[GRASS-SVN] r35139 -
grass/branches/releasebranch_6_4/visualization/nviz/scripts
svn_grass at osgeo.org
Thu Jan 1 12:28:47 EST 2009
Author: cmbarton
Date: 2009-01-01 12:28:47 -0500 (Thu, 01 Jan 2009)
New Revision: 35139
grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_site.tcl
grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_vect.tcl
grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_vol.tcl
Fix buttons so that they display properly in Mac aqua as well as x11
Modified: grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_site.tcl
--- grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_site.tcl 2009-01-01 17:25:31 UTC (rev 35138)
+++ grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_site.tcl 2009-01-01 17:28:47 UTC (rev 35139)
@@ -55,8 +55,8 @@
Label $top.current -text "Current:" -anchor w
mkMapList $top.list site
- button $top.new -text New -anchor center -width 4 -command "add_map site" -bd 1
- button $top.delete -text Delete -anchor center -width 4 -command "delete_map site" -bd 1
+ button $top.new -text New -anchor center -command "add_map site" -bd 1
+ button $top.delete -text Delete -anchor center -command "delete_map site" -bd 1
pack $top.current $top.list -side left
pack $top.delete $top.new -side right -expand 0
Modified: grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_vect.tcl
--- grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_vect.tcl 2009-01-01 17:25:31 UTC (rev 35138)
+++ grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_vect.tcl 2009-01-01 17:28:47 UTC (rev 35139)
@@ -38,7 +38,7 @@
set curr [Nget_current vect]
- if {0 != $curr} {
+ if {$curr != 0} {
set width [Nvect$curr get_att width]
set flat_state [Nvect$curr get_att flat]
set height [expr [lindex [Nvect$curr get_trans] 2] * 10]
@@ -66,8 +66,8 @@
mkMapList $tmp.list vect
- button $tmp.new -text New -anchor center -width 4 -command "add_map vect" -bd 1
- button $tmp.delete -text Delete -anchor center -width 4 -command "delete_map vect" -bd 1
+ button $tmp.new -text New -anchor center -command "add_map vect" -bd 1
+ button $tmp.delete -text Delete -anchor center -command "delete_map vect" -bd 1
pack $tmp.current $tmp.list -side left
pack $tmp.list -side left
@@ -374,25 +374,29 @@
#Procedure to update vect atts from radiobutton
proc check_list {address} {
- global Nv_ flat_state curr vect_height
+ global Nv_
+ global flat_state
+ global curr
+ global vect_height
set state [winfo exists $address]
- if {0 != $curr} {
- set maplist [Nget_map_list surf]
+ if {$curr != 0} {
+ set maplist [Nget_map_list surf]
if {$state == 0 && $flat_state == 0 } {
- #display on surface
- catch {destroy $address}
- Nvect$curr set_att flat 0
- Nv_mkSurfacelist $address $maplist Nvect$curr vect
- pack $address
- if { $state == 1 && $flat_state == 1} {
- #display on flat
- Nvect$curr set_att flat 1
+ #display on surface
+ catch {destroy $address}
+ Nvect$curr set_att flat 0
+ Nv_mkSurfacelist $address $maplist Nvect$curr vect
+ pack $address
+ if {$state == 1 && $flat_state == 1} {
+ #display on flat
+ Nvect$curr set_att flat 1
Modified: grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_vol.tcl
--- grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_vol.tcl 2009-01-01 17:25:31 UTC (rev 35138)
+++ grass/branches/releasebranch_6_4/visualization/nviz/scripts/panel_vol.tcl 2009-01-01 17:28:47 UTC (rev 35139)
@@ -50,8 +50,8 @@
label $tmp.current -text "Current:" -anchor w
mkMapList $tmp.list vol
- button $tmp.new -text New -anchor center -bd 1 -width 4 -command new_vol
- button $tmp.delete -text Delete -anchor center -bd 1 -width 4 -command delete_vol
+ button $tmp.new -text New -anchor center -bd 1 -command new_vol
+ button $tmp.delete -text Delete -anchor center -bd 1 -command delete_vol
pack $tmp.delete $tmp.new -side right -expand 0
