[GRASS-SVN] r35214 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Sun Jan 4 14:22:13 EST 2009
Author: martinl
Date: 2009-01-04 14:22:13 -0500 (Sun, 04 Jan 2009)
New Revision: 35214
grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: eliminate gcmd.Command()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2009-01-04 19:11:16 UTC (rev 35213)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2009-01-04 19:22:13 UTC (rev 35214)
@@ -991,7 +991,9 @@
listOfDrivers = self.settings.Get(group='display', key='driver', subkey='choices', internal=True)
# check if cairo is available
if 'cairo' not in listOfDrivers:
- for line in gcmd.Command(['d.mon', '-l']).ReadStdOutput():
+ for line in gcmd.RunCommand('d.mon',
+ flags = 'l',
+ read = True):
if 'cairo' in line:
listOfDrivers.append('cairo')
break
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2009-01-04 19:11:16 UTC (rev 35213)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2009-01-04 19:22:13 UTC (rev 35214)
@@ -133,9 +133,11 @@
if UserSettings.Get(group='display', key='driver', subkey='type') == 'cairo':
os.environ["GRASS_CAIROFILE"] = self.mapfile
- if 'cairo' not in gcmd.Command(['d.mon', '-p']).ReadStdOutput()[0]:
- gcmd.Command(['d.mon',
- 'start=cairo'], stderr=None)
+ if 'cairo' not in gcmd.RunCommand('d.mon',
+ flags='p',
+ read = True):
+ gcmd.RunCommand('d.mon',
+ start = 'cairo')
else:
if self.mapfile:
os.environ["GRASS_PNGFILE"] = self.mapfile
@@ -186,8 +188,8 @@
# stop monitor
- 'stop=cairo'], stderr=None)
+ stop = 'cairo')
del os.environ["GRASS_CAIROFILE"]
elif os.environ.has_key("GRASS_PNGFILE"):
del os.environ["GRASS_PNGFILE"]
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2009-01-04 19:11:16 UTC (rev 35213)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2009-01-04 19:22:13 UTC (rev 35214)
@@ -953,19 +953,20 @@
gisbase = os.environ['GISBASE']
# make list of xmons that are not running
- cmdlist = ["d.mon", "-L"]
- p = gcmd.Command(cmdlist)
+ ret = gcmd.RunCommand('d.mon',
+ flags = 'L',
+ read = True)
- for line in p.ReadStdOutput():
+ for line in ret.split('\n'):
line = line.strip()
if line.startswith('x') and 'not running' in line:
xmonlist.append(line[0:2])
# open available xmon
xmon = xmonlist[0]
- cmdlist = ["d.mon","start=%s" % xmon]
+ start = xmon)
# run the command
runbat = os.path.join(gisbase,'etc','grass-run.bat')
xtermwrapper = os.path.join(gisbase,'etc','grass-xterm-wrapper')
@@ -976,6 +977,7 @@
cmdlist = ["cmd.exe", "/c", 'start "%s"' % runbat, command]
else:
cmdlist = [xtermwrapper, '-e "%s"' % grassrun, command]
# reset display mode
