[GRASS-SVN] r35563 - in grass-addons/LandDyn: . r.lcov.stats.py
Fri Jan 23 15:35:59 EST 2009
Author: isaacullah
Date: 2009-01-23 15:35:59 -0500 (Fri, 23 Jan 2009)
New Revision: 35563
Added:
   grass-addons/LandDyn/r.lcov.stats.py/
   grass-addons/LandDyn/r.lcov.stats.py/r.lcov.stats.py
python script to gather univaritate stats from a run of any of the LandDyn landuse/landcover scripts (ie. r.agropast.extensive, etc) and format them, and write them to a comma delimited txt file
Added: grass-addons/LandDyn/r.lcov.stats.py/r.lcov.stats.py
--- grass-addons/LandDyn/r.lcov.stats.py/r.lcov.stats.py	                        (rev 0)
+++ grass-addons/LandDyn/r.lcov.stats.py/r.lcov.stats.py	2009-01-23 20:35:59 UTC (rev 35563)
@@ -0,0 +1,196 @@
+#!/usr/bin/env python
+# MODULE:
+# AUTHOR(S):    iullah
+# COPYRIGHT:    (C) 2007 GRASS Development Team/iullah
+#  description: Grabs landcover stats from a stack of sequnetially numbered landcover maps, and makes a formatted csv file
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+#%Module
+#% description: Grabs landcover stats from a stack of sequnetially numbered landcover maps, and makes a formatted csv file
+#%End
+#%option
+#% key: pattern
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Pattern of first part of file names (prefixes) for input landcover map series (leave off #'s)
+#% required : yes
+#%END
+#%option
+#% key: suffix
+#% type: string
+#% description: Pattern of last part of file names (suffixes) for map series with infixed numbers (leave blank if numbers are on the end of the file name!!!)
+#% required : no
+#%END
+#%option
+#% key: startnum
+#% type: integer
+#% description: Smallest number of the input map series (ie. # of the first map you'd like to include in the cumulative series).
+#% answer: 1
+#% required : yes
+#%END
+#%option
+#% key: endnum
+#% type: integer
+#% description: Largest number of the input map series (ie. # of the last map you'd like to include in the cumulative series).
+#% answer: 40
+#% required : yes
+#%END
+#%option
+#% key: categories
+#% type: integer
+#% description: Number of landcover categories used in the input maps
+#% answer: 50
+#% required : yes
+#%END
+#%option
+#% key: digits
+#% type: integer
+#% description: Total number of digits for input (and output) numbers. (for padding with leading zeros. if zero, numbers are given no leading zeroes)
+#% required : yes
+#% answer: 0
+#%END
+#%option
+#% key: statsout
+#% type: string
+#% description: Name of output stats file
+#% answer: lc_stats.csv
+#% required : yes
+#%END
+#%Flag
+#% key: n
+#% description: -n Automatically name stats file  "lc_stats_'mapset'_'pattern'.csv". Disregards option "statsout".
+#%End
+#%Flag
+#% key: r
+#% description: -r Output stats file formatted as a GRASS xy ASCII raster matrix (X = categories, Y = years).
+#%End
+#%Flag
+#% key: e
+#% description: -e export all maps to PNG files in home directory (good for animation in other programs)
+#%End
+import sys
+import os
+import subprocess
+def grass_print(m):
+	return subprocess.Popen("g.message message='"'%s'"'" % m, shell='bash').wait()
+def main():
+	pattern = os.getenv("GIS_OPT_pattern")
+	startnum = int(os.getenv("GIS_OPT_startnum"))
+	endnum = int(os.getenv("GIS_OPT_endnum"))
+	categories = int(os.getenv("GIS_OPT_categories"))
+	digits = int(os.getenv("GIS_OPT_digits"))
+	msp = subprocess.Popen('g.gisenv get=MAPSET store=gisrc --quiet', stdout=subprocess.PIPE, shell='bash')
+	mapset = msp.stdout.read().replace('\n','')
+	if os.getenv("GIS_FLAG_n") == "1":
+		statsout = 'lc_stats_%s_%s.csv' % (mapset,pattern)
+	else:
+		statsout = os.getenv("GIS_OPT_statsout")
+        f = open(statsout, 'w')
+        l = [str(x) for x in range(0,categories+1)]
+        md = {}
+	if bool(os.getenv("GIS_OPT_suffix")) == False:
+		grass_print("Numbers are suffixes to prefix: %s" % pattern)
+		for number in range(startnum, endnum+1):
+		    outmap = '%s%s' % (pattern, str(number).zfill(digits))
+		    p = subprocess.Popen('r.stats -a -n input=%s fs=space nv=* nsteps=255 --quiet' % outmap, stdout=subprocess.PIPE, shell='bash')
+		    out = p.stdout.readlines()
+		    dict1 = {}
+		    for x in out:
+			x0,x1 = x.split()
+			dict1[x0] = x1
+		    mdlist = []
+		    for key in l:
+			if dict1.has_key(key):
+			    mdlist.append(dict1[key])
+			else:
+			    mdlist.append('0')
+		    md[number] = mdlist
+		    if ( os.getenv("GIS_FLAG_e") == "1" ):
+			subprocess.Popen('r.out.png --quiet quiet input=%s output=%s.png' % (outmap, outmap), shell='bash').wait()
+		if os.getenv("GIS_FLAG_r") == "1":
+			f.write('north: %s\nsouth: %s\neast: %s\nwest: 1\ncols: %s\nrows: %s\n' % (endnum,startnum,categories,categories,endnum))
+			stat_list = []
+			for key in md.iterkeys():
+				stats = md[key]
+				stat_list.append('%s\n' % (','.join(stats)))
+			stat_list.reverse()
+			grass_print(stat_list)
+			f.writelines(stat_list)
+			f.close()
+		else:
+			f.write('Landcover Category,%s\n' % ','.join(l))
+				stats = md.get(key, [])
+				stat_str = 'Year %s,%s\n' % (key, ','.join(stats))
+				f.write(stat_str)
+	else:
+		suffix = os.getenv("GIS_OPT_suffix")
+		grass_print("Numbers are infixes between prefix: %s and suffix: %s" % (pattern, suffix))
+		    outmap = '%s%s%s' % (pattern, str(number).zfill(digits), suffix)
+		    dict1 = {}
+		    for x in out:
+			x0,x1 = x.split()
+			dict1[x0] = x1
+		    mdlist = []
+		    for key in l:
+			else:
+			stat_list = []
+				stats = md[key]
+			f.close()
+		else:
+				f.write(stat_str)
+        f.close()
+        return
+if __name__ == "__main__":
+    if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
+        os.execvp("g.parser", [sys.argv[0]] + sys.argv)
+    else:
+        grass_print("Starting the process, hold on!")
+	grass_print("It is not done until you see DONE WITH EVERYTHING!")
+        main();
+        grass_print("DONE WITH EVERYTHING!")
Property changes on: grass-addons/LandDyn/r.lcov.stats.py/r.lcov.stats.py
___________________________________________________________________
