[GRASS-SVN] r35182 - grass/branches/releasebranch_6_4/display/d.vect
svn_grass at osgeo.org
Sat Jan 3 08:25:20 EST 2009
Author: neteler
Date: 2009-01-03 08:25:19 -0500 (Sat, 03 Jan 2009)
New Revision: 35182
grass/branches/releasebranch_6_4/display/d.vect/area.c
mlennert: draw boundary also with -c (trac #171)
Modified: grass/branches/releasebranch_6_4/display/d.vect/area.c
--- grass/branches/releasebranch_6_4/display/d.vect/area.c 2009-01-03 13:24:59 UTC (rev 35181)
+++ grass/branches/releasebranch_6_4/display/d.vect/area.c 2009-01-03 13:25:19 UTC (rev 35182)
@@ -380,14 +380,9 @@
int i;
Vect_get_area_points(Map, area, Points);
- if (rgb) {
- R_RGB_color((unsigned char)red, (unsigned char)grn,
- (unsigned char)blu);
- else {
- R_RGB_color(bcolor->r, bcolor->g, bcolor->b);
- /*use different user defined render methods */
+ R_RGB_color(bcolor->r, bcolor->g, bcolor->b);
+ /*use different user defined render methods */
plot_polyline(Points->x, Points->y, Points->n_points);
for (i = 0; i < n_isles; i++) {
isle = Vect_get_area_isle(Map, area, i);
