.txt > fields_stats.csv
+echo '"Integer","String","Real","Real","Real"' > fields_stats.csvt
+# import table
+db.in.ogr dsn=fields_stats.csv output=fields_data
+# view table
+db.select fields_data
+# remove temporary files
+rm fields_stats.csv fields_stats.csvt fields_stats.txt
+# perform DB step (broken)
+## how to automatically collate by key column, ie copy between tables?
+## SELECT INTO? JOIN?
+echo "INSERT INTO fields_stats (mean_elev,min_elev,max_elev) SELECT mean,min,max FROM fields_data" | db.execute
+#### view completed table
+v.db.select fields_stats
+</pre></div>
+<h2>TODO</h2>
+<i>mode, skewness, kurtosis</i>
+<br>
+<i>3D zonal statistics</i>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a><br>
+<a href="r3.univar.html">r3.univar</a><br>
+<a href="r.univar.sh.html">r.univar.sh</a><br>
+<a href="r.average.html">r.average</a><br>
+<a href="r.median.html">r.median</a><br>
+<a href="r.mode.html">r.mode</a><br>
+<a href="r.sum.html">r.sum</a><br>
+<a href="r.series.html">r.series</a><br>
+<a href="r.stats.html">r.stats</a><br>
+<a href="v.rast.stats.html">v.rast.stats</a><br>
+<a href="r.statistics.html">r.statistics</a><br>
+<a href="v.univar.html">v.univar</a><br>
+<a href="v.univar.sh.html">v.univar.sh</a><br>
+</em>
+<h2>AUTHORS</h2>
+Hamish Bowman, Otago University, New Zealand<br>
+Extended statistics by Martin Landa<br>
+Zonal loop by Markus Metz
+<p>
+<i>Last changed: $Date$</i>
