[GRASS-SVN] r35213 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Jan 4 14:11:16 EST 2009
Author: martinl
Date: 2009-01-04 14:11:16 -0500 (Sun, 04 Jan 2009)
New Revision: 35213
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
gselect.py synchronized with trunk
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-01-04 19:10:17 UTC (rev 35212)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2009-01-04 19:11:16 UTC (rev 35213)
@@ -125,11 +125,8 @@
if not root:
return
item = self.FindItem(root, self.value[0])
- try:
- self.seltree.SelectItem(item)
- self.seltree.EnsureVisible(item)
- except:
- pass
+ self.seltree.EnsureVisible(item)
+ self.seltree.SelectItem(item)
def SetStringValue(self, value):
# this assumes that item strings are unique...
@@ -328,6 +325,7 @@
nuldev = file(os.devnull, 'w+')
self.layers = grass.vector_db(map=self.map, stderr=nuldev)
nuldev.close()
if (len(self.layers.keys()) == 0):
return False
@@ -338,38 +336,28 @@
for layer in self.layers.keys():
# determine column names and types
table = self.layers[layer]["table"]
- columnsCommand = gcmd.Command (cmd=["db.describe",
- "-c", "--q",
- "table=%s" % self.layers[layer]["table"],
- "driver=%s" % self.layers[layer]["driver"],
- "database=%s" % self.layers[layer]["database"]])
columns = {} # {name: {type, length, [values], [ids]}}
+ i = 0
+ for item in grass.db_describe(table = self.layers[layer]["table"],
+ driver = self.layers[layer]["driver"],
+ database = self.layers[layer]["database"])['cols']:
+ name, type, length = item
+ # FIXME: support more datatypes
+ if type.lower() == "integer":
+ ctype = int
+ elif type.lower() == "double precision":
+ ctype = float
+ else:
+ ctype = str
- if columnsCommand.returncode == 0:
- # skip nrows and ncols
- i = 0
- for line in columnsCommand.ReadStdOutput()[2:]:
- num, name, type, length = line.strip().split(':')
- # FIXME: support more datatypes
- if type.lower() == "integer":
- ctype = int
- elif type.lower() == "double precision":
- ctype = float
- else:
- ctype = str
- columns[name.strip()] = { 'index' : i,
- 'type' : type.lower(),
- 'ctype' : ctype,
- 'length' : int(length),
- 'values' : [],
- 'ids' : []}
- i += 1
- else:
- return False
+ columns[name.strip()] = { 'index' : i,
+ 'type' : type.lower(),
+ 'ctype' : ctype,
+ 'length' : int(length),
+ 'values' : [],
+ 'ids' : []}
+ i += 1
# check for key column
# v.db.connect -g/p returns always key column name lowercase
if self.layers[layer]["key"] not in columns.keys():
@@ -426,7 +414,7 @@
def InsertLayers(self, vector):
"""Insert layers for a vector into the layer combobox"""
layerchoices = utils.GetVectorNumberOfLayers(vector)
if self.all:
layerchoices.insert(0, '-1')
if len(layerchoices) > 1:
@@ -486,17 +474,20 @@
def InsertTables(self, driver=None, database=None):
"""Insert attribute tables into combobox"""
items = []
- tableCmd = None
+ if not driver or not database:
+ connect = grass.db_connection()
+ driver = connect['driver']
+ database = connect['database']
ret = gcmd.RunCommand('db.tables',
- parent = self,
- read = True,
flags = 'p',
+ read = True,
driver = driver,
database = database)
- if ret == None:
- tableCmd = None
- else:
+ if ret:
for table in ret.split('\n'):
if len(table) > 0:
items.append(table)
