[GRASS-SVN] r35138 - grass/branches/develbranch_6/visualization/nviz/scripts
Thu Jan 1 12:25:32 EST 2009
Author: cmbarton
Date: 2009-01-01 12:25:31 -0500 (Thu, 01 Jan 2009)
New Revision: 35138
   grass/branches/develbranch_6/visualization/nviz/scripts/panel_site.tcl
   grass/branches/develbranch_6/visualization/nviz/scripts/panel_vect.tcl
   grass/branches/develbranch_6/visualization/nviz/scripts/panel_vol.tcl
Fix buttons so that they display correctly on Mac aqua as well as in x11
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/panel_site.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/panel_site.tcl	2008-12-31 22:26:56 UTC (rev 35137)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/panel_site.tcl	2009-01-01 17:25:31 UTC (rev 35138)
@@ -55,8 +55,8 @@
 	Label $top.current -text "Current:" -anchor w
     mkMapList $top.list site
-	button $top.new -text New -anchor center -width 4 -command "add_map site" -bd 1
-	button $top.delete -text Delete -anchor center -width 4 -command "delete_map site" -bd 1
+	button $top.new -text New -anchor center -command "add_map site" -bd 1
+	button $top.delete -text Delete -anchor center -command "delete_map site" -bd 1
 	pack $top.current $top.list -side left
 	pack $top.delete $top.new -side right -expand 0
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/panel_vect.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/panel_vect.tcl	2008-12-31 22:26:56 UTC (rev 35137)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/panel_vect.tcl	2009-01-01 17:25:31 UTC (rev 35138)
@@ -38,7 +38,7 @@
     set curr [Nget_current vect]
-    if {0 != $curr}  {
+    if {$curr != 0}  {
 		set width [Nvect$curr get_att width]
 		set flat_state [Nvect$curr get_att flat]
 		set height [expr [lindex [Nvect$curr get_trans] 2] * 10]
@@ -66,8 +66,8 @@
     mkMapList $tmp.list vect
-	button $tmp.new -text New -anchor center -width 4 -command "add_map vect" -bd 1
-	button $tmp.delete -text Delete -anchor center -width 4 -command "delete_map vect" -bd 1
+	button $tmp.new -text New -anchor center -command "add_map vect" -bd 1
+	button $tmp.delete -text Delete -anchor center -command "delete_map vect" -bd 1
 	pack $tmp.current $tmp.list -side left
     pack $tmp.list -side left
@@ -374,25 +374,29 @@
 #Procedure to update vect atts from radiobutton
 proc check_list {address} {
-    global Nv_ flat_state curr vect_height
+    global Nv_
+    global flat_state
+    global curr
+    global vect_height
     set state [winfo exists $address]
-    if {0 != $curr}  {
-	set maplist [Nget_map_list surf]
+    if {$curr != 0}  {
+        set maplist [Nget_map_list surf]
         if {$state == 0 && $flat_state == 0 } {
-        #display on surface
-	catch {destroy $address}
-        Nvect$curr set_att flat 0
-	Nv_mkSurfacelist $address $maplist Nvect$curr vect
-	pack $address
-        if { $state == 1 && $flat_state == 1} {
-        #display on flat
-	Nvect$curr set_att flat 1
+            #display on surface
+            catch {destroy $address}
+            Nvect$curr set_att flat 0
+            Nv_mkSurfacelist $address $maplist Nvect$curr vect
+            pack $address
+        if {$state == 1 && $flat_state == 1} {
+            #display on flat
+            Nvect$curr set_att flat 1
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/panel_vol.tcl
--- grass/branches/develbranch_6/visualization/nviz/scripts/panel_vol.tcl	2008-12-31 22:26:56 UTC (rev 35137)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/panel_vol.tcl	2009-01-01 17:25:31 UTC (rev 35138)
@@ -50,8 +50,8 @@
     label $tmp.current -text "Current:" -anchor w
     mkMapList $tmp.list vol
-    button $tmp.new -text New -anchor center -bd 1 -width 4 -command new_vol
-    button $tmp.delete -text Delete -anchor center -bd 1 -width 4 -command delete_vol
+    button $tmp.new -text New -anchor center -bd 1 -command new_vol
+    button $tmp.delete -text Delete -anchor center -bd 1 -command delete_vol
 	pack $tmp.delete $tmp.new -side right -expand 0
