[GRASS-SVN] r35356 -
grass/branches/releasebranch_6_4/gui/wxpython/docs
svn_grass at osgeo.org
Mon Jan 12 06:07:03 EST 2009
Author: martinl
Date: 2009-01-12 06:07:02 -0500 (Mon, 12 Jan 2009)
New Revision: 35356
grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html
grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI_vector_digitizer_toolbar.jpg
wxGUI: update vector digizer manual page (new icons)
(merge from trunk, r35354)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html
--- grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html 2009-01-12 11:06:30 UTC (rev 35355)
+++ grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html 2009-01-12 11:07:02 UTC (rev 35356)
@@ -60,56 +60,82 @@
</center>
<dl>
- <dt><img src="icons/silk/bullet_add.png"> Digitize new point</dt>
+ <dt><img src="icons/grass2/point-create.png">
+ <img src="icons/grass/vdigit/new.point.gif">
+ <img src="icons/silk/bullet_add.png"> <em>Digitize new point</em></dt>
<dd>Add new point to vector map and optionally define its
attributes.</dd>
- <dt><img src="icons/silk/vector_add.png"> Digitize new line</dt>
+ <dt><img src="icons/grass2/line-create.png">
+ <img src="icons/grass/vdigit/new.line.gif">
+ <img src="icons/silk/vector_add.png"> <em>Digitize new line</em></dt>
<dd>Add new line to vector map and optionally define its
attributes.</dd>
- <dt><img src="icons/silk/shape_handles.png"> Digitize new boundary</dt>
+ <dt><img src="icons/grass2/polygon-create.png">
+ <img src="icons/grass/vdigit/new.boundary.gif">
+ <img src="icons/silk/shape_handles.png"> <em>Digitize new boundary</em></dt>
<dd>Add new boundary to vector map and optionally define its
attributes.</dd>
- <dt><img src="icons/silk/shape_square_add.png"> Digitize new centroid</dt>
+ <dt><img src="icons/grass2/centroid-create.png">
+ <img src="icons/grass/vdigit/new.centroid.gif">
+ <img src="icons/silk/shape_square_add.png"> <em>Digitize new centroid</em></dt>
<dd>Add new centroid to vector map and optionally define its
attributes.</dd>
- <dt><img src="icons/silk/chart_line.png"> Move vertex</dt>
+ <dt><img src="icons/grass2/vertex-move.png">
+ <img src="icons/grass/vdigit/move.vertex.gif">
+ <img src="icons/silk/chart_line.png"> <em>Move vertex</em></dt>
<dd>Move selected vertex of linear feature. Thus shape of linear
feature is changed.</dd>
- <dt><img src="icons/silk/chart_line_add.png"> Add vertex</dt>
+ <dt><img src="icons/grass2/vertex-create.png">
+ <img src="icons/grass/vdigit/add.vertex.gif">
+ <img src="icons/silk/chart_line_add.png"> <em>Add vertex</em></dt>
<dd>Add new vertex to selected linear feature (shape not
changed).</dd>
- <dt><img src="icons/silk/chart_line_delete.png"> Remove vertex</dt>
+ <dt><img src="icons/grass2/vertex-delete.png">
+ <img src="icons/grass/vdigit/rm.vertex.gif">
+ <img src="icons/silk/chart_line_delete.png"> <em>Remove vertex</em></dt>
<dd>Remove selected vertex from linear feature. Thus shape of selected
feature can be changed.</dd>
- <dt><img src="icons/silk/chart_line_link.png"> Split line/boundary</dt>
+ <dt><img src="icons/grass2/line-split.png">
+ <img src="icons/grass/vdigit/split.line.gif">
+ <img src="icons/silk/chart_line_link.png"> <em>Split line/boundary</em></dt>
<dd>Split selected linear feature on given position to separate
vector features.</dd>
- <dt><img src="icons/silk/chart_line_edit.png"> Edit line/boundary</dt>
+ <dt><img src="icons/grass2/line-edit.png">
+ <img src="icons/grass/vdigit/edit.line.gif">
+ <img src="icons/silk/chart_line_edit.png"> <em>Edit line/boundary</em></dt>
<dd>Edit selected linear feature, add new segments or remove
existing segments of linear feature.</dd>
- <dt><img src="icons/silk/bullet_go.png"> Move feature(s)</dt>
+ <dt><img src="icons/grass2/line-move.png">
+ <img src="icons/grass/vdigit/move.line.gif">
+ <img src="icons/silk/bullet_go.png"> <em>Move feature(s)</em></dt>
<dd>Move selected vector features. Selection can be done by mouse or
by query.</dd>
- <dt><img src="icons/silk/vector_delete.png"> Delete feature(s)</dt>
+ <dt><img src="icons/grass2/line-delete.png">
+ <img src="icons/grass/vdigit/delete.line.gif">
+ <img src="icons/silk/vector_delete.png"> <em>Delete feature(s)</em></dt>
<dd>Delete selected vector features. Selection can be done by mouse
or by query.</dd>
- <dt><img src="icons/silk/chart_organisation.png"> Display/update categories</dt>
+ <dt><img src="icons/grass2/cats-display.png">
+ <img src="icons/grass/vdigit/display.cats.gif">
+ <img src="icons/silk/chart_organisation.png"> <em>Display/update categories</em></dt>
<dd>Display categories of selected vector feature. Category settings
can be modified, new layer/category pairs added or already defined pairs
removed.</dd>
- <dt><img src="icons/silk/chart_organisation_add.png"> Copy categories / Duplicate attributes</dt>
+ <dt><img src="icons/grass2/cats-copy.png">
+ <img src="icons/grass/vdigit/copy.cats.gif">
+ <img src="icons/silk/chart_organisation_add.png"> <em>Copy categories / Duplicate attributes</em></dt>
<dd><ul>
<li>Copy category settings of selected vector feature to other
vector features. Layer/category pairs of source vector features are
@@ -125,13 +151,17 @@
</ul>
</dd>
- <dt><img src="icons/silk/table.png"> Display/update attributes</dt>
+ <dt<img src="icons/grass2/attributes-display.png">
+ <img src="icons/grass/vdigit/display.attributes.gif">
+ <img src="icons/silk/table.png"> <em>Display/update attributes</em></dt>
<dd>Display attributes of selected vector feature (based on its
category settings). Attributes can be also modified. Same
functionality is accessible from Main toolbar "Query vector map
(editable mode)".</dd>
- <dt><img src="icons/silk/plugin.png"> Additional tools</dt>
+ <dt><img src="icons/grass2/tools.png">
+ <img src="icons/silk/plugin.png"> <em>Additional tools</em></dt>
<dd>
<ul>
<li>Copy features from (background) map<br> Make identical copy of
@@ -173,13 +203,19 @@
</ul>
</dd>
- <dt><img src="icons/silk/arrow_undo.png"> Undo</dt>
+ <dt><img src="icons/grass2/undo.png">
+ <img src="icons/silk/arrow_undo.png"> <em>Undo</em></dt>
<dd>Undo previous operations.</dd>
- <dt><img src="icons/silk/color_swatch.png"> Settings</dt>
+ <dt><img src="icons/grass2/settings.png">
+ <img src="icons/grass/vdigit/settings.gif">
+ <img src="icons/silk/color_swatch.png"> <em>Settings</em></dt>
<dd>Dialog for vector digitizer settings.</dd>
- <dt><img src="icons/silk/door_in.png"> Quit digitizing tool</dt>
+ <dt><img src="icons/grass2/quit.png">
+ <img src="icons/grass/gui-exit.gif">
+ <img src="icons/silk/door_in.png"> <em>Quit digitizing tool</em></dt>
<dd>Changes in vector map can be optionally discarded when
digitizing session is quited.</dd>
Modified: grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI_vector_digitizer_toolbar.jpg
(Binary files differ)
