[GRASS-SVN] r35311 - grass/trunk/doc/vector
svn_grass at osgeo.org
Sat Jan 10 04:09:27 EST 2009
Author: neteler
Date: 2009-01-10 04:09:27 -0500 (Sat, 10 Jan 2009)
New Revision: 35311
grass/trunk/doc/vector/TODO
some suggestions moved into trac as ticket
Modified: grass/trunk/doc/vector/TODO
--- grass/trunk/doc/vector/TODO 2009-01-10 09:09:17 UTC (rev 35310)
+++ grass/trunk/doc/vector/TODO 2009-01-10 09:09:27 UTC (rev 35311)
@@ -225,11 +225,6 @@
'and,not,nor' operators are used. An inspiration is available in
v.select.
-v.buffer
-Completely rewrite if possible or at least fix the bug which is
-probably in clean_parallel() in lib/vector/Vlib/buffer.c.
v.pack/v.unpack
Write it. New modules to pack/unpack a vector to/from single file
@@ -239,18 +234,7 @@
probably better to use copy of 'coor' file and attributes written to
SQLite database.
-v.in.ogr
-It would be useful to split long boundaries to smaller
-pieces. Otherwise cleaning process can become very slow because
-bounding box of long boundaries can overlap large part of the map (for
-example outline around all areas) and cleaning process is checking
-intersection with all boundaries falling in the bounding box.
-v.out.ogr
-v.out.ogr is very slow because it is using random access to the
-attributes. It should be rewritten so that all attributes are selected
-by one query, geometry for each attribute can be searched by category
-index (which is fast).
+1/2009: Other suggestions moved to
+ http://trac.osgeo.org/grass/
