[GRASS-SVN] r35312 - grass/branches/releasebranch_6_3/lib/proj
svn_grass at osgeo.org
Sat Jan 10 07:14:48 EST 2009
Author: neteler
Date: 2009-01-10 07:14:48 -0500 (Sat, 10 Jan 2009)
New Revision: 35312
grass/branches/releasebranch_6_3/lib/proj/convert.c
grass/branches/releasebranch_6_3/lib/proj/datum.c
grass/branches/releasebranch_6_3/lib/proj/do_proj.c
grass/branches/releasebranch_6_3/lib/proj/ellipse.c
grass/branches/releasebranch_6_3/lib/proj/get_proj.c
grass64/tools/grass_indent.sh applied for easier bugtracking
Modified: grass/branches/releasebranch_6_3/lib/proj/convert.c
--- grass/branches/releasebranch_6_3/lib/proj/convert.c 2009-01-10 09:09:27 UTC (rev 35311)
+++ grass/branches/releasebranch_6_3/lib/proj/convert.c 2009-01-10 12:14:48 UTC (rev 35312)
@@ -31,7 +31,7 @@
/* GRASS relative location of OGR co-ordinate system lookup tables */
#define CSVDIR "/etc/ogr_csv"
-static void DatumNameMassage( char ** );
+static void DatumNameMassage(char **);
* \brief Converts a GRASS co-ordinate system representation to WKT style.
@@ -59,10 +59,10 @@
char *wkt;
hSRS = GPJ_grass_to_osr(proj_info, proj_units);
if (hSRS == NULL)
- return NULL;
+ return NULL;
if (esri_style)
OSRMorphToESRI(hSRS);
@@ -86,24 +86,24 @@
OGRSpatialReferenceH GPJ_grass_to_osr(struct Key_Value * proj_info,
- struct Key_Value * proj_units)
+ struct Key_Value * proj_units)
struct pj_info pjinfo;
char *proj4, *proj4mod, *wkt, *modwkt, *startmod, *lastpart;
OGRSpatialReferenceH hSRS, hSRS2;
OGRErr errcode;
struct gpj_datum dstruct;
- struct gpj_ellps estruct;
+ struct gpj_ellps estruct;
size_t len;
char *ellps, *ellpslong, *datum, *params, *towgs84, *datumlongname,
- *start, *end, *unit, *unfact, *buff;
+ *start, *end, *unit, *unfact, *buff;
const char *sysname, *osrunit, *osrunfact;
double a, es, rf;
int haveparams = 0;
- if( (proj_info == NULL) || (proj_units == NULL) )
- return NULL;
+ if ((proj_info == NULL) || (proj_units == NULL))
+ return NULL;
hSRS = OSRNewSpatialReference(NULL);
if (pj_get_kv(&pjinfo, proj_info, proj_units) < 0) {
@@ -124,7 +124,7 @@
proj4mod = proj4;
if ((errcode = OSRImportFromProj4(hSRS, proj4mod)) != OGRERR_NONE) {
- G_warning(_("OGR can't parse PROJ.4-style parameter string:\n"
+ G_warning(_("OGR can't parse PROJ.4-style parameter string:\n"
"%s\n(OGR Error code was %d)"), proj4mod, errcode);
return NULL;
@@ -148,16 +148,15 @@
datumlongname = G_store(dstruct.longname);
if (ellps == NULL)
ellps = G_store(dstruct.ellps);
- GPJ_free_datum(&dstruct);
+ GPJ_free_datum(&dstruct);
- if( GPJ_get_ellipsoid_by_name(ellps, &estruct) > 0 )
+ if (GPJ_get_ellipsoid_by_name(ellps, &estruct) > 0) {
ellpslong = G_store(estruct.longname);
DatumNameMassage(&ellpslong);
- GPJ_free_ellps(&estruct);
+ GPJ_free_ellps(&estruct);
else
- ellpslong = G_store(ellps);
+ ellpslong = G_store(ellps);
startmod = G_strstr(wkt, "GEOGCS");
lastpart = G_strstr(wkt, "PRIMEM");
@@ -167,6 +166,7 @@
/* Only put datum params into the WKT if they were specifically
* specified in PROJ_INFO */
char *paramkey, *paramvalue;
paramkey = strtok(params, "=");
paramvalue = params + strlen(paramkey) + 1;
if (G_strcasecmp(paramkey, "towgs84") == 0)
@@ -214,8 +214,8 @@
G_asprintf(&modwkt,
"%sGEOGCS[\"%s\",DATUM[\"%s\",SPHEROID[\"%s\",%.16g,%.16g]%s],%s%s",
- start, ellps, datumlongname, ellpslong, a, rf, towgs84, lastpart,
- end);
+ start, ellps, datumlongname, ellpslong, a, rf, towgs84,
+ lastpart, end);
hSRS2 = OSRNewSpatialReference(modwkt);
@@ -255,8 +255,8 @@
* been defined
-int GPJ_osr_to_grass(struct Cell_head *cellhd, struct Key_Value **projinfo,
- struct Key_Value **projunits, OGRSpatialReferenceH hSRS,
+int GPJ_osr_to_grass(struct Cell_head *cellhd, struct Key_Value **projinfo,
+ struct Key_Value **projunits, OGRSpatialReferenceH hSRS,
int datumtrans)
struct Key_Value *temp_projinfo;
@@ -264,404 +264,383 @@
char *pszProj = NULL;
char *datum = NULL;
- if( hSRS == NULL )
- goto default_to_xy;
+ if (hSRS == NULL)
+ goto default_to_xy;
/* Set finder function for locating OGR csv co-ordinate system tables */
- SetCSVFilenameHook( GPJ_set_csv_loc );
+ SetCSVFilenameHook(GPJ_set_csv_loc);
/* Hopefully this doesn't do any harm if it wasn't in ESRI format
* to start with... */
- OSRMorphFromESRI( hSRS );
+ OSRMorphFromESRI(hSRS);
-/* Set cellhd for well known coordinate systems. */
- if( !OSRIsGeographic( hSRS ) && !OSRIsProjected( hSRS ) )
+ /* Set cellhd for well known coordinate systems. */
+ if (!OSRIsGeographic(hSRS) && !OSRIsProjected(hSRS))
- if( cellhd )
- int bNorth;
+ if (cellhd) {
+ int bNorth;
- if( OSRIsGeographic( hSRS ) )
- cellhd->proj = PROJECTION_LL;
- cellhd->zone = 0;
- else if( OSRGetUTMZone( hSRS, &bNorth ) != 0 )
- cellhd->proj = PROJECTION_UTM;
- cellhd->zone = OSRGetUTMZone( hSRS, &bNorth );
- if( !bNorth )
- cellhd->zone *= -1;
- else
- cellhd->proj = PROJECTION_OTHER;
- cellhd->zone = 0;
+ if (OSRIsGeographic(hSRS)) {
+ cellhd->proj = PROJECTION_LL;
+ cellhd->zone = 0;
+ else if (OSRGetUTMZone(hSRS, &bNorth) != 0) {
+ cellhd->proj = PROJECTION_UTM;
+ cellhd->zone = OSRGetUTMZone(hSRS, &bNorth);
+ if (!bNorth)
+ cellhd->zone *= -1;
+ else {
+ cellhd->proj = PROJECTION_OTHER;
+ cellhd->zone = 0;
-/* Get the coordinate system definition in PROJ.4 format. */
- if( OSRExportToProj4( hSRS, &pszProj4 ) != OGRERR_NONE )
+ /* Get the coordinate system definition in PROJ.4 format. */
+ if (OSRExportToProj4(hSRS, &pszProj4) != OGRERR_NONE)
-/* Parse the PROJ.4 string into key/value pairs. Do a bit of */
-/* extra work to "GRASSify" the result. */
+ /* Parse the PROJ.4 string into key/value pairs. Do a bit of */
+ /* extra work to "GRASSify" the result. */
temp_projinfo = G_create_key_value();
pszRemaining = pszProj4;
- while( (pszRemaining = strstr(pszRemaining,"+")) != NULL )
- char *pszToken, *pszValue;
+ while ((pszRemaining = strstr(pszRemaining, "+")) != NULL) {
+ char *pszToken, *pszValue;
- pszRemaining++;
- /* Advance pszRemaining to end of this token[=value] pair */
- pszToken = pszRemaining;
- while( *pszRemaining != ' ' && *pszRemaining != '\0' )
- pszRemaining++;
+ pszRemaining++;
- if( *pszRemaining == ' ' )
- *pszRemaining = '\0';
- pszRemaining++;
+ /* Advance pszRemaining to end of this token[=value] pair */
+ pszToken = pszRemaining;
+ while (*pszRemaining != ' ' && *pszRemaining != '\0')
+ pszRemaining++;
- /* parse token, and value */
- if( strstr(pszToken,"=") != NULL )
- pszValue = strstr(pszToken,"=");
- *pszValue = '\0';
- pszValue++;
- else
- pszValue = "defined";
+ if (*pszRemaining == ' ') {
+ *pszRemaining = '\0';
+ pszRemaining++;
- if( G_strcasecmp(pszToken,"proj") == 0 )
- /* The ll projection is known as longlat in PROJ.4 */
- if( G_strcasecmp(pszValue,"longlat") == 0 )
- pszValue = "ll";
- pszProj = pszValue;
+ /* parse token, and value */
+ if (strstr(pszToken, "=") != NULL) {
+ pszValue = strstr(pszToken, "=");
+ *pszValue = '\0';
+ pszValue++;
+ else
+ pszValue = "defined";
+ if (G_strcasecmp(pszToken, "proj") == 0) {
+ /* The ll projection is known as longlat in PROJ.4 */
+ if (G_strcasecmp(pszValue, "longlat") == 0)
+ pszValue = "ll";
+ pszProj = pszValue;
continue;
- /* Ellipsoid and datum handled separately below */
- if( G_strcasecmp(pszToken,"ellps") == 0
- || G_strcasecmp(pszToken,"a") == 0
- || G_strcasecmp(pszToken,"b") == 0
- || G_strcasecmp(pszToken,"es") == 0
- || G_strcasecmp(pszToken,"rf") == 0
- || G_strcasecmp(pszToken,"datum") == 0 )
- continue;
- /* We will handle units separately */
- if( G_strcasecmp(pszToken,"to_meter") == 0
- || G_strcasecmp(pszToken,"units") == 0 )
- continue;
+ /* Ellipsoid and datum handled separately below */
+ if (G_strcasecmp(pszToken, "ellps") == 0
+ || G_strcasecmp(pszToken, "a") == 0
+ || G_strcasecmp(pszToken, "b") == 0
+ || G_strcasecmp(pszToken, "es") == 0
+ || G_strcasecmp(pszToken, "rf") == 0
+ || G_strcasecmp(pszToken, "datum") == 0)
+ continue;
- G_set_key_value( pszToken, pszValue, temp_projinfo );
+ /* We will handle units separately */
+ if (G_strcasecmp(pszToken, "to_meter") == 0
+ || G_strcasecmp(pszToken, "units") == 0)
+ continue;
+ G_set_key_value(pszToken, pszValue, temp_projinfo);
*projinfo = G_create_key_value();
-/* Derive the user name for the projection. */
- if( pszProj )
- char path[4095];
- char name[80];
- sprintf(path,"%s/etc/projections",G_gisbase());
- if( G_lookup_key_value_from_file(path,pszProj,name,sizeof(name)) > 0 )
- G_set_key_value( "name", name, *projinfo );
- else
- G_set_key_value( "name", pszProj, *projinfo );
- G_set_key_value( "proj", pszProj, *projinfo );
+ /* Derive the user name for the projection. */
+ if (pszProj) {
+ char path[4095];
+ char name[80];
+ sprintf(path, "%s/etc/projections", G_gisbase());
+ if (G_lookup_key_value_from_file(path, pszProj, name, sizeof(name)) >
+ 0)
+ G_set_key_value("name", name, *projinfo);
+ else
+ G_set_key_value("name", pszProj, *projinfo);
+ G_set_key_value("proj", pszProj, *projinfo);
else
G_warning(_("No projection name! Projection parameters likely to be meaningless."));
-/* Find the GRASS datum name and choose parameters either */
-/* interactively or not. */
- const char *pszDatumNameConst = OSRGetAttrValue( hSRS, "DATUM", 0 );
- struct datum_list *list, *listhead;
- char *dum1, *dum2, *pszDatumName;
- int paramspresent = GPJ__get_datum_params(temp_projinfo, &dum1, &dum2);
+ /* Find the GRASS datum name and choose parameters either */
+ /* interactively or not. */
- if ( pszDatumNameConst )
+ const char *pszDatumNameConst = OSRGetAttrValue(hSRS, "DATUM", 0);
+ struct datum_list *list, *listhead;
+ char *dum1, *dum2, *pszDatumName;
+ int paramspresent =
+ GPJ__get_datum_params(temp_projinfo, &dum1, &dum2);
+ if (pszDatumNameConst) {
/* Need to make a new copy of the string so we don't mess
* around with the memory inside the OGRSpatialReferenceH? */
- pszDatumName = G_store( pszDatumNameConst );
- DatumNameMassage( &pszDatumName );
+ pszDatumName = G_store(pszDatumNameConst);
+ DatumNameMassage(&pszDatumName);
- list = listhead = read_datum_table();
- while (list != NULL) {
- if (G_strcasecmp(pszDatumName, list->longname) == 0) {
- datum = G_store(list->name);
- break;
- list = list->next;
- free_datum_list(listhead);
- if (datum == NULL)
- if( paramspresent < 2)
+ list = listhead = read_datum_table();
+ while (list != NULL) {
+ if (G_strcasecmp(pszDatumName, list->longname) == 0) {
+ datum = G_store(list->name);
+ break;
+ list = list->next;
+ free_datum_list(listhead);
+ if (datum == NULL) {
+ if (paramspresent < 2)
/* Only give warning if no parameters present */
- G_warning(_("Datum <%s> not recognised by GRASS and no parameters found."),
+ G_warning(_("Datum <%s> not recognised by GRASS and no parameters found."),
pszDatumName);
- else
- G_set_key_value( "datum", datum, *projinfo );
+ else {
+ G_set_key_value("datum", datum, *projinfo);
- if (paramspresent < 2)
- /* If no datum parameters were imported from the OSR
- * object then we should use the set specified by datumtrans */
- char *params, *chosenparams = NULL;
- int paramsets;
+ if (paramspresent < 2) {
+ /* If no datum parameters were imported from the OSR
+ * object then we should use the set specified by datumtrans */
+ char *params, *chosenparams = NULL;
+ int paramsets;
- paramsets = GPJ_get_default_datum_params_by_name(datum, ¶ms);
+ paramsets =
+ GPJ_get_default_datum_params_by_name(datum, ¶ms);
- if( paramsets < 0 )
- G_warning(_("Datum <%s> apparently recognised by GRASS but no parameters found. "
- "You may want to look into this."), datum );
- else if( datumtrans > paramsets )
+ if (paramsets < 0)
+ G_warning(_("Datum <%s> apparently recognised by GRASS but no parameters found. "
+ "You may want to look into this."), datum);
+ else if (datumtrans > paramsets) {
- G_warning(_("Invalid tranformation number %d; valid range is 1 to %d. "
- "Leaving datum transform parameters unspecified."),
- datumtrans, paramsets);
- datumtrans = 0;
+ G_warning(_("Invalid tranformation number %d; valid range is 1 to %d. "
+ "Leaving datum transform parameters unspecified."),
+ datumtrans, paramsets);
+ datumtrans = 0;
- if( paramsets > 0 )
- struct gpj_datum_transform_list *list, *old;
- list = GPJ_get_datum_transform_by_name( datum );
- if( list != NULL )
- do
- if( list->count == datumtrans )
- chosenparams = G_store( list->params );
- break;
- old = list;
- G_free( old );
- } while(list != NULL);
- if( chosenparams != NULL )
- char *paramkey, *paramvalue;
- paramkey = strtok(chosenparams, "=");
- paramvalue = chosenparams + strlen(paramkey) + 1;
- G_set_key_value( paramkey, paramvalue, *projinfo );
- G_free( chosenparams );
- if(paramsets > 0)
- G_free(params);
+ if (paramsets > 0) {
+ struct gpj_datum_transform_list *list, *old;
+ list = GPJ_get_datum_transform_by_name(datum);
+ if (list != NULL) {
+ do {
+ if (list->count == datumtrans) {
+ chosenparams = G_store(list->params);
+ break;
+ old = list;
+ G_free(old);
+ } while (list != NULL);
+ if (chosenparams != NULL) {
+ char *paramkey, *paramvalue;
+ paramkey = strtok(chosenparams, "=");
+ paramvalue = chosenparams + strlen(paramkey) + 1;
+ G_set_key_value(paramkey, paramvalue, *projinfo);
+ G_free(chosenparams);
+ G_free(params);
-/* Determine an appropriate GRASS ellipsoid name if possible, or */
-/* else just put a and es values into PROJ_INFO */
+ /* Determine an appropriate GRASS ellipsoid name if possible, or */
+ /* else just put a and es values into PROJ_INFO */
- if( (datum != NULL) && (GPJ_get_datum_by_name( datum, &dstruct ) > 0) )
- /* Use ellps name associated with datum */
- G_set_key_value( "ellps", dstruct.ellps, *projinfo );
- GPJ_free_datum( &dstruct );
- G_free( datum );
+ if ((datum != NULL) && (GPJ_get_datum_by_name(datum, &dstruct) > 0)) {
+ /* Use ellps name associated with datum */
+ G_set_key_value("ellps", dstruct.ellps, *projinfo);
+ G_free(datum);
- else
- /* If we can't determine the ellipsoid from the datum, derive it
- * directly from "SPHEROID" parameters in WKT */
- const char *pszSemiMajor = OSRGetAttrValue( hSRS, "SPHEROID", 1 );
- const char *pszInvFlat = OSRGetAttrValue( hSRS, "SPHEROID", 2 );
+ else {
+ /* If we can't determine the ellipsoid from the datum, derive it
+ * directly from "SPHEROID" parameters in WKT */
+ const char *pszSemiMajor = OSRGetAttrValue(hSRS, "SPHEROID", 1);
+ const char *pszInvFlat = OSRGetAttrValue(hSRS, "SPHEROID", 2);
- if( pszSemiMajor != NULL && pszInvFlat != NULL )
- char *ellps = NULL;
- struct ellps_list *list, *listhead;
- double a = atof(pszSemiMajor), flat = atof(pszInvFlat);
- double es;
- /* Allow for incorrect WKT describing a sphere where InvFlat
- * is given as 0 rather than inf */
- if( flat > 0 )
- flat = 1 / flat;
- es = flat * (2.0 - flat);
+ if (pszSemiMajor != NULL && pszInvFlat != NULL) {
+ char *ellps = NULL;
+ struct ellps_list *list, *listhead;
+ double a = atof(pszSemiMajor), flat = atof(pszInvFlat);
+ double es;
- list = listhead = read_ellipsoid_table(0);
- /* Try and match a and es against GRASS defined ellipsoids;
+ /* Allow for incorrect WKT describing a sphere where InvFlat
+ * is given as 0 rather than inf */
+ if (flat > 0)
+ flat = 1 / flat;
+ es = flat * (2.0 - flat);
+ list = listhead = read_ellipsoid_table(0);
+ /* Try and match a and es against GRASS defined ellipsoids;
* accept first one that matches. These numbers were found
* by trial and error and could be fine-tuned, or possibly
* a direct comparison of IEEE floating point values used. */
- if ( ( a == list->a || fabs(a - list->a) < 0.1 || fabs(1 - a/list->a) < 0.0000001 ) &&
- ( es == list->es || fabs(es - list->es) < 0.000000001 || fabs(1 - es/list->es) < 0.0000001) )
- ellps = G_store(list->name);
- break;
- if(listhead != NULL)
- free_ellps_list(listhead);
+ if ((a == list->a || fabs(a - list->a) < 0.1 ||
+ fabs(1 - a / list->a) < 0.0000001) && (es == list->es ||
+ fabs(es -
+ list->es) <
+ 0.000000001 ||
+ fabs(1 -
+ es /
+ list->es) <
+ 0.0000001)) {
+ ellps = G_store(list->name);
+ break;
+ if (listhead != NULL)
+ free_ellps_list(listhead);
- if(ellps == NULL)
- /* If we weren't able to find a matching ellps name, set
- * a and es values directly from WKT-derived data */
- char es_str[100];
+ if (ellps == NULL) {
+ /* If we weren't able to find a matching ellps name, set
+ * a and es values directly from WKT-derived data */
+ char es_str[100];
- G_set_key_value( "a", (char *) pszSemiMajor, *projinfo );
+ G_set_key_value("a", (char *)pszSemiMajor, *projinfo);
- sprintf( es_str, "%.16g", es );
- G_set_key_value( "es", es_str, *projinfo );
- else
- /* else specify the GRASS ellps name for readability */
- G_set_key_value( "ellps", ellps, *projinfo );
- G_free(ellps);
+ sprintf(es_str, "%.16g", es);
+ G_set_key_value("es", es_str, *projinfo);
+ else {
+ /* else specify the GRASS ellps name for readability */
+ G_set_key_value("ellps", ellps, *projinfo);
+ G_free(ellps);
-/* Finally append the detailed projection parameters to the end */
+ /* Finally append the detailed projection parameters to the end */
- int i;
- for ( i = 0; i < temp_projinfo->nitems; i++)
- G_set_key_value( temp_projinfo->key[i],
- temp_projinfo->value[i], *projinfo );
- G_free_key_value( temp_projinfo );
+ int i;
+ for (i = 0; i < temp_projinfo->nitems; i++)
+ G_set_key_value(temp_projinfo->key[i],
+ temp_projinfo->value[i], *projinfo);
+ G_free_key_value(temp_projinfo);
- free( pszProj4 ); /* hopefully the same as CPLFree()! */
-/* Set the linear units. */
+ free(pszProj4); /* hopefully the same as CPLFree()! */
+ /* Set the linear units. */
*projunits = G_create_key_value();
- /* We assume degrees ... someday we will be wrong! */
- G_set_key_value( "unit", "degree", *projunits );
- G_set_key_value( "units", "degrees", *projunits );
- G_set_key_value( "meters", "1.0", *projunits );
+ /* We assume degrees ... someday we will be wrong! */
+ G_set_key_value("unit", "degree", *projunits);
+ G_set_key_value("units", "degrees", *projunits);
+ G_set_key_value("meters", "1.0", *projunits);
- else
- char szFormatBuf[256];
- char *pszUnitsName = NULL;
- double dfToMeters;
- char *pszUnitsPlural, *pszStringEnd;
+ else {
+ char szFormatBuf[256];
+ char *pszUnitsName = NULL;
+ double dfToMeters;
+ char *pszUnitsPlural, *pszStringEnd;
- dfToMeters = OSRGetLinearUnits( hSRS, &pszUnitsName );
- /* Workaround for the most obvious case when unit name is unknown */
- if( (G_strcasecmp(pszUnitsName, "unknown") == 0) && (dfToMeters == 1.) )
- G_asprintf( &pszUnitsName, "meter" );
- G_set_key_value( "unit", pszUnitsName, *projunits );
- /* Attempt at plural formation (WKT format doesn't store plural
- * form of unit name) */
- pszUnitsPlural = G_malloc( strlen(pszUnitsName) + 3 );
- strcpy(pszUnitsPlural, pszUnitsName);
- pszStringEnd = pszUnitsPlural + strlen(pszUnitsPlural) - 4;
- if( G_strcasecmp(pszStringEnd, "foot") == 0 )
- /* Special case for foot - change two o's to e's */
- pszStringEnd[1] = 'e';
- pszStringEnd[2] = 'e';
- else if( G_strcasecmp(pszStringEnd, "inch") == 0 )
- /* Special case for inch - add es */
- pszStringEnd[4] = 'e';
- pszStringEnd[5] = 's';
- pszStringEnd[6] = '\0';
- else
- /* For anything else add an s at the end */
- pszStringEnd[4] = 's';
- pszStringEnd[5] = '\0';
- G_set_key_value( "units", pszUnitsPlural, *projunits );
- G_free( pszUnitsPlural );
- sprintf( szFormatBuf, "%.16g", dfToMeters );
- G_set_key_value( "meters", szFormatBuf, *projunits );
+ dfToMeters = OSRGetLinearUnits(hSRS, &pszUnitsName);
+ /* Workaround for the most obvious case when unit name is unknown */
+ if ((G_strcasecmp(pszUnitsName, "unknown") == 0) &&
+ (dfToMeters == 1.))
+ G_asprintf(&pszUnitsName, "meter");
+ G_set_key_value("unit", pszUnitsName, *projunits);
+ /* Attempt at plural formation (WKT format doesn't store plural
+ * form of unit name) */
+ pszUnitsPlural = G_malloc(strlen(pszUnitsName) + 3);
+ strcpy(pszUnitsPlural, pszUnitsName);
+ pszStringEnd = pszUnitsPlural + strlen(pszUnitsPlural) - 4;
+ if (G_strcasecmp(pszStringEnd, "foot") == 0) {
+ /* Special case for foot - change two o's to e's */
+ pszStringEnd[1] = 'e';
+ pszStringEnd[2] = 'e';
+ else if (G_strcasecmp(pszStringEnd, "inch") == 0) {
+ /* Special case for inch - add es */
+ pszStringEnd[4] = 'e';
+ pszStringEnd[5] = 's';
+ pszStringEnd[6] = '\0';
+ else {
+ /* For anything else add an s at the end */
+ pszStringEnd[4] = 's';
+ pszStringEnd[5] = '\0';
+ G_set_key_value("units", pszUnitsPlural, *projunits);
+ G_free(pszUnitsPlural);
+ sprintf(szFormatBuf, "%.16g", dfToMeters);
+ G_set_key_value("meters", szFormatBuf, *projunits);
return 2;
-/* Fallback to returning an ungeoreferenced definition. */
+ /* Fallback to returning an ungeoreferenced definition. */
default_to_xy:
- if( cellhd != NULL )
- cellhd->proj = PROJECTION_XY;
- cellhd->zone = 0;
+ if (cellhd != NULL) {
+ cellhd->proj = PROJECTION_XY;
+ cellhd->zone = 0;
*projinfo = NULL;
*projunits = NULL;
- return 1;
+ return 1;
@@ -684,26 +663,27 @@
* been defined
-int GPJ_wkt_to_grass(struct Cell_head *cellhd, struct Key_Value **projinfo,
- struct Key_Value **projunits, const char *wkt,
+int GPJ_wkt_to_grass(struct Cell_head *cellhd, struct Key_Value **projinfo,
+ struct Key_Value **projunits, const char *wkt,
int datumtrans)
int retval;
- if( wkt == NULL )
- retval = GPJ_osr_to_grass(cellhd, projinfo, projunits, NULL, datumtrans);
- else
- OGRSpatialReferenceH hSRS;
+ if (wkt == NULL)
+ retval =
+ GPJ_osr_to_grass(cellhd, projinfo, projunits, NULL, datumtrans);
+ else {
+ OGRSpatialReferenceH hSRS;
- /* Set finder function for locating OGR csv co-ordinate system tables */
- hSRS = OSRNewSpatialReference(wkt);
- retval = GPJ_osr_to_grass(cellhd, projinfo, projunits, hSRS, datumtrans);
- OSRDestroySpatialReference(hSRS);
+ /* Set finder function for locating OGR csv co-ordinate system tables */
+ hSRS = OSRNewSpatialReference(wkt);
+ retval =
+ GPJ_osr_to_grass(cellhd, projinfo, projunits, hSRS, datumtrans);
+ OSRDestroySpatialReference(hSRS);
return retval;
@@ -717,7 +697,7 @@
static char *buf = NULL;
if (buf != NULL)
- G_free(buf);
+ G_free(buf);
G_asprintf(&buf, "%s%s/%s", gisbase, CSVDIR, name);
@@ -738,8 +718,7 @@
* these shortened versions seem to be standard
-static const char *papszDatumEquiv[] =
+static const char *papszDatumEquiv[] = {
"Militar_Geographische_Institute",
"Militar_Geographische_Institut",
"World_Geodetic_System_1984",
@@ -768,54 +747,49 @@
/* Massage an EPSG datum name into WMT format. Also transform */
/* specific exception cases into WKT versions. */
-static void DatumNameMassage( char ** ppszDatum )
+static void DatumNameMassage(char **ppszDatum)
- int i, j;
- char *pszDatum = *ppszDatum;
+ int i, j;
+ char *pszDatum = *ppszDatum;
-/* Translate non-alphanumeric values to underscores. */
- for( i = 0; pszDatum[i] != '\0'; i++ )
- if( !(pszDatum[i] >= 'A' && pszDatum[i] <= 'Z')
- && !(pszDatum[i] >= 'a' && pszDatum[i] <= 'z')
- && !(pszDatum[i] >= '0' && pszDatum[i] <= '9') )
- pszDatum[i] = '_';
+ /* Translate non-alphanumeric values to underscores. */
+ for (i = 0; pszDatum[i] != '\0'; i++) {
+ if (!(pszDatum[i] >= 'A' && pszDatum[i] <= 'Z')
+ && !(pszDatum[i] >= 'a' && pszDatum[i] <= 'z')
+ && !(pszDatum[i] >= '0' && pszDatum[i] <= '9')) {
+ pszDatum[i] = '_';
-/* Remove repeated and trailing underscores. */
- for( i = 1, j = 0; pszDatum[i] != '\0'; i++ )
- if( pszDatum[j] == '_' && pszDatum[i] == '_' )
- continue;
+ /* Remove repeated and trailing underscores. */
+ for (i = 1, j = 0; pszDatum[i] != '\0'; i++) {
+ if (pszDatum[j] == '_' && pszDatum[i] == '_')
+ continue;
- pszDatum[++j] = pszDatum[i];
+ pszDatum[++j] = pszDatum[i];
- if( pszDatum[j] == '_' )
- pszDatum[j] = '\0';
+ if (pszDatum[j] == '_')
+ pszDatum[j] = '\0';
else
- pszDatum[j+1] = '\0';
-/* Search for datum equivelences. Specific massaged names get */
-/* mapped to OpenGIS specified names. */
- for( i = 0; papszDatumEquiv[i] != NULL; i += 2 )
- if( EQUAL(*ppszDatum,papszDatumEquiv[i]) )
- CPLFree( *ppszDatum );
- *ppszDatum = CPLStrdup( papszDatumEquiv[i+1] );
- break;
+ pszDatum[j + 1] = '\0';
+ /* Search for datum equivelences. Specific massaged names get */
+ /* mapped to OpenGIS specified names. */
+ for (i = 0; papszDatumEquiv[i] != NULL; i += 2) {
+ if (EQUAL(*ppszDatum, papszDatumEquiv[i])) {
+ CPLFree(*ppszDatum);
+ *ppszDatum = CPLStrdup(papszDatumEquiv[i + 1]);
+ break;
Modified: grass/branches/releasebranch_6_3/lib/proj/datum.c
--- grass/branches/releasebranch_6_3/lib/proj/datum.c 2009-01-10 09:09:27 UTC (rev 35311)
+++ grass/branches/releasebranch_6_3/lib/proj/datum.c 2009-01-10 12:14:48 UTC (rev 35312)
@@ -87,32 +87,30 @@
int GPJ_get_default_datum_params_by_name(const char *name, char **params)
- int count = 1;
+ int count = 1;
- list = GPJ_get_datum_transform_by_name( name );
- if( list == NULL)
- *params = NULL;
- return -1;
- /* Take the first parameter set in the list as the default
- * (will normally be a 3-parameter transformation) */
- *params = G_store( list->params );
- while(list->next != NULL)
- count++;
+ list = GPJ_get_datum_transform_by_name(name);
+ if (list == NULL) {
+ *params = NULL;
+ return -1;
+ /* Take the first parameter set in the list as the default
+ * (will normally be a 3-parameter transformation) */
+ *params = G_store(list->params);
+ while (list->next != NULL) {
+ count++;
old = list;
list = list->next;
- G_free( old );
- G_free( list );
- return count;
+ G_free(old);
+ G_free(list);
+ return count;
@@ -193,14 +191,15 @@
returnval = 2;
else if (G_find_key_value("nadgrids", projinfo) != NULL) {
- const char *gisbase = G_gisbase();
+ const char *gisbase = G_gisbase();
G_asprintf(params, "nadgrids=%s%s/%s", gisbase, GRIDDIR,
G_find_key_value("nadgrids", projinfo));
returnval = 2;
else if (G_find_key_value("towgs84", projinfo) != NULL) {
- G_asprintf(params, "towgs84=%s", G_find_key_value("towgs84", projinfo));
+ G_asprintf(params, "towgs84=%s",
+ G_find_key_value("towgs84", projinfo));
returnval = 2;
else if (G_find_key_value("dx", projinfo) != NULL
@@ -245,114 +244,124 @@
char buff[1024], answer[100];
char *Tmp_file;
- FILE *Tmp_fd = NULL;
+ FILE *Tmp_fd = NULL;
struct gpj_datum_transform_list *list, *listhead, *old;
int transformcount, currenttransform;
- if( G_strcasecmp(datumname, "custom") != 0)
- Tmp_file = G_tempfile ();
- if (NULL == (Tmp_fd = fopen (Tmp_file, "w"))) {
- G_warning(_("Cannot open temp file") );
+ if (G_strcasecmp(datumname, "custom") != 0) {
+ Tmp_file = G_tempfile();
+ if (NULL == (Tmp_fd = fopen(Tmp_file, "w"))) {
+ G_warning(_("Cannot open temp file"));
- fprintf(Tmp_fd,"Number\tDetails\t\n---\n");
- listhead = GPJ_get_datum_transform_by_name( datumname );
- list = listhead;
- transformcount = 0;
- while( list != NULL)
+ fprintf(Tmp_fd, "Number\tDetails\t\n---\n");
+ listhead = GPJ_get_datum_transform_by_name(datumname);
+ list = listhead;
+ transformcount = 0;
/* Count how many sets of transformation paramters have been
* defined for this datum and print them to a temporary file
* in case the user asks for them to be displayed */
- fprintf(Tmp_fd,"%d\tUsed in %s\n\t(PROJ.4 Params %s)\n\t%s\n---\n",
- list->count, list->where_used, list->params, list->comment);
- transformcount++;
- fclose(Tmp_fd);
+ fprintf(Tmp_fd,
+ "%d\tUsed in %s\n\t(PROJ.4 Params %s)\n\t%s\n---\n",
+ list->count, list->where_used, list->params,
+ list->comment);
+ transformcount++;
+ fclose(Tmp_fd);
- for(;;) {
- do {
- fprintf(stderr,("\nNow select Datum Transformation Parameters\n"));
- fprintf(stderr,("Please think carefully about the area covered by your data\n"
- "and the accuracy you require before making your selection.\n"));
- fprintf(stderr,("\nEnter 'list' to see the list of available Parameter sets\n"));
- fprintf(stderr,("Enter the corresponding number, or <RETURN> to cancel request\n"));
- fprintf(stderr,">");
- } while(!G_gets(answer));
- G_strip(answer);
- if(strlen(answer)==0)
- remove( Tmp_file );
- G_free( Tmp_file );
- return -1;
- if (strcmp(answer,"list") == 0) {
- char *pager;
+ for (;;) {
+ do {
+ fprintf(stderr,
+ ("\nNow select Datum Transformation Parameters\n"));
+ fprintf(stderr,
+ ("Please think carefully about the area covered by your data\n"
+ "and the accuracy you require before making your selection.\n"));
+ fprintf(stderr,
+ ("\nEnter 'list' to see the list of available Parameter sets\n"));
+ fprintf(stderr,
+ ("Enter the corresponding number, or <RETURN> to cancel request\n"));
+ fprintf(stderr, ">");
+ } while (!G_gets(answer));
+ G_strip(answer);
+ if (strlen(answer) == 0) {
+ remove(Tmp_file);
+ G_free(Tmp_file);
+ return -1;
+ if (strcmp(answer, "list") == 0) {
+ char *pager;
- pager = getenv("GRASS_PAGER");
- if (!pager || strlen(pager) == 0)
- pager = "cat";
+ pager = getenv("GRASS_PAGER");
+ if (!pager || strlen(pager) == 0)
+ pager = "cat";
/* Always print interactive output to stderr */
- sprintf(buff,"%s \"%s\" 1>&2", pager, G_convert_dirseps_to_host(Tmp_file));
- G_system(buff);
- else {
- if ( (sscanf(answer, "%d", ¤ttransform) != 1) ||
- currenttransform > transformcount || currenttransform < 1) {
+ sprintf(buff, "%s \"%s\" 1>&2", pager,
+ G_convert_dirseps_to_host(Tmp_file));
+ G_system(buff);
+ else {
+ if ((sscanf(answer, "%d", ¤ttransform) != 1) ||
+ currenttransform > transformcount ||
+ currenttransform < 1) {
/* If a number was not typed, was less than 0 or greater
* than the number of sets of parameters, ask again */
- fprintf(stderr,("\ninvalid transformation number\n"));
- else break;
+ fprintf(stderr, ("\ninvalid transformation number\n"));
+ else
+ break;
- remove ( Tmp_file );
- G_free ( Tmp_file );
- list = listhead;
+ remove(Tmp_file);
+ G_free(Tmp_file);
+ list = listhead;
/* Search through the linked list to find the parameter string
* that corresponds to the number entered */
- if( list->count == currenttransform )
- G_asprintf(params, list->params);
+ if (list->count == currenttransform)
+ G_asprintf(params, list->params);
/* Continue to end of list even after we find it, to free all
* the memory used */
- old = list;
- list = old->next;
- G_free( old );
+ old = list;
+ list = old->next;
+ G_free(old);
- else
- /* Here we ask the user to enter customised parameters */
- for(;;) {
- do {
- fprintf(stderr,("\nPlease specify datum transformation parameters in PROJ.4 syntax. Examples:\n"));
- fprintf(stderr,("\ttowgs84=dx,dy,dz\t(3-parameter transformation)\n"));
- fprintf(stderr,("\ttowgs84=dx,dy,dz,rx,ry,rz,m\t(7-parameter transformation)\n"));
- fprintf(stderr,("\tnadgrids=alaska\t(Tables-based grid-shifting transformation)\n"));
- fprintf (stderr,_("Hit RETURN to cancel request\n"));
- G_strip(answer);
- return -1;
+ else {
+ /* Here we ask the user to enter customised parameters */
+ for (;;) {
+ do {
+ fprintf(stderr,
+ ("\nPlease specify datum transformation parameters in PROJ.4 syntax. Examples:\n"));
+ fprintf(stderr,
+ ("\ttowgs84=dx,dy,dz\t(3-parameter transformation)\n"));
+ fprintf(stderr,
+ ("\ttowgs84=dx,dy,dz,rx,ry,rz,m\t(7-parameter transformation)\n"));
+ fprintf(stderr,
+ ("\tnadgrids=alaska\t(Tables-based grid-shifting transformation)\n"));
+ fprintf(stderr, _("Hit RETURN to cancel request\n"));
+ G_strip(answer);
+ return -1;
G_asprintf(params, answer);
- sprintf(buff, "Parameters to be used are:\n\"%s\"\nIs this correct?", *params);
- if (G_yes(buff, 1))
- break;
+ sprintf(buff,
+ "Parameters to be used are:\n\"%s\"\nIs this correct?",
+ *params);
+ if (G_yes(buff, 1))
+ break;
return 1;
@@ -370,7 +379,7 @@
struct gpj_datum_transform_list *GPJ_get_datum_transform_by_name(const char
- *inputname)
+ *inputname)
FILE *fd;
char *file;
@@ -394,9 +403,10 @@
G_asprintf(&(current->params), "towgs84=%.3f,%.3f,%.3f", dstruct.dx,
dstruct.dy, dstruct.dz);
G_asprintf(&(current->where_used), "whole %s region", inputname);
- G_asprintf(&(current->comment), "Default 3-Parameter Transformation (May not be optimum for "
- "older datums; use this only if no more appropriate options "
- "are available.)");
+ G_asprintf(&(current->comment),
+ "Default 3-Parameter Transformation (May not be optimum for "
+ "older datums; use this only if no more appropriate options "
+ "are available.)");
count++;
current->count = count;
current->next = NULL;
@@ -404,7 +414,7 @@
/* Now check for additional parameters in datumtransform.table */
G_asprintf(&file, "%s%s", G_gisbase(), DATUMTRANSFORMTABLE);
fd = fopen(file, "r");
Modified: grass/branches/releasebranch_6_3/lib/proj/do_proj.c
--- grass/branches/releasebranch_6_3/lib/proj/do_proj.c 2009-01-10 09:09:27 UTC (rev 35311)
+++ grass/branches/releasebranch_6_3/lib/proj/do_proj.c 2009-01-10 12:14:48 UTC (rev 35312)
@@ -144,6 +144,7 @@
if (h == NULL) {
int i;
h = G_malloc(sizeof *h * count);
/* they say memset is only guaranteed for chars ;-( */
for (i = 0; i < count; ++i)
Modified: grass/branches/releasebranch_6_3/lib/proj/ellipse.c
--- grass/branches/releasebranch_6_3/lib/proj/ellipse.c 2009-01-10 09:09:27 UTC (rev 35311)
+++ grass/branches/releasebranch_6_3/lib/proj/ellipse.c 2009-01-10 12:14:48 UTC (rev 35312)
@@ -26,7 +26,8 @@
#include <grass/gprojects.h>
#include "local_proto.h"
-static int get_a_e2_f(const char *, const char *, double *, double *, double *);
+static int get_a_e2_f(const char *, const char *, double *, double *,
+ double *);
* This routine returns the ellipsoid parameters from the database.
@@ -217,7 +218,8 @@
if (fd == NULL) {
perror(file);
- G_asprintf(&errbuf, _("unable to open ellipsoid table file: %s"), file);
+ G_asprintf(&errbuf, _("unable to open ellipsoid table file: %s"),
+ file);
fatal ? G_fatal_error(errbuf) : G_warning(errbuf);
G_free(errbuf);
return 0;
@@ -230,8 +232,8 @@
if (*buf == 0 || *buf == '#')
continue;
- if (sscanf(buf, "%s \"%1023[^\"]\" %s %s", name, descr, buf1, buf2) !=
- 4) {
+ if (sscanf(buf, "%s \"%1023[^\"]\" %s %s", name, descr, buf1, buf2)
+ != 4) {
err++;
sprintf(buf, " %d", line);
if (*badlines)
Modified: grass/branches/releasebranch_6_3/lib/proj/get_proj.c
--- grass/branches/releasebranch_6_3/lib/proj/get_proj.c 2009-01-10 09:09:27 UTC (rev 35311)
+++ grass/branches/releasebranch_6_3/lib/proj/get_proj.c 2009-01-10 12:14:48 UTC (rev 35312)
@@ -1,3 +1,4 @@
\file get_proj.c
@@ -187,9 +188,9 @@
/* Workaround to stop PROJ reading values from defaults file when
* rf (and sometimes ellps) is not specified */
if (G_find_key_value("no_defs", in_proj_keys) == NULL) {
- sprintf(buffa, "no_defs");
- alloc_options(buffa);
+ sprintf(buffa, "no_defs");
+ alloc_options(buffa);
/* If datum parameters are present in the PROJ_INFO keys, pass them on */
if (GPJ__get_datum_params(in_proj_keys, &datum, ¶ms) == 2) {
@@ -201,7 +202,7 @@
* from the datum.table file */
else if (datum != NULL) {
if (GPJ_get_default_datum_params_by_name(datum, ¶ms) > 0) {
sprintf(buffa, params);
@@ -227,15 +228,16 @@
pj_set_finder(FINDERFUNC);
if (!(pj = pj_init(nopt1, opt_in))) {
- strcpy(buffa, _("Unable to initialise PROJ.4 with the following parameter list:"));
+ strcpy(buffa,
+ _("Unable to initialise PROJ.4 with the following parameter list:"));
for (i = 0; i < nopt1; i++) {
char err[50];
- sprintf (err, " +%s", opt_in[i]);
- strcat (buffa, err);
+ sprintf(err, " +%s", opt_in[i]);
+ strcat(buffa, err);
- G_warning (buffa);
- G_warning (_("The error message: %s"),
- pj_strerrno(pj_errno));
+ G_warning(buffa);
+ G_warning(_("The error message: %s"), pj_strerrno(pj_errno));
return -1;
info->pj = pj;
@@ -248,7 +250,7 @@
int nsize;
nsize = strlen(buffa);
- opt_in[nopt1++] = (char *) G_malloc(nsize + 1);
+ opt_in[nopt1++] = (char *)G_malloc(nsize + 1);
sprintf(opt_in[nopt1 - 1], buffa);
return;
@@ -273,7 +275,7 @@
sprintf(info->proj, "ll");
sprintf(buffa, "proj=latlong ellps=WGS84");
- opt_in[nopt] = (char *) G_malloc(nsize + 1);
+ opt_in[nopt] = (char *)G_malloc(nsize + 1);
sprintf(opt_in[nopt++], buffa);
else {
@@ -312,7 +314,7 @@
sprintf(buffa, s);
@@ -324,7 +326,8 @@
if (!(pj = pj_init(nopt, opt_in))) {
- G_warning (_("Unable to initialize pj cause: %s"), pj_strerrno(pj_errno));
+ G_warning(_("Unable to initialize pj cause: %s"),
+ pj_strerrno(pj_errno));
return -1;
info->pj = pj;
@@ -399,9 +402,11 @@
if (iproj) {
str = pj_get_def(iproj->pj, 1);
if (str != NULL) {
- fprintf (stderr, "%s: %s\n", _("Input Projection Parameters"), str);
+ fprintf(stderr, "%s: %s\n", _("Input Projection Parameters"),
+ str);
G_free(str);
- fprintf (stderr, "%s: %.16g\n", _("Input Unit Factor"), iproj->meters);
+ fprintf(stderr, "%s: %.16g\n", _("Input Unit Factor"),
+ iproj->meters);
else
return -1;
@@ -410,9 +415,11 @@
if (oproj) {
str = pj_get_def(oproj->pj, 1);
if (str != NULL) {
- fprintf (stderr, "%s: %s\n", _("Output Projection Parameters"), str);
+ fprintf(stderr, "%s: %s\n", _("Output Projection Parameters"),
+ str);
G_free(str);
- fprintf (stderr, "%s: %.16g\n", _("Output Unit Factor"), oproj->meters);
+ fprintf(stderr, "%s: %.16g\n", _("Output Unit Factor"),
+ oproj->meters);
else
return -1;
